http://forum.kia-club.ru/kb.php?a=129
Текущее время: 09 фев 2026, 18:04
Расшифровка кодов ошибок.ID статьи: 129Авторство: =ЛёШка= Дата: 30 ноя 2008, 22:17 Описание статьи: Standard OBD-II codes starting with "P"
Количество просмотров статьи: 36900
P0000 No fault found —
P0001 Fuel volume regulator control – circuit open Wiring, regulator control solenoid P0002 Fuel volume regulator control – circuit range/performance Wiring, regulator control solenoid P0003 Fuel volume regulator control – circuit low Wiring short to ground, regulator control solenoid P0004 Fuel volume regulator control – circuit high Wiring open circuit/short to positive, regulator control solenoid P0005 Fuel shut-off valve control – circuit open Wiring open circuit, fuel shut-off valve P0006 Fuel shut-off valve control – circuit low Wiring short to ground, fuel shut-off valve P0007 Fuel shut-off valve control – circuit high Wiring short to positive, fuel shut-off valve P0008 Engine position system, bank 1 – performance Mechanical fault P0009 Engine position system, bank 2 – performance Mechanical fault P0010 Camshaft position (CMP) actuator, intake/left/front, bank 1 – circuit malfunction Wiring, CMP actuator, ECM P0011 Camshaft position (CMP), intake/left/front, bank 1 – timing over-advanced/system performance Valve timing, engine mechanical fault, CMP actuator P0012 Camshaft position (CMP), intake/left/front, bank 1 – timing over-retarded Valve timing, engine mechanical fault, CMP actuator P0013 Camshaft position (CMP) actuator, intake/left/front, bank 1 – circuit malfunction Wiring, CMP actuator, ECM P0014 Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 – timing over-advanced/system performance Valve timing, engine mechanical fault, CMP actuator P0015 Camshaft position (CMP) actuator, exhaust/right/rear, bank 1 – timing over-retarded Valve timing, engine mechanical fault, CMP actuator P0016 Crankshaft position/camshaft position, bank 1 sensor A – correlation Wiring, CKP sensor, CMP sensor, mechanical fault P0017 Crankshaft position/camshaft position, bank 1 sensor B – correlation Wiring, CKP sensor, CMP sensor, mechanical fault P0018 Crankshaft position/camshaft position, bank 2 sensor A – correlation Wiring, CKP sensor, CMP sensor, mechanical fault P0019 Crankshaft position/camshaft position, bank 2 sensor B – correlation Wiring, CKP sensor, CMP sensor, mechanical fault P0020 Camshaft position (CMP) actuator, intake/left/front, bank 2 – circuit malfunction Wiring, CMP actuator, ECM P0021 Camshaft position (CMP), intake/left/front, bank 2 – timing over-advanced/system performance Valve timing, engine mechanical fault, CMP actuator P0022 Camshaft position (CMP), intake/left/front, bank 2 – timing over-retarded Valve timing, engine mechanical fault, CMP actuator P0023 Camshaft position (CMP) actuator, exhaust/right/rear, bank 2 – circuit malfunction Wiring, CMP actuator, ECM P0024 Camshaft position (CMP), exhaust/right/rear, bank 2 – timing over-advanced/system performance Valve timing, engine mechanical fault, CMP actuator P0025 Camshaft position (CMP), exhaust/right/rear, bank 2 – timing over-retarded Valve timing, engine mechanical fault, CMP actuator P0026 Intake valve control solenoid circuit, bank 1 – range/performance Wiring, intake valve control solenoid P0027 Exhaust valve control solenoid circuit, bank 1 – range/performance Wiring, exhaust valve control solenoid P0028 Intake valve control solenoid circuit, bank 2 – range/performance Wiring, intake valve control solenoid P0029 Exhaust valve control solenoid circuit, bank 2 – range/performance Wiring, exhaust valve control solenoid P0030 Heated oxygen sensor (HO2S) 1, bank 1, heater control – circuit malfunction Wiring, HO2S, ECM P0031 Heated oxygen sensor (HO2S) 1, bank 1, heater control – circuit low Wiring short to ground, HO2S, ECM P0032 Heated oxygen sensor (HO2S) 1, bank 1, heater control – circuit high Wiring short to positive, HO2S, ECM P0033 Turbocharger (TC) wastegate regulating valve – circuit malfunction Wiring, TC wastegate regulating valve, ECM P0034 Turbocharger (TC) wastegate regulating valve – circuit low Wiring short to ground, TC wastegate regulating valve, ECM P0035 Turbocharger (TC) wastegate regulating valve – circuit high Wiring short to positive, TC wastegate regulating valve, ECM P0036 Heated oxygen sensor (HO2S) 2, bank 1, heater control – circuit malfunction Wiring, HO2S, ECM P0037 Heated oxygen sensor (HO2S) 2, bank 1, heater control – circuit low Wiring short to ground, HO2S, ECM P0038 Heated oxygen sensor (HO2S) 2, bank 1, heater control – circuit high Wiring short to positive, HO2S, ECM P0039 Turbo/super charger bypass valve, control circuit– range/performance Wiring, bypass valve P0040 Oxygen sensor signals swapped, bank 1 sensor 1/bank 2 sensor 1 Wiring P0041 Oxygen sensor signals swapped, bank 1 sensor 2/bank 2 sensor 2 Wiring P0042 Heated oxygen sensor (HO2S) 3, bank 1, heater control – circuit malfunction Wiring, HO2S, ECM P0043 Heated oxygen sensor (HO2S) 3, bank 1, heater control – circuit low Wiring short to ground, HO2S, ECM P0044 Heated oxygen sensor (HO2S) 3, bank 1, heater control – circuit high Wiring short to positive, HO2S, ECM P0045 Turbo/super charger boost control solenoid – circuit open Wiring, boost control solenoid P0046 Turbo/super charger boost control solenoid – circuit range/performance Wiring, boost control solenoid, mechanical fault P0047 Turbo/super charger boost control solenoid – circuit low Wiring short to ground, boost control solenoid P0048 Turbo/super charger boost control solenoid – circuit high Wiring short to positive, boost control solenoid P0049 Turbo/super charger turbine – over-speed Mechanical fault P0050 Heated oxygen sensor (HO2S) 1, bank 2, heater control – circuit malfunction Wiring, HO2S, ECM P0051 Heated oxygen sensor (HO2S) 1, bank 2, heater control – circuit low Wiring short to ground, HO2S, ECM P0052 Heated oxygen sensor (HO2S) 1, bank 2, heater control – circuit high Wiring short to positive, HO2S, ECM P0053 Heated oxygen sensor (HO2S), bank 1, sensor 1 – heater resistance Wiring, HO2S P0054 Heated oxygen sensor (HO2S), bank 1, sensor 2 – heater resistance Wiring, HO2S P0055 Heated oxygen sensor (HO2S), bank 1, sensor 3 – heater resistance Wiring, HO2S P0056 Heated oxygen sensor (HO2S) 2, bank 2, heater control – circuit malfunction Wiring, HO2S, ECM P0057 Heated oxygen sensor (HO2S) 2, bank 2, heater control – heater circuit low Wiring short to ground, HO2S, ECM P0058 Heated oxygen sensor (HO2S) 2, bank 2, heater control – circuit high Wiring short to positive, HO2S, ECM P0059 Heated oxygen sensor (HO2S), bank 2, sensor 1 – heater resistance Wiring, HO2S P0060 Heated oxygen sensor (HO2S), bank 2, sensor 2 – heater resistance Wiring, HO2S P0061 Heated oxygen sensor (HO2S), bank 2, sensor 3 – heater resistance Wiring, HO2S P0062 Heated oxygen sensor (HO2S) 3, bank 2, heater control – circuit malfunction Wiring, HO2S, ECM P0063 Heated oxygen sensor (HO2S) 3, bank 2, heater control – circuit low Wiring short to ground, HO2S, ECM P0064 Heated oxygen sensor (HO2S) 3, bank 2, heater control – circuit high Wiring short to positive, HO2S, ECM P0065 Air assisted injector – range/performance problem Air assisted injector P0066 Air assisted injector – circuit malfunction/circuit low Wiring short to ground, air assisted injector, ECM P0067 Air assisted injector – circuit high Wiring short to positive, air assisted injector, ECM P0068 Manifold pressure (MAP) sensor/Mass air flow (MAF) sensor – throttle position correlation Wiring, MAP sensor, MAF sensor, mechanical fault P0069 Manifold pressure (MAP) sensor – barometric pressure correlation MAF sensor, mechanical fault P0070 Outside air temperature sensor – circuit malfunction Wiring, outside air temperature sensor, ECM P0071 Outside air temperature sensor – range/performance problem Outside air temperature sensor P0072 Outside air temperature sensor – low input Wiring, short to ground, outside air temperature sensor, ECM P0073 Outside air temperature sensor – high input Wiring, short to positive, outside air temperature sensor, ECM P0074 Outside air temperature sensor – circuit intermittent Wiring, poor connection, outside air temperature sensor, ECM P0075 Intake valve control solenoid, bank 1 – circuit malfunction Wiring, intake valve control solenoid, ECM P0076 Intake valve control solenoid, bank 1 – circuit low Wiring short to ground, intake valve control solenoid, ECM P0077 Intake valve control solenoid, bank 1 – circuit high Wiring short to positive, intake valve control solenoid, ECM P0078 Exhaust valve control solenoid, bank 1 – circuit malfunction Wiring, exhaust valve control solenoid, ECM P0079 Exhaust valve control solenoid, bank 1 – circuit low Wiring short to ground, exhaust valve control solenoid, ECM P0080 Exhaust valve control solenoid, bank 1 – circuit high Wiring short to positive, exhaust valve control solenoid, ECM P0081 Intake valve control solenoid, bank 2 – circuit malfunction Wiring, intake valve control solenoid, ECM P0082 Intake valve control solenoid, bank 2 – circuit low Wiring short to ground, intake valve control solenoid, ECM P0083 Intake valve control solenoid, bank 2 – circuit high Wiring short to positive, intake valve control solenoid, ECM P0084 Exhaust valve control solenoid, bank 2 – circuit malfunction Wiring, exhaust valve control solenoid, ECM P0085 Exhaust valve control solenoid, bank 2 – circuit low Wiring short to ground, exhaust valve control solenoid, ECM P0086 Exhaust valve control solenoid, bank 2 – circuit high Wiring short to positive, exhaust valve control solenoid, ECM P0087 Fuel rail/system pressure – too low Fuel pump, fuel pressure regulator, fuel supply pipe blockage, mechanical fault P0088 Fuel rail/system pressure – too high Fuel pump, fuel pressure regulator, fuel return pipe blockage, mechanical fault P0089 Fuel pressure regulator – performance problem Fuel pressure regulator, mechanical fault P0090 Fuel metering solenoid – open circuit Wiring open circuit, fuel metering solenoid, ECM P0091 Fuel metering solenoid – short to ground Wiring short to ground, fuel metering solenoid, ECM P0092 Fuel metering solenoid – short to positive Wiring short to positive, fuel metering solenoid, ECM P0093 Fuel system leak detected – large leak Wiring, fuel pressure sensor, mechanical fault P0094 Fuel system leak detected – small leak Wiring, fuel pressure sensor, mechanical fault P0095 Intake air temperature (IAT) sensor 2 – circuit malfunction Wiring, poor connection, IAT sensor, ECM P0096 Intake air temperature (IAT) sensor 2 – circuit range/performance Wiring, poor connection, IAT sensor, ECM 37 P0097 Intake air temperature (IAT) sensor 2 – circuit low input Wiring short to ground, IAT sensor, ECM P0098 Intake air temperature (IAT) sensor 2 – circuit high input Wiring short to positive, IAT sensor, ECM P0099 Intake air temperature (IAT) sensor 2 – circuit intermittent/erratic Wiring, poor connection, IAT sensor, ECM P0100 Mass air flow (MAF) sensor/volume air flow (VAF) sensor – circuit malfunction Wiring, MAF/VAF sensor, ECM P0101 Mass air flow (MAF) sensor/volume air flow (VAF) sensor – range/performance problem Intake leak/blockage, MAF/VAF sensor P0102 Mass air flow (MAF) sensor/volume air flow (VAF) sensor – low input Wiring short to ground, MAF/VAF sensor, ECM P0103 Mass air flow (MAF) sensor/volume air flow (VAF) sensor – high input Wiring short to positive, MAF/VAF sensor, ECM P0104 Mass air flow (MAF) sensor/volume air flow (VAF) sensor – circuit intermittent Wiring, poor connection, MAF/VAF sensor, ECM P0105 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor – circuit malfunction Wiring, MAP sensor, BARO sensor, ECM P0106 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor – range/performance problem Intake/exhaust leak, wiring, MAP sensor, BARO sensor P0107 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor – low input Wiring short to ground, MAP sensor, BARO sensor, ECM P0108 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor – high input Wiring short to positive, MAP sensor, BARO sensor, ECM P0109 Manifold abosolute pressure (MAP) sensor/barometric pressure (BARO) sensor – circuit intermittent Wiring, poor connection, MAP sensor, BARO sensor, ECM P0110 Intake air temperature (IAT) sensor – circuit malfunction Wiring, IAT sensor, ECM P0111 Intake air temperature (IAT) sensor – range/performance problem IAT sensor P0112 Intake air temperature (IAT) sensor – low input Wiring short to ground, IAT sensor, ECM P0113 Intake air temperature (IAT) sensor – high input Wiring open circuit/short to positive, ground wire defective,IAT sensor, ECM P0114 Intake air temperature (IAT) sensor – circuit intermittent Wiring, poor connection, IAT sensor, ECM P0115 Engine coolant temperature (ECT) sensor – circuit malfunction Wiring, ECT sensor, ECM P0116 Engine coolant temperature (ECT) sensor – range/performance problem Coolant thermostat, poor connection, wiring, ECT sensor P0117 Engine coolant temperature (ECT) sensor – low input Coolant thermostat, wiring short to ground, ECT sensor P0118 Engine coolant temperature (ECT) sensor – high input Coolant thermostat, wiring open circuit/short to positive, ground wire defective, ECT sensor P0119 Engine coolant temperature (ECT) sensor – circuit intermittent Wiring, poor connection, ECT sensor, ECM P0120 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A – circuit malfunction Wiring,TP/APP sensor, ECM Throttle position (TP) switch A/accelerator pedal position (APP) switch A – circuit malfunction Wiring,TP/APP switch, ECM P0121 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A – range/performance problem Accelerator cable adjustment, TP/APP sensor Throttle position (TP) switch A/accelerator pedal position (APP) switch A – range/performance problem Accelerator cable adjustment, TP/APP switch P0122 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A – low input Wiring short to ground,TP/APP sensor, ECM Throttle position (TP) switch A/accelerator pedal position (APP) switch A – low input Wiring short to ground,TP/APP switch, ECM P0123 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A – high input Wiring short to positive,TP/APP sensor, ECM Throttle position (TP) switch A/accelerator pedal position (APP) switch A – high input Wiring short to positive,TP/APP switch, ECM P0124 Throttle position (TP) sensor A/accelerator pedal position (APP) sensor A – circuit intermittent Wiring, poor connection, TP/APP sensor, ECM Throttle position (TP) switch A/accelerator pedal position (APP) switch A – circuit intermittent Wiring, poor connection, TP/APP switch, ECM P0125 Insufficient coolant temperature for closed loop fuel control Wiring, cooling system, coolant thermostat, ECT sensor P0126 Insufficient coolant temperature for stable operation Wiring, cooling system, coolant thermostat, ECT sensor P0127 Intake air temperature – too high Wiring short to ground, IAT sensor 2, mechanical fault, ECM P0128 Coolant thermostat – coolant temp below thermostat regulating temperature Mechanical fault P0129 Barometric pressure – too low Wiring, BARO sensor, mechanical fault P0130 Heated oxygen sensor (HO2S) 1, bank 1 – circuit malfunction Heating inoperative, poor connection, wiring, HO2S Oxygen sensor (O2S) 1, bank 1 – circuit malfunction Wiring, O2S, ECM P0131 Heated oxygen sensor (HO2S) 1, bank 1 – low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 1, bank 1 – low voltage Exhaust leak,wiring short to ground, O2S, ECM P0132 Heated oxygen sensor (HO2S) 1, bank 1 – high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 1, bank 1 – high voltage Wiring short to positive, O2S, ECM P0133 Heated oxygen sensor (HO2S) 1, bank 1 – slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 1, bank 1 – slow response Wiring, O2S P0134 Heated oxygen sensor (HO2S) 1, bank 1 – no acitivty detected Wiring open circuit, heating inoperative, HO2S Oxygen sensor (O2S) 1, bank 1 – no activity detected Wiring, O2S P0135 Heated oxygen sensor (HO2S) 1, bank 1, heater control – circuit malfunction Fuse, wiring, HO2S, ECM P0136 Heated oxygen sensor (HO2S) 2, bank 1 – circuit malfunction Heating inoperative, wiring, HO2S, ECM Oxygen sensor (O2S) 2, bank 1 – circuit malfunction Wiring, O2S, ECM P0137 Heated oxygen sensor (HO2S) 2, bank 1 – low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 2, bank 1 – low voltage Exhaust leak,wiring short to ground, O2S, ECM P0138 Heated oxygen sensor (HO2S) 2, bank 1 – high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 2, bank 1 – high voltage Wiring short to positive, O2S, ECM P0139 Heated oxygen sensor (HO2S) 2, bank 1 – slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 2, bank 1 – slow response Wiring, O2S P0140 Heated oxygen sensor (HO2S) 2, bank 1 – no acitivty detected Wiring, heating inoperative, HO2S, ECM Oxygen sensor (O2S) 2, bank 1 – no activity detected Wiring, O2S, ECM P0141 Heated oxygen sensor (HO2S) 2, bank 1, heater control – circuit malfunction Wiring, HO2S, ECM P0142 Heated oxygen sensor (HO2S) 3, bank 1 – circuit malfunction Wiring, HO2S, ECM P0143 Heated oxygen sensor (HO2S) 3, bank 1 – low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 3, bank 1 – low voltage Exhaust leak,wiring short to ground, O2S, ECM P0144 Heated oxygen sensor (HO2S) 3, bank 1 – high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 3, bank 1 – high voltage Wiring short to positive, O2S, ECM P0145 Heated oxygen sensor (HO2S) 3, bank 1 – slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 3, bank 1 – slow response Wiring, O2S P0146 Heated oxygen sensor (HO2S) 3, bank 1 – no acitivty detected Wiring, HO2S, ECM Oxygen sensor (O2S) 3, bank 1 – no activity detected Wiring, O2S, ECM P0147 Heated oxygen sensor (HO2S) 3, bank 1, heater control – circuit malfunction Wiring, HO2S, ECM P0148 Fuel delivery error Fuel pump/fuel injection pump P0149 Fuel timing error Fuel pump/fuel injection pump P0150 Heated oxygen sensor (HO2S) 1, bank 2 – circuit malfunction Wiring, HO2S, ECM Oxygen sensor (O2S) 1, bank 2 – circuit malfunction Wiring, O2S, ECM P0151 Heated oxygen sensor (HO2S) 1, bank 2 – low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 1, bank 2 – low voltage Exhaust leak,wiring short to ground, O2S, ECM P0152 Heated oxygen sensor (HO2S) 1, bank 2 – high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 1, bank 2 – high voltage Wiring short to positive, O2S, ECM P0153 Heated oxygen sensor (HO2S) 1, bank 2 – slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 1, bank 2 – slow response Wiring, O2S P0154 Heated oxygen sensor (HO2S) 1, bank 2 – no acitivty detected Wiring, HO2S, ECM Oxygen sensor (O2S) 1, bank 2 – no activity detected Wiring, O2S, ECM P0155 Heated oxygen sensor (HO2S) 1, bank 2, heater control – circuit malfunction Wiring, HO2S, ECM P0156 Heated oxygen sensor (HO2S) 2, bank 2 – circuit malfunction Heating inoperative, wiring, HO2S, ECM Oxygen sensor (O2S) 2, bank 2 – circuit malfunction Wiring, O2S, ECM P0157 Heated oxygen sensor (HO2S) 2, bank 2 – low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 2, bank 2 – low voltage Exhaust leak,wiring short to ground, O2S, ECM P0158 Heated oxygen sensor (HO2S) 2, bank 2 – high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 2, bank 2 – high voltage Wiring short to positive, O2S, ECM P0159 Heated oxygen sensor (HO2S) 2, bank 2 – slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 2, bank 2 – slow response Wiring, O2S P0160 Heated oxygen sensor (HO2S) 2, bank 2 – no acitivty detected Wiring, HO2S, ECM Oxygen sensor (O2S) 2, bank 2 – no activity detected Wiring, O2S, ECM P0161 Heated oxygen sensor (HO2S) 2, bank 2, heater control – circuit malfunction Wiring, HO2S, ECM P0162 Heated oxygen sensor (HO2S) 3, bank 2 – circuit malfunction Wiring, HO2S, ECM Oxygen sensor (O2S) 3, bank 2 – circuit malfunction Wiring, O2S, ECM P0163 Heated oxygen sensor (HO2S) 3, bank 2 – low voltage Exhaust leak, wiring short to ground, HO2S, ECM Oxygen sensor (O2S) 3, bank 2 – low voltage Exhaust leak, wiring short to ground, O2S, ECM P0164 Heated oxygen sensor (HO2S) 3, bank 2 – high voltage Wiring short to positive, HO2S, ECM Oxygen sensor (O2S) 3, bank 2 – high voltage Wiring short to positive, O2S, ECM P0165 Heated oxygen sensor (HO2S) 3, bank 2 – slow response Heating inoperative, wiring, HO2S Oxygen sensor (O2S) 3, bank 2 – slow response Wiring, O2S P0166 Heated oxygen sensor (HO2S) 3, bank 2 – no acitivty detected Wiring, HO2S, ECM Oxygen sensor (O2S) 3, bank 2 – no activity detected Wiring, O2S, ECM P0167 Heated oxygen sensor (HO2S) 3, bank 2, heater control – circuit malfunction Wiring, HO2S, ECM P0168 Fuel temperature – too high Wiring, fuel temperature sensor, mechanical fault P0169 Incorrect fuel composition Wiring, fuel temperature sensor, mechanical fault P0170 Fuel trim (FT), bank 1 – malfunction Intake leak, AIR system, fuel pressure/pump, injector(s), EVAP canister purge valve, HO2S P0171 System too lean, bank 1 Intake/exhaust leak, AIR system, MAF/VAF sensor, fuel pressure/pump, injector(s), HO2S P0172 System too rich, bank 1 Intake blocked, EVAP canister purge valve, fuel pressure,EGR system, injector(s), HO2S P0173 Fuel trim (FT), bank 2 – malfunction Intake leak, AIR system, fuel pressure/pump, injector(s), EVAP canister purge valve, HO2S P0174 System too lean, bank 2 Intake/exhaust leak, fuel pressure/pump, injector(s), AIR system, hose connection(s) P0175 System too rich, bank 2 Intake blocked, EVAP canister purge valve, fuel pressure, EGR system, injector(s), HO2S P0176 Fuel composition sensor – circuit malfunction Wiring, fuel composition sensor, ECM P0177 Fuel composition sensor – range/performance problem Fuel composition sensor P0178 Fuel composition sensor – low input Wiring short to ground, fuel composition sensor, ECM P0179 Fuel composition sensor – high input Wiring short to positive, fuel composition sensor, ECM P0180 Fuel temperature sensor A – circuit malfunction Wiring, fuel temperature sensor, ECM P0181 Fuel temperature sensor A – range/performance problem Fuel temperature sensor P0182 Fuel temperature sensor A – low input Wiring short to ground, fuel temperature sensor, ECM P0183 Fuel temperature sensor A – high input Wiring short to positive, fuel temperature sensor, ECM P0184 Fuel temperature sensor A – circuit intermittent Wiring, poor connection, fuel temperature sensor, ECM P0185 Fuel temperature sensor B – circuit malfunction Wiring, fuel temperature sensor, ECM P0186 Fuel temperature sensor B – range/performance problem Fuel temperature sensor P0187 Fuel temperature sensor B – low input Wiring short to ground, fuel temperature sensor, ECM P0188 Fuel temperature sensor B – high input Wiring short to positive, fuel temperature sensor, ECM P0189 Fuel temperature sensor B – circuit intermittent Wiring, poor connection, fuel temperature sensor, ECM P0190 Fuel rail pressure (FRP) sensor – circuit malfunction Wiring, fuel rail pressure sensor, ECM P0191 Fuel rail pressure (FRP) sensor – range/performance problem Wiring, FRP sensor P0192 Fuel rail pressure (FRP) sensor – low input Wiring short to ground, FRP sensor P0193 Fuel rail pressure (FRP) sensor – high input Wiring short to positive, FRP sensor P0194 Fuel rail pressure (FRP) sensor – circuit intermittent Wiring, poor connection, FRP sensor P0195 Engine oil temperature (EOT) sensor – circuit malfunction Wiring, EOT sensor, ECM P0196 Engine oil temperature (EOT) sensor – range/performance problem EOT sensor P0197 Engine oil temperature (EOT) sensor – low input Wiring short to ground, EOT sensor P0198 Engine oil temperature (EOT)) sensor – high input Wiring short to positive, EOT sensor P0199 Engine oil temperature (EOT) sensor – circuit intermittent Wiring, poor connection, EOT sensor, ECM P0200 Injector – circuit malfunction Wiring, injector, ECM P0201 Injector 1 – circuit malfunction Wiring, injector, ECM P0202 Injector 2 – circuit malfunction Wiring, injector, ECM P0203 Injector 3 – circuit malfunction Wiring, injector, ECM P0204 Injector 4 – circuit malfunction Wiring, injector, ECM P0205 Injector 5 – circuit malfunction Wiring, injector, ECM P0206 Injector 6 – circuit malfunction Wiring, injector, ECM P0207 Injector 7 – circuit malfunction Wiring, injector, ECM P0208 Injector 8 – circuit malfunction Wiring, injector, ECM P0209 Injector 9 – circuit malfunction Wiring, injector, ECM P0210 Injector 10 – circuit malfunction Wiring, injector, ECM P0211 Injector 11 – circuit malfunction Wiring, injector, ECM P0212 Injector 12 – circuit malfunction Wiring, injector, ECM P0213 Cold start injector 1 – circuit malfunction Wiring, cold start injector, ECM P0214 Cold start injector 2 – circuit malfunction Wiring, cold start injector, ECM P0215 Fuel shut-off solenoid – circuit malfunction Wiring, fuel shut-off solenoid, ECM P0216 Fuel injection timing control – circuit malfunction Wiring, fuel injection timing control solenoid, ECM P0217 Engine over temperature condition Wiring, cooling system, coolant thermostat, ECT sensor P0218 Transmission over temperature condition Wiring, TFT sensor, ECM P0219 Engine over speed condition Incorrect gear change P0220 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B – circuit malfunction Wiring, TP/APP sensor, ECM Throttle position (TP) switch B/accelerator pedal position (APP) switch B – circuit malfunction Wiring, TP/APP switch, ECM P0221 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B – range/performance problem Accelerator cable adjustment, TP/APP sensor Throttle position (TP) switch B/accelerator pedal position (APP) switch B – range/performance problem Accelerator cable adjustment, TP/APP switch P0222 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B – low input Wiring short to ground, TP/APP sensor, ECM Throttle position (TP) switch B/accelerator pedal position (APP) switch B – low input Wiring short to ground, TP/APP switch, ECM P0223 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B – high input Wiring short to positive, TP/APP sensor, ECM Throttle position (TP) switch B/accelerator pedal position (APP) switch B – high input Wiring short to positive, TP/APP switch, ECM P0224 Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B – circuit intermittent Wiring, poor connection, TP/APP sensor, ECM Throttle position (TP) switch B/accelerator pedal position (APP) switch B – circuit intermittent Wiring, poor connection, TP/APP switch, ECM P0225 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C – circuit malfunction Wiring, TP/APP sensor, ECM Throttle position (TP) switch C/accelerator pedal position (APP) switch C – circuit malfunction Wiring, TP/APP switch, ECM P0226 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C – range/performance problem Accelerator cable adjustment, TP/APP sensor Throttle position (TP) switch C/accelerator pedal position (APP) switch C – range/performance problem Accelerator cable adjustment, TP/APP switch P0227 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C – low input Wiring short to ground, TP/APP sensor, ECM Throttle position (TP) switch C/accelerator pedal position (APP) switch C – low input Wiring short to ground, TP/APP switch, ECM P0228 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C – high input Wiring short to positive, TP/APP sensor, ECM Throttle position (TP) switch C/accelerator pedal position (APP) switch C – high input Wiring short to positive, TP/APP switch, ECM P0229 Throttle position (TP) sensor C/accelerator pedal position (APP) sensor C – circuit intermittent Wiring, poor connection, TP/APP sensor, ECM Throttle position (TP) switch C/accelerator pedal position (APP) switch C – circuit intermittent Wiring, poor connection, TP/APP switch, ECM P0230 Fuel pump relay – circuit malfunction Wiring, fuel pump relay, ECM P0231 Fuel pump relay – circuit low Wiring short to ground, fuel pump relay, ECM P0232 Fuel pump relay – circuit high Wiring short to positive, fuel pump relay, ECM P0233 Fuel pump relay – circuit intermittent Wiring, poor connection, fuel pump relay, ECM P0234 Engine boost condition – limit exceeded Hose connection(s), wiring, TC wastergate regulating valve, TC wastegate P0235 Engine boost condition – limit not reached Hose connection(s), wiring, TC wastergate regulating valve, TC wastegate, TC P0236 Manifold absolute pressure (MAP) sensor A, TC system – range/performance problem Intake/exhaust leak, hose connection(s), MAP sensor P0237 Manifold absolute pressure (MAP) sensor A, TC system – low input Wiring short to ground, MAP sensor, ECM P0238 Manifold absolute pressure (MAP) sensor A, TC system – high input Wiring short to positive, MAP sensor, ECM P0239 Manifold absolute pressure (MAP) sensor B, TC system – circuit malfunction Wiring, MAP sensor, ECM P0240 Manifold absolute pressure (MAP) sensor B, TC system – range/performance problem Intake/exhaust leak, hose connection(s), MAP sensor P0241 Manifold absolute pressure (MAP) sensor B, TC system – low input Wiring short to ground, MAP sensor, ECM P0242 Manifold absolute pressure (MAP) sensor B, TC system – high input Wiring short to positive, MAP sensor, ECM P0243 Turbocharger (TC) wastegate regulating valve A – circuit malfunction Wiring, TC wastegate regulating valve, ECM P0244 Turbocharger (TC) wastegate regulating valve A – range/performance problem TC wastegate regulating valve P0245 Turbocharger (TC) wastegate regulating valve A – circuit low Wiring short to ground, TC wastegate regulating valve, ECM P0246 Turbocharger (TC) wastegate regulating valve A – circuit high Wiring short to positive, TC wastegate regulating valve, ECM P0247 Turbocharger (TC) wastegate regulating valve B – circuit malfunction Wiring, TC wastegate regulating valve, ECM P0248 Turbocharger (TC) wastegate regulating valve B – range/performance problem TC wastegate regulating valve P0249 Turbocharger (TC) wastegate regulating valve B – circuit low Wiring short to ground, TC wastegate regulating valve, ECM P0250 Turbocharger (TC) wastegate regulating valve B – circuit high Wiring short to positive, TC wastegate regulating valve, ECM P0251 Injection pump A, rotor/cam – circuit malfunction Wiring, injection pump, ECM P0252 Injection pump A, rotor/cam – range/performance problem Injection pump P0253 Injection pump A, rotor/cam – circuit low Wiring short to ground, injection pump, ECM P0254 Injection pump A, rotor/cam – circuit high Wiring short to positive, injection pump, ECM P0255 Injection pump A, rotor/cam – circuit intermittent Wiring, poor connection, injection pump, ECM P0256 Injection pump B, rotor/cam – circuit malfunction Wiring, injection pump, ECM P0257 Injection pump B, rotor/cam – range/performance problem Injection pump P0258 Injection pump B, rotor/cam – circuit low Wiring short to ground, injection pump, ECM P0259 Injection pump B, rotor/cam – circuit high Wiring short to positive, injection pump, ECM P0260 Injection pump B, rotor/cam – circuit intermittent Wiring, poor connection, injection pump, ECM P0261 Injector 1 – circuit low Wiring short to ground, injector, ECM P0262 Injector 1 – circuit high Wiring short to positive, injector, ECM P0263 Cylinder 1 – contribution/balance fault Wiring, fuel system, ECM P0264 Injector 2 – circuit low Wiring short to ground, injector, ECM P0265 Injector 2 – circuit high Wiring short to positive, injector, ECM P0266 Cylinder 2 – contribution/balance fault Wiring, fuel system, ECM P0267 Injector 3 – circuit low Wiring short to ground, injector, ECM P0268 Injector 3 – circuit high Wiring short to positive, injector, ECM P0269 Cylinder 3 – contribution/balance fault Wiring, fuel system, ECM P0270 Injector 4 – circuit low Wiring short to ground, injector, ECM P0271 Injector 4 – circuit high Wiring short to positive, injector, ECM P0272 Cylinder 4 – contribution/balance fault Wiring, fuel system, ECM P0273 Injector 5 – circuit low Wiring short to ground, injector, ECM P0274 Injector 5 – circuit high Wiring short to positive, injector, ECM P0275 Cylinder 5 – contribution/balance fault Wiring, fuel system, ECM P0276 Injector 6 – circuit low Wiring short to ground, injector, ECM P0277 Injector 6 – circuit high Wiring short to positive, injector, ECM P0278 Cylinder 6 – contribution/balance fault Wiring, fuel system, ECM P0279 Injector 7 – circuit low Wiring short to ground, injector, ECM P0280 Injector 7 – circuit high Wiring short to positive, injector, ECM P0281 Cylinder 7 – contribution/balance fault Wiring, fuel system, ECM P0282 Injector 8 – circuit low Wiring short to ground, injector, ECM P0283 Injector 8 – circuit high Wiring short to positive, injector, ECM P0284 Cylinder 8 – contribution/balance fault Wiring, fuel system, ECM P0285 Injector 9 – circuit low Wiring short to ground, injector, ECM P0286 Injector 9 – circuit high Wiring short to positive, injector, ECM P0287 Cylinder 9 – contribution/balance fault Wiring, fuel system, ECM P0288 Injector 10 – circuit low Wiring short to ground, injector, ECM P0289 Injector 10 – circuit high Wiring short to positive, injector, ECM P0290 Cylinder 10 – contribution/balance fault Wiring, fuel system, ECM P0291 Injector 11 – circuit low Wiring short to ground, injector, ECM P0292 Injector 11 – circuit high Wiring short to positive, injector, ECM P0293 Cylinder 11 – contribution/balance fault Wiring, fuel system, ECM P0294 Injector 12 – circuit low Wiring short to ground, injector, ECM P0295 Injector 12 – circuit high Wiring short to positive, injector, ECM P0296 Cylinder 12 – contribution/balance fault Wiring, fuel system, ECM P0297 Vehicle over-speed condition Wiring, VSS, mechanical fault P0298 Engine oil temperature – too high Wiring, EOT sensor, mechanical fault P0299 Turbo/super charger – low boost Mechanical fault P0300 Random/multiple cylinder(s) – misfire detected Spark plug(s), HT lead(s), injector(s), ignition coil(s),low compression, wiring P0301 Cylinder 1 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0302 Cylinder 2 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0303 Cylinder 3 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0304 Cylinder 4 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0305 Cylinder 5 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0306 Cylinder 6 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0307 Cylinder 7 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0308 Cylinder 8 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0309 Cylinder 9 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0310 Cylinder 10 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0311 Cylinder 11 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0312 Cylinder 12 – misfire detected Engine mechanical fault, wiring, ignitiion/fuel system, injector, ECT/MAF sensor, ECM P0313 Misfire detected – low fuel level Fuel system, mechanical fault P0314 Single cylinder misfire – cylinder not specified Engine mechanical fault, wiring, ignition/fuel system, injector P0315 Crankshaft position system – variation not learned Engine mechanical fault, wiring P0316 Misfire dectected during startup – first 1000 revolutions Engine mechanical fault, wiring, ignition/fuel system, injector P0317 Rough road hardware not present Wiring, ECM P0318 Rough road sensor signal A – circuit malfunction Wiring, rough road sensor A, mechanical fault P0319 Rough road sensor signal B – circuit malfunction Wiring, rough road sensor B, mechanical fault P0320 Crankshaft position (CKP) sensor/engine speed (RPM) sensor – circuit malfunction WiringCKP/RPM sensor, ECM P0321 Crankshaft position (CKP) sensor/engine speed (RPM) sensor – range/performance problem Air gap, metal particle contamination, insecure sensor/rotor, wiring, CKP/RPM sensor P0322 Crankshaft position (CKP) sensor/engine speed (RPM) sensor – no signal Wiring, CKP/RPM sensor, ECM P0323 Crankshaft position (CKP) sensor/engine speed (RPM) sensor – circuit intermittent Wiring, poor connection, CKP/RPM sensor, ECM P0324 Knock control system error Wiring, poor connection, KS, ECM P0325 Knock sensor (KS) 1, bank 1 – circuit malfunction Wiring, poor connection, KS P0326 Knock sensor (KS) 1, bank 1 – range/performance problem Wiring, KS incorrectly tightened, KS P0327 Knock sensor (KS) 1, bank 1 – low input Insecure KS, poor connection, wiring short to ground,incorrectly tightened, KS, ECM P0328 Knock sensor (KS) 1, bank 1 – high input Wiring short to positive, KS incorrectly tightened, KS, ECM P0329 Knock sensor (KS) 1, bank 1 – circuit intermittent Wiring, poor connection, KS, ECM P0330 Knock sensor (KS) 2, bank 2 – circuit malfunction Wiring, KS, ECM P0331 Knock sensor (KS) 2, bank 2 – range/performance problem Wiring, KS incorrectly tightened, KS P0332 Knock sensor (KS) 2, bank 2 – low input Insecure KS, poor connection, wiring short to ground,incorrectly tightened, KS, ECM P0333 Knock sensor (KS) 2, bank 2 – high input Wiring short to positive, KS incorrectly tightened, KS, ECM P0334 Knock sensor (KS) 2, bank 2 – circuit intermittent Wiring, poor connection, KS, ECM P0335 Crankshaft position (CKP) sensor – circuit malfunction Wiring, CKP sensor, ECM P0336 Crankshaft position (CKP) sensor – range/performance problem Insecure sensor/rotor, air gap, wiring, CKP sensor P0337 Crankshaft position (CKP) sensor – low input Wiring short to ground, CKP sensor, ECM P0338 Crankshaft position (CKP) sensor – high input Wiring short to positive, CKP sensor, ECM P0339 Crankshaft position (CKP) sensor– circuit intermittent Wiring, poor connection, CKP sensor, ECM P0340 Camshaft position (CMP) sensor A, bank 1 – circuit malfunction Wiring, CMP sensor, ECM P0341 Camshaft position (CMP) sensor A, bank 1 – range/performance problem Insecure sensor/rotor, air gap, wiring, CMP sensor P0342 Camshaft position (CMP) sensor A, bank 1 – low input Wiring short to ground, CMP sensor, ECM P0343 Camshaft position (CMP) sensor A, bank 1 – high input Wiring short to positive, CMP sensor, ECM P0344 Camshaft position (CMP) sensor A, bank 1– circuit intermittent Wiring, poor connection, CMP sensor, ECM P0345 Camshaft position (CMP) sensor A, bank 2 – circuit malfunction Wiring, CMP sensor, ECM P0346 Camshaft position (CMP) sensor A, bank 2 – range/performance problem Insecure sensor/rotor, air gap, wiring, CMP sensor P0347 Camshaft position (CMP) sensor A, bank 2 – low input Wiring short to ground, CMP sensor, ECM P0348 Camshaft position (CMP) sensor A, bank 2 – high input Wiring short to positive, CMP sensor, ECM P0349 Camshaft position (CMP) sensor A, bank 2– circuit intermittent Wiring, poor connection, CMP sensor, ECM P0350 Ignitiion coil, primary/secordary – circuit malfunction Wiring, ignition coil, ECM P0351 Ignitiion coil A, primary/secordary – circuit malfunction Wiring, ignition coil, ECM P0352 Ignitiion coil B, primary/secordary – circuit malfunction Wiring, ignition coil, ECM P0353 Ignitiion coil C, primary/secordary – circuit malfunction Wiring, ignition coil, ECM P0354 Ignitiion coil D, primary/secordary – circuit malfunction Wiring, ignition coil, ECM P0355 Ignitiion coil E, primary/secordary – circuit malfunction Wiring, ignition coil, ECM P0356 Ignitiion coil F, primary/secordary – circuit malfunction Wiring, ignition coil, ECM P0357 Ignitiion coil G, primary/secordary – circuit malfunction Wiring, ignition coil, ECM P0358 Ignitiion coil H, primary/secordary – circuit malfunction Wiring, ignition coil, ECM P0359 Ignitiion coil I, primary/secordary – circuit malfunction Wiring, ignition coil, ECM P0360 Ignitiion coil J, primary/secordary – circuit malfunction Wiring, ignition coil, ECM P0361 Ignitiion coil K, primary/secordary – circuit malfunction Wiring, ignition coil, ECM P0362 Ignitiion coil L, primary/secordary – circuit malfunction Wiring, ignition coil, ECM P0363 Misfire detected – fueling disabled Fuel system, mechanical fault P0365 Camshaft position (CMP) sensor B, bank 1 – circuit malfunction Wiring, poor connection, CMP sensor, ECM P0366 Camshaft position (CMP) sensor B, bank 1 – range/performance problem Wiring, poor connection, CMP sensor P0367 Camshaft position (CMP) sensor B, bank 1 – low input Wiring short to ground, CMP sensor, ECM P0368 Camshaft position (CMP) sensor B, bank 1 – high input Wiring short to positive, CMP sensor, ECM P0369 Camshaft position (CMP) sensor B, bank 1– circuit intermittent Wiring, poor connection, ECM P0370 Timing reference, high resolution signal A – malfunction Wiring, CKP/RPM/CMP sensor, ECM P0371 Timing reference, high resolution signal A – too many pulses Wiring, CKP/RPM/CMP sensor, ECM P0372 Timing reference, high resolution signal A – too few pulses Wiring, CKP/RPM/CMP sensor, ECM P0373 Timing reference, high resolution signal A – intermittent erratic pulses Wiring, poor connection, CKP/RPM/CMP sensor, ECM P0374 Timing reference, high resolution signal A – no pulses Wiring, CKP/RPM/CMP sensor, ECM P0375 Timing reference, high resolution signal B – malfunction Wiring, CKP/RPM/CMP sensor, ECM P0376 Timing reference, high resolution signal B – too many pulses Wiring, CKP/RPM/CMP sensor, ECM P0377 Timing reference, high resolution signal B – too few pulses Wiring, CKP/RPM/CMP sensor, ECM P0378 Timing reference, high resolution signal B – intermittent erratic pulses Wiring, poor connection, CKP/RPM/CMP sensor, ECM P0379 Timing reference, high resolution signal B – no pulses Wiring, CKP/RPM/CMP sensor, ECM P0380 Glow plugs, circuit A – malfunction Wiring, glow plug relay, fuse, glow plugs, ECM P0381 Glow plug warning lamp – circuit malfunction Wiring, glow plug warning lamp, ECM P0382 Glow plugs, circuit B – malfunction Wiring, glow plug relay, fuse, glow plugs, ECM P0385 Crankshaft position (CKP) sensor B – circuit malfunction Wiring, CKP sensor, ECM P0386 Crankshaft position (CKP) sensor B – range/performance problem Insecure sensor/rotor, air gap, wiring, CKP sensor P0387 Crankshaft position (CKP) sensor B – low input Wiring short to ground, CKP sensor, ECM P0388 Crankshaft position (CKP) sensor B – high input Wiring short to positive, CKP sensor, ECM P0389 Crankshaft position (CKP) sensor B – circuit intermittent Wiring, poor connection, CKP sensor, ECM P0390 Camshaft position (CMP) sensor B, bank 2 – circuit malfunction Wiring, poor connection, CMP sensor, ECM P0391 Camshaft position (CMP) sensor B, bank 2 – circuit range/performance problem Wiring, poor connection, CMP sensor P0392 Camshaft position (CMP) sensor B, bank 2 – circuit low input Wiring short to ground, CMP sensor, ECM P0393 Camshaft position (CMP) sensor B, bank 2 – circuit high input Wiring short to positive, CMP sensor, ECM P0394 Camshaft position (CMP) sensor B, bank 2– circuit intermittent Wiring, poor connection, ECM P0400 Exhaust gas recirculation (ERG) system – flow malfunction Hose leak/blockage, basic setting not carried out (if applicable), wiring, EGR valve, EGR solenoid, ECM P0401 Exhaust gas recirculation (ERG) system – insufficient flow detected Hose leak/blockage, basic setting not carried out (if applicable), wiring, EGR valve, EGR solenoid, ECM P0402 Exhaust gas recirculation (ERG) system – excessive flow detected Hose leak/blockage, basic setting not carried out (if applicable), wiring, EGR valve, EGR solenoid, ECM P0403 Exhaust gas recirculation (ERG) system – circuit malfunction Wiring, EGR solenoid, ECM P0404 Exhaust gas recirculation (ERG) system – range/performance problem Hose leak/blockage, wiring, EGR valve/solenoid P0405 Exhaust gas recirculation (ERG) valve position sensor A – low input Wiring short to ground, EGR valve position sensor, ECM P0406 Exhaust gas recirculation (ERG) valve position sensor A – high input Wiring short to positive, EGR valve position sensor, ECM P0407 Exhaust gas recirculation (ERG) valve position sensor B – low input Wiring short to ground, EGR valve position sensor, ECM P0408 Exhaust gas recirculation (ERG) valve position sensor B – high input Wiring short to positive, EGR valve position sensor, ECM P0409 Exhaust gas recirculation (ERG) sensor A – circuit malfunction Wiring, poor connection, EGR sensor, ECM P0410 Secondary air injection (AIR) system – malfunction Wiring, AIR valve, AIR solenoid, ECM P0411 Secondary air injection (AIR) system – incorrect flow detected AIR pump, AIR valve, AIR hose(s) P0412 Secondary air injection (AIR) solenoid A – circuit malfunction Wiring, AIR solenoid, ECM P0413 Secondary air injection (AIR) solenoid A – open circuit Wiring open circuit, AIR solenoid, ECM P0414 Secondary air injection (AIR) solenoid A – short circuit Wiring short circuit, AIR solenoid, ECM P0415 Secondary air injection (AIR) solenoid B – circuit malfunction Wiring, AIR solenoid, ECM P0416 Secondary air injection (AIR) solenoid B – open circuit Wiring open circuit, AIR solenoid, ECM P0417 Secondary air injection (AIR) solenoid B – short circuit Wiring short circuit, AIR solenoid, ECM P0418 Secondary air injection (AIR) pump relay A – circuit malfunction Wiring, AIR pump relay, ECM P0419 Secondary air injection (AIR) pump relay B – circuit malfunction Wiring, AIR pump relay, ECM P0420 Catalytic converter system, bank 1 – efficiency below threshold Catalytic converter, wiring, HO2S 2 P0421 Warm up catalytic converter, bank 1 – efficiency below threshold Catalytic converter, wiring, HO2S 2 P0422 Main catalytic converter, bank 1 – efficiency below threshold Catalytic converter, wiring, HO2S 2 P0423 Heated catalytic converter, bank 1 – efficiency below threshold Catalytic converter, wiring, HO2S 2 P0424 Heated catalytic converter, bank 1 – temperature below threshold Catalytic converter, wiring, HO2S 2 P0425 Catalytic converter temperature sensor, bank 1 Wiring, poor connection, catalytic converter temperature sensor, ECM P0426 Catalytic converter temperature sensor, bank 1 – range/performance Wiring, poor connection, catalytic converter temperature sensor, ECM P0427 Catalytic converter temperature sensor, bank 1 – low input Wiring short to ground, catalytic converter temperature sensor, ECM P0428 Catalytic converter temperature sensor, bank 1 – high input Wiring short to positive, catalytic converter temperature sensor, ECM P0429 Catalytic converter heater, bank 1 – control circuit malfunction Wiring, relay, ECM P0430 Catalytic converter system, bank 2 – efficiency below threshold Catalytic converter, wiring, HO2S 2 P0431 Warm up catalytic converter, bank 2 – efficiency below threshold Catalytic converter, wiring, HO2S 2 P0432 Main catalytic converter, bank 2 – efficiency below threshold Catalytic converter, wiring, HO2S 2 P0433 Heated catalytic converter, bank 2 – efficiency below threshold Catalytic converter, wiring, HO2S 2 P0434 Heated catalytic converter, bank 2 – temperature below threshold Catalytic converter, wiring, HO2S 2 P0435 Catalytic converter temperature sensor, bank 2 Wiring, poor connection, catalytic converter temperature sensor, ECM P0436 Catalytic converter temperature sensor, bank 2 – range/performance Wiring, poor connection, catalytic converter temperature sensor, ECM P0437 Catalytic converter temperature sensor, bank 2 – low input Wiring short to ground, catalytic converter temperature sensor, ECM P0438 Catalytic converter temperature sensor, bank 2 – high input Wiring short to positive, catalytic converter temperature sensor, ECM P0439 Catalytic converter heater, bank 2 – control circuit malfunction Wiring, relay, ECM P0440 Evaporative emission (EVAP) system – malfunction Hose connection(s), intake leak, EVAP canister purge valve P0441 Evaporative emission (EVAP) system – incorrect flow detected Hose connection(s), intake leak, EVAP canister purge valve P0442 Evaporative emission (EVAP) system – small leak detected Hose connection(s), intake leak, EVAP canister, EVAP canister purge valve P0443 Evaporative emission (EVAP) canister purge valve – circuit malfunction Wiring, EVAP canister purge valve, ECM P0444 Evaporative emission (EVAP) canister purge valve – open circuit Wiring open circuit, EVAP canister purge valve, ECM P0445 Evaporative emission (EVAP) canister purge valve – short circuit Wiring short circuit, EVAP canister purge valve, ECM P0446 Evaporative emission (EVAP) system, vent control – circuit malfunction Wiring, EVAP canister purge valve, ECM P0447 Evaporative emission (EVAP) system, vent control – open circuit Wiring open circuit, EVAP canister purge valve, ECM P0448 Evaporative emission (EVAP) system, vent control – short circuit Wiring short circuit, EVAP canister purge valve, ECM P0449 Evaporative emission (EVAP) system, vent valve – circuit malfunction Wiring, EVAP canister purge valve, ECM P0450 Evaporative emission (EVAP) pressure sensor – circuit malfunction Wiring, EVAP pressure sensor, ECM P0451 Evaporative emission (EVAP) pressure sensor – range/performance problem EVAP pressure sensor P0452 Evaporative emission (EVAP) pressure sensor – low input Wiring short to ground, EVAP pressure sensor, ECM P0453 Evaporative emission (EVAP) pressure sensor – high input Wiring short to positive, EVAP pressure sensor, ECM P0454 Evaporative emission (EVAP) pressure sensor – circuit intermittent Wiring, poor connection, EVAP pressure sensor, ECM P0455 Evaporative emission (EVAP) system – large leak detected Hose connection(s), intake leak, EVAP canister, EVAP canister purge valve P0456 Evaporative emission system – very small leak detected Mechanical fault, hose connection(s), EVAP pressure sensor P0457 Evaporative emission system – leak detected (fuel cap loose/off) Mechanical fault, hose connection(s), EVAP pressure sensor P0458 Evaporative emission system, purge control valve – circuit low Wiring short to ground, EVAP valve P0459 Evaporative emission system, purge control valve – circuit high Wiring short to positive, EVAP valve P0460 Fuel tank level sensor – circuit malfunction Wiring, fuel tank level sensor, ECM P0461 Fuel tank level sensor – range/performance problem Wiring, fuel tank level sensor P0462 Fuel tank level sensor – low input Wiring short to ground, fuel tank level sensor, ECM P0463 Fuel tank level sensor – high input Wiring short to positive, fuel tank level sensor, ECM P0464 Fuel tank level sensor – circuit intermittent Wiring, poor connection, fuel tank level sensor, ECM P0465 Evaporative emission (EVAP) canister purge flow sensor – circuit malfunction Wiring, EVAP canister purge flow sensor, ECM P0466 Evaporative emission (EVAP) canister purge flow sensor – range/performance problem EVAP canister purge flow sensor P0467 Evaporative emission (EVAP) canister purge flow sensor – low input Wiring short to ground, EVAP canister purge flow sensor, ECM P0468 Evaporative emission (EVAP) canister purge flow sensor – high input Wiring short to positive, EVAP canister purge flow sensor, ECM P0469 Evaporative emission (EVAP) canister purge flow sensor – circuit intermittent Wiring, poor connection, EVAP canister purge flow sensor, ECM P0470 Exhaust gas pressure sensor – circuit malfunction Wiring, exhaust gas pressure sensor, ECM P0471 Exhaust gas pressure sensor – range/performance problem Exhaust gas pressure sensor P0472 Exhaust gas pressure sensor – low input Wiring short to ground, exhaust gas pressure sensor, ECM P0473 Exhaust gas pressure sensor – high input Wiring short to positive, exhaust gas pressure sensor, ECM P0474 Exhaust gas pressure sensor – circuit intermittent Wiring, poor connection, exhaust gas pressure sensor, ECM P0475 Exhaust gas pressure control valve – circuit malfunction Wiring, exhaust gas pressure control valve, ECM P0476 Exhaust gas pressure control valve – range/performance problem Exhaust gas control valve sensor P0477 Exhaust gas pressure control valve – low input Wiring short to ground, exhaust gas control valve sensor, ECM P0478 Exhaust gas pressure control valve – high input Wiring short to positive, exhaust gas control valve sensor, ECM P0479 Exhaust gas pressure control valve – circuit intermittent Wiring, poor connection, exhaust gas control valve sensor, ECM P0480 Engine coolant blower motor 1 – circuit malfunction Wiring, engine coolant blower motor, ECM P0481 Engine coolant blower motor 2 – circuit malfunction Wiring, engine coolant blower motor, ECM P0482 Engine coolant blower motor 3 – circuit malfunction Wiring, engine coolant blower motor, ECM P0483 Engine coolant blower motor, rationality check – malfunction Wiring, engine coolant blower motor, ECM P0484 Engine coolant blower motor – circuit over current Wiring, engine coolant blower motor, ECM P0485 Engine coolant blower motor, power/earth – circuit malfunction Wiring, engine coolant blower motor, ECM P0486 Exhaust gas recirculation (EGR) valve poistion sensor B – circuit malfunction Wiring, poor connection, EGR valve position sensor, ECM P0487 Exhaust gas recirculation (EGR) system, throttle position control – circuit malfunction Wiring, poor connection, ECM P0488 Exhaust gas recirculation (EGR) system, throttle position control – range/performance Wiring, poor connection, ECM P0489 Exhaust gas recirculation (EGR) system – circuit low Wiring short to ground, EGR valve P0490 Exhaust gas recirculation (EGR) system – circuit high Wiring short to posistive, EGR valve P0491 Secondary air injection system, bank 1 – malfunction Wiring, AIR solenoid, hose connections, mechanical fault P0492 Secondary air injection system, bank 2 – malfunction Wiring, AIR solenoid, hose connections, mechanical fault P0493 Fan over-speed (clutch locked) Fan clutch, mechanical fault P0494 Fan speed – low Wiring, relay, fan motor, mechanical fault P0495 Fan speed – high Wiring, relay, fan motor, mechanical fault P0496 Evaporative emission system – high purge flow Wiring, EVAP valve, mechanical fault P0497 Evaporative emission system – low purge flow Wiring, EVAP valve, hoses blocked, mechanical fault P0498 Evaporative emission system, vent control – circuit low Wiring, short to gound, EVAP valve P0499 Evaporative emission system, vent control – circuit high Wiring, short to positive, EVAP valve P0500 Vehicle speed sensor (VSS) – circuit malfunction Wiring, VSS, ECM P0501 Vehicle speed sensor (VSS) – range/performance problem Wiring, speedometer, VSS, CAN data bus P0502 Vehicle speed sensor (VSS) – low input Wiring short to ground, VSS, ECM P0503 Vehicle speed sensor (VSS) – intermittent/erratic/high input Wiring, poor connection, other connected system, insturment panel, VSS P0504 Brake switch – A/B correlation Wiring, mechanical fault P0505 Idle speed control (ISC) system – malfunction Wiring, ISC acutator/IAC valve, throttle motor, throttle valve tight/sticking, ECM P0506 Idle speed control (ISC) system – rpm lower than expected Wiring, ISC acutator/IAC valve, throttle motor, throttle valve tight/sticking, ECM P0507 Idle speed control (ISC) system – rpm higher than expected Wiring, ISC acutator/IAC valve, throttle motor, throttle valve tight/sticking, ECM P0508 Idle air control (IAC) system – circuit low Wiring short to ground, IAC valve, ECM P0509 Idle air control (IAC) system – circuit high Wiring short to positive, IAC valve, ECM P0510 Closed throttle position (CTP) switch – circuit malfunction Wiring, CTP switch, ECM P0511 Idle air control (IAC) system – circuit malfunction Wiring, poor connection, IAC valve, ECM P0512 Starter request circuit – malfunction Wiring, immobilizer system, relay P0513 Incorrect immobilizer key Immobilizer system P0514 Battery temperature sensor – circuit range/performance Wiring, poor connection, battery temperature sensor P0515 Battery temperature sensor – circuit malfunction Wiring, poor connection, battery temperature sensor P0516 Battery temperature sensor – circuit low Wiring, short to ground, battery temperature sensor, ECM P0517 Battery temperature sensor – circuit high Wiring, short to positive, battery temperature sensor, ECM P0518 Idle air control (IAC) system – circuit intermittent Wiring, poor connection, IAC valve, ECM P0519 Idle air control (IAC) system – circuit performance Wiring, poor connection, IAC valve, ECM P0520 Engine oil pressure sensor/switch – circuit malfunction Wiring, engine oil pressure sensor/switch, ECM P0521 Engine oil pressure sensor/switch – range/performance problem Engine oil pressure sensor/switch P0522 Engine oil pressure sensor/switch – low voltage Wiring short to ground, engine oil pressure sensor/switch, ECM P0523 Engine oil pressure sensor/switch – high voltage Wiring short to positive, engine oil pressure sensor/switch, ECM P0524 Engine oil pressure too low Mechanical fault P0525 Cruise control, servo control – circuit range/performance Wiring, poor connection, cruise control servo P0526 Fan speed sensor – circuit malfunction Wiring, poor connection, fan speed sensor, ECM P0527 Fan speed sensor – circuit range/performance Wiring, poor connection, fan speed sensor P0528 Fan speed sensor – no signal Wiring, poor connection, fan speed sensor, ECM P0529 Fan speed sensor – circuit intermittent Wiring, poor connection, ECM P0530 AC refrigerant pressure sensor – circuit malfunction Wiring, AC refrigerant pressure sensor, ECM P0531 AC refrigerant pressure sensor – range/performance problem AC refrigerant pressure sensor P0532 AC refrigerant pressure sensor – low input AC refrigerant pressure too low (incorrectly charged), wiring, AC refrigerant pressure sensor, ECM P0533 AC refrigerant pressure sensor – high input AC refrigerant pressure too high (cooling fault/incorrectly charged), wiring, AC refrigerant pressure sensor, ECM P0534 AC refrigerant charge loss AC leak, wiring, AC refrigerant pressure sensor P0535 AC evaporator temperature sensor – circuit malfunction Wiring, poor connection, A/C evaporator temperature sensor, ECM P0536 AC evaporator temperature sensor – range/performance problem Wiring, poor connection, A/C evaporator temperature sensor, ECM P0537 AC evaporator temperature sensor – circuit low Wiring, short to gound, A/C evaporator temperature sensor, ECM P0538 AC evaporator temperature sensor – circuit high Wiring, short to positive, A/C evaporator temperature sensor, ECM P0539 AC evaporator temperature sensor – circuit intermittent Wiring, poor connection, A/C evaporator temperature sensor, ECM P0540 Intake air heater A – circuit malmunction Wiring, relay, intake air heater P0541 Intake air heater A – circuit low Wiring short to ground, intake air heater P0542 Intake air heater A – circuit high Wiring short to positive, intake air heater P0543 Intake air heater A – circuit open Wiring, intake air heater P0544 Exhaust gas recirculation temperature (EGRT) sensor, bank 1 – circuit malfunction Wiring, EGRT sensor, ECM P0545 Exhaust gas recirculation temperature (EGRT) sensor, bank 1 – low input Wiring short to ground, EGRT sensor, ECM P0546 Exhaust gas recirculation temperature (EGRT) sensor, bank 1 – high input Wiring short to positive, EGRT sensor, ECM P0547 Exhaust gas temperature sensor, bank 2 sensor 1 – circuit malfunction Wiring, poor connection, exhaust gas temperature sensor, ECM P0548 Exhaust gas temperature sensor, bank 2 sensor 1 – circuit low Wiring short to ground, exhaust gas temperature sensor, ECM P0549 Exhaust gas temperature sensor, bank 2 sensor 1 – circuit high Wiring short to positive, exhaust gas temperature sensor, ECM P0550 Power steering pressure (PSP) sensor/switch – circuit malfunction Wiring, PSP sensor/switch, ECM P0551 Power steering pressure (PSP) sensor/switch – range/performance problem PAS system, PSP sensor/switch P0552 Power steering pressure (PSP) sensor/switch – low input Wiring short to ground, PSP sensor/switch, ECM P0553 Power steering pressure (PSP) sensor/switch – high input Wiring short to positive, PSP sensor/switch, ECM P0554 Power steering pressure (PSP) sensor/switch – circuit intermittent Wiring, poor connection, PSP sensor/switch, ECM P0555 Brake booster pressure sensor – circuit malfunction Wiring, poor connection, brake booster pressure sensor, ECM P0556 Brake booster pressure sensor – circuit range/performance Wiring, poor connection, brake booster pressure sensor, ECM P0557 Brake booster pressure sensor – circuit low input Wiring short to ground, brake booster pressure sensor, ECM P0558 Brake booster pressure sensor – circuit high input Wiring short to positive, brake booster pressure sensor, ECM P0559 Brake booster pressure sensor – circuit intermittent Wiring, poor connection, brake booster pressure sensor, ECM P0560 System voltage – malfunction Wiring, poor connection, battery, alternator P0561 System voltage – unstable Wiring, poor connection, battery, alternator P0562 System voltage – low Wiring, poor connection, battery, alternator P0563 System voltage – high Alternator P0564 Cruise control system, multi-function input A – circuit malfunction Wiring poor connection, multi-function switch, mechanical fault P0565 Cruise control master switch, ON signal – malfunction Wiring, cruise control master switch, ECM P0566 Cruise control master switch, OFF signal – malfunction Wiring, cruise control master switch, ECM P0567 Cruise control master switch, RESUME signal – malfunction Wiring, cruise control master switch, ECM P0568 Cruise control master switch, SET signal – malfunction Wiring, cruise control master switch, ECM P0569 Cruise control master switch, COAST signal – malfunction Wiring, cruise control master switch, ECM P0570 Cruise control system, APP sensor signal – malfunction Wiring, APP sensor, ECM P0571 Cruise/brake switch A – circuit malfunction Wiring, cruise/brake switch, ECM P0572 Cruise/brake switch A – circuit low Wiring short to ground, cruise/brake switch, ECM P0573 Cruise/brake switch A – circuit high Wiring short to positive, cruise/brake switch, ECM P0574 Cruise control system –vehicle speed too high Mechanical fault P0575 Cruise control system – input circuit malfunction Wiring, poor connection, mechanical fault, ECM P0576 Cruise control system – input circuit low Wiring short to ground P0577 Cruise control system – input circuit high Wiring short to positive P0578 Cruise control system, multi-function input A – circuit stuck Wiring, poor connection, multi-function switch, mechanical fault P0579 Cruise control system, multi-function input A – circuit range/performance Wiring, poor connection, multi-function switch, mechanical fault P0580 Cruise control system, multi-function input A – circuit low Wiring short to ground, multi-function switch, mechanical fault P0581 Cruise control system, multi-function input A – circuit high Wiring short to positive, multi-function switch, mechanical fault P0582 Cruise control system, vacuum control – circuit open Wiring, vacuum control solenoid P0583 Cruise control system, vacuum control – circuit low Wiring short to ground, vacuum control solenoid P0584 Cruise control system, vacuum control – circuit high Wiring short to positive, vacuum control solenoid P0585 Cruise control system, multi-function input A/B – correlation Mechanical fault P0586 Cruise control system, vent control – circuit open Wiring, vent control solenoid P0587 Cruise control system, vent control – circuit low Wiring short to ground, vent control solenoid P0588 Cruise control system, vent control – circuit high Wiring short to positive, vent control solenoid P0589 Cruise control system, multi-function input B – circuit malfunction Wiring, poor connection, multi-function switch, mechanical fault P0590 Cruise control system, multi-function input B – circuit stuck Wiring, poor connection, multi-function switch, mechanical fault P0591 Cruise control system, multi-function input B – circuit range/performance Wiring, poor connection, multi-function switch, mechanical fault P0592 Cruise control system, multi-function input B – circuit low Wiring short to ground, multi-function switch, mechanical fault P0593 Cruise control system, multi-function input B – circuit high Wiring short to positive, multi-function switch, mechanical fault P0594 Cruise control system, servo control – circuit open Wiring, servo control solenoid P0595 Cruise control system, servo control – circuit low Wiring short to ground, servo control solenoid P0596 Cruise control system, servo control – circuit high Wiring short to positive, servo control solenoid P0597 Thermostat heater control system – circuit open Wiring, relay, thermostat heater P0598 Thermostat heater control system – circuit low Wiring short to ground, relay, thermostat heater P0599 Thermostat heater control system – circuit high Wiring short to positive, relay, thermostat heater P0600 CAN date bus – malfunction Wiring, connected system, ECM P0601 Engine control module (ECM) – memory check sum error ECM P0602 Engine control module (ECM) – programming error ECM P0603 Engine control module (ECM) – KAM error ECM P0604 Engine control module (ECM) – RAM error ECM P0605 Engine control module (ECM) – ROM error ECM P0606 Engine control module (ECM) – processor fault ECM P0607 Control module – performance Control module P0608 Engine control module (ECM), VSS output A – malfunction ECM P0609 Engine control module (ECM), VSS output B – malfunction ECM P0610 Control module – vehicle options error Control module P0611 Fuel injector control module – performance Fuel injector control module P0612 Fuel injector control module – relay control circuit Wiring, relay,fuel injector control module P0613 Transmission control module (TCM) processor error TCM P0614 Engine control module (ECM)/Transmission control module (TCM) – mismatch ECM/TCM P0615 Starter relay – circuit malfunction Wiring, poor connection, starter relay, ECM P0616 Starter relay – circuit low Wiring short to ground, starter relay, ECM P0617 Starter relay – circuit high Wiring short to positive, starter relay, ECM P0618 Alternative fuel control module – KAM error alternative fuel control module P0619 Alternative fuel control module – RAM/ROM error alternative fuel control module P0620 Alternator, control – circuit malfunction Wiring, alternator, battery, ECM P0621 Alternator warning lamp– circuit malfunction Wiring, alternator warning lamp, ECM P0622 Alternator, field control – circuit malfunction Wiring, alternator, battery, ECM P0623 Generator lamp control – circuit malfunction Wiring, poor connection, bulb, ECM P0624 Fuel cap lamp control – circuit malfunction Wiring, poor connection, bulb, ECM P0625 Generator field terminal – circuit low Wiring short to ground, generator P0626 Generator field terminal – circuit high Wiring short to positive, generator P0627 Fuel pump control – circuit open Wiring, relay, fuel pump P0628 Fuel pump control – circuit low Wiring short to ground, relay, fuel pump P0629 Fuel pump control – circuit high Wiring short to positive, relay, fuel pump P0630 VIN not programmed or mismatch – ECM ECM P0631 VIN not programmed or mismatch – TCM TCM P0632 Odometer not programmed – ECM ECM P0633 Immobilizer key not programmed – ECM ECM P0634 ECM/TCM – internal termperature too high Mechanical fault, ECM/TCM P0635 Power steering (PAS) control – circuit malfunction Wiring, poor connection, PAS pressure switch, ECM P0636 Power steering (PAS) control – circuit low Wiring short to ground, PAS pressure switch, ECM P0637 Power steering (PAS) control – circuit high Wiring short to positive, PAS pressure switch, ECM P0638 Throttle actuator control, bank 1 – range/performance problem Basic setting not carried out (if applicable), ISC actuator/throttle motor, APP sensor P0639 Throttle actuator control, bank 2 – range/performance Wiring, throttle control unit P0640 Intake air heater control – circuit malfunction Wiring, relay, intake air heater P0641 Sensor reference voltage A – circuit open Wiring short to positive P0642 Engine control module (ECM), knock control – defective ECM P0643 Sensor reference voltage A – circuit high Wiring short to positive P0644 Driver display, serial communication – circuit malfunction Wiring, CAN data bus, ECM P0645 Air conditioning (AC) Wiring, AC system P0646 A/C clutch relay control – circuit low Wiring short to ground, A/C clutch relay P0647 A/C clutch relay control – circuit high Wiring short to positive, A/C clutch relay P0648 Immobilizer lamp control – circuit malfunction Wiring, poor connection, bulb, ECM P0649 Cruise control lamp control – circuit Wiring, poor connection, bulb, ECM P0650 Malfunction indicator lamp (MIL) – circuit malfunction Wiring, MIL, ECM P0651 Sensor reference voltage B – circuit open Wiring short to positive P0652 Sensor reference voltage B – circuit low Wiring short to ground P0653 Sensor reference voltage B – circuit high Wiring short to positive P0654 Engine rpm, output – circuit malfunction Wiring, ECM P0655 Engine hot lamp output – circuit malfunction Wiring, engine hot lamp, ECM P0656 Fuel level output – circuit malfunction Wiring, ECM P0657 Actuator supply voltage – circuit open Wiring P0658 Actuator supply voltage – circuit low Wiring short to ground, actuator P0659 Actuator supply voltage – circuit high Wiring short to positive, actuator P0660 Intake manifold tuning valve, bank 1 – circuit open Wiring, intake manifold tuning valve P0661 Intake manifold tuning valve, bank 1 – circuit low Wiring short to ground, intake manifold tuning valve P0662 Intake manifold tuning valve, bank 1 – circuit high Wiring short to positive, intake manifold tuning valve P0663 Intake manifold tuning valve, bank 2 – circuit open Wiring, intake manifold tuning valve P0664 Intake manifold tuning valve, bank 2 – circuit low Wiring short to ground, intake manifold tuning valve P0665 Intake manifold tuning valve, bank 2 – circuit high Wiring short to positive, intake manifold P0666 ECM/TCM internal termperature sensor – circuit malfunction Wiring, poor connection, internal temperature sensor, ECM/TCM P0667 ECM/TCM internal termperature sensor – range/performance Wiring, poor connection, internal temperature sensor, ECM/TCM P0668 ECM/TCM internal termperature sensor – circuit low Wiring short to ground, internal temperature sensor, ECM/TCM P0669 ECM/TCM internal termperature sensor – circuit high Wiring short to positive, internal temperature sensor, ECM/TCM P0670 Glow plug module control – circuit malfunction Wiring, poor connection, control module, glow plug, ECM P0671 Glow plug, cylinder 1 – circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0672 Glow plug, cylinder 2 – circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0673 Glow plug, cylinder 3 – circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0674 Glow plug, cylinder 4 – circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0675 Glow plug, cylinder 5 – circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0676 Glow plug, cylinder 6 – circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0677 Glow plug, cylinder 7 – circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0678 Glow plug, cylinder 8 – circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0679 Glow plug, cylinder 9 – circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0680 Glow plug, cylinder 10 – circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0681 Glow plug, cylinder 11 – circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0682 Glow plug, cylinder 12 – circuit malfunction Wiring, poor connection, relay, control module, glow plug, ECM P0683 Glow plug control module communication to ECM – malfunction Wiring, poor connection, control module, ECM P0684 Glow plug control module communication to ECM – range/performance Wiring, poor connection, control module, ECM P0685 ECM power relay control – circuit open Wiring, ECM relay P0686 ECM power relay control – circuit low Wiring short to ground, ECM relay, ECM P0687 Engine control relay – short to ground Wiring short to ground, engine control relay, ECM P0688 Engine control relay – short to positive Wiring short to positive, engine control relay, ECM P0689 ECM power relay sense – circuit low Wiring short to ground, ECM relay, ECM P0690 ECM power relay sense – circuit high Wiring short to positive, ECM relay, ECM P0691 Engine coolant blower motor 1 – short to ground Wiring short to ground, engine coolant blower motor, ECM P0692 Engine coolant blower motor 1 – short to positive Wiring short to positive, engine coolant blower motor, ECM P0693 Engine coolant blower motor 2 – short to ground Wiring short to ground, engine coolant blower motor, ECM P0694 Engine coolant blower motor 2 – short to positive Wiring short to positive, engine coolant blower motor, ECM P0695 Fan 3 control – circuit low Wiring short to ground, fan motor P0696 Fan 3 control – circuit high Wiring short to positive, fan motor P0697 Sensor reference voltage C – circuit open Wiring short to positive P0698 Sensor reference voltage C – circuit low Wiring short to ground P0699 Sensor reference voltage C – circuit high Wiring short to positive P0700 Transmission control system – malfunction Wiring, TCM P0701 Transmission control system – range/performance problem Wiring, TCM P0702 Transmission control system – electrical Wiring, TCM P0703 Torque converter/brake switch B – circuit malfunction Wiring, torque converter/brake switch, ECM//TCM P0704 Clutch pedal position (CPP) switch – circuit malfunction Wiring, CPP switch, ECM/TCM P0705 Transmission range (TR) sensor/switch, PRNDL input – circuit malfunction Wiring, TR sensor/switch, ECM/TCM P0706 Transmission range (TR) sensor/switch – range/performance problem Wiring, TR sensor/switch P0707 Transmission range (TR) sensor/switch – low input Wiring short to ground, TR sensor/switch, ECM/TCM P0708 Transmission range (TR) sensor/switch –high input Wiring short to positive, TR sensor/switch, ECM/TCM P0709 Transmission range (TR) sensor/switch – circuit intermittent Wiring, poor connection, TR sensor/switch, ECM/TCM P0710 Transmission fluid temperature (TFT) sensor – circuit malfunction Wiring, TFT sensor, ECM, ECM/TCM P0711 Transmission fluid temperature (TFT) sensor – range/performance problem Wiring, TFT sensor P0712 Transmission fluid temperature (TFT) sensor – low input Wiring short to ground, TFT sensor, ECM, ECM/TCM P0713 Transmission fluid temperature (TFT) sensor – high input Wiring short to ground, TFT sensor, ECM, ECM/TCM P0714 Transmission fluid temperature (TFT) sensor – circuit intermittent Wiring, poor connection, TFT sensor, ECM, ECM/TCM P0715 Turbine shaft speed (TSS) sensor – circuit malfunction Wiring, TSS sensor, ECM/TCM P0716 Turbine shaft speed (TSS) sensor – range/performance problem Wiring, TSS sensor P0717 Turbine shaft speed (TSS) sensor – no signal Wiring, TSS sensor, ECM/TCM P0718 Turbine shaft speed (TSS) sensor – circuit intermittent Wiring, poor connection, TSS sensor, ECM/TCM P0719 Torque converter/brake switch B – circuit low Wiring short to ground, torque converter/brake switch, ECM/TCM P0720 Output shaft speed (OSS) sensor – circuit malfunction Wiring, OSS sensor, ECM/TCM P0721 Output shaft speed (OSS) sensor – range/performance problem Wiring, OSS sensor P0722 Output shaft speed (OSS) sensor – no signal Wiring, OSS sensor, ECM/TCM P0723 Output shaft speed (OSS) sensor – circuit intermittent Wiring, poor connection, OSS sensor, ECM/TCM P0724 Torque converter/brake switch B – circuit high Wiring short to positive, torque converter/brake switch, ECM/TCM P0725 Engine RPM input – circuit malfunction Wiring, CKP/RPM sensor, ECM/TCM P0726 Engine RPM input – range/performance problem Wiring, CKP/RPM sensor P0727 Engine RPM input – no signal Wiring, CKP/RPM sensor, ECM/TCM P0728 Engine RPM input – circuit intermittent Wiring, poor connection, CKP/RPM sensor, ECM/TCM P0730 Incorrect gear ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault P0731 Gear 1 – incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault P0732 Gear 2 – incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault P0733 Gear 3 – incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault P0734 Gear 4 – incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault P0735 Gear 5 – incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault P0736 Reverse – incorrect ratio Wiring, TR sensor/switch, shift solenoid, transmission mechanical fault P0737 TCM engine speed output – circuit Wiring, TCM P0738 TCM engine speed output – circuit low Wiring, TCM P0739 TCM engine speed output – circuit high Wiring, TCM P0740 Torque converter clutch (TCC) solenoid – circuit malfunction Wiring, TCC solenoid, ECM/TCM P0741 Torque converter clutch (TCC) solenoid – performance or stuck off Wiring, TCC solenoid P0742 Torque converter clutch (TCC) solenoid – stuck on Wiring, TCC solenoid P0743 Torque converter clutch (TCC) solenoid – electrical Wiring, TCC solenoid, ECM/TCM P0744 Torque converter clutch (TCC) solenoid – circuit intermittent Wiring, poor connection, TCC solenoid, ECM/TCM P0745 Transmission fluid pressure (TFP) solenoid – circuit malfunction Wiring, TFP solenoid, ECM/TCM P0746 Transmission fluid pressure (TFP) solenoid – performance or stuck off Wiring, TFP solenoid P0747 Transmission fluid pressure (TFP) solenoid – stuck on Wiring, TFP solenoid P0748 Transmission fluid pressure (TFP) solenoid – electrical Wiring, TFP solenoid, ECM/TCM P0749 Transmission fluid pressure (TFP) solenoid – circuit intermittent Wiring, poor connection, TFP solenoid, ECM/TCM P0750 Shift solenoid (SS) A – circuit malfunction Wiring, shift solenoid, ECM/TCM P0751 Shift solenoid (SS) A – performance or stuck off Wiring, shift solenoid P0752 Shift solenoid (SS) A – stuck on Wiring, shift solenoid P0753 Shift solenoid (SS) A – electrical Wiring, shift solenoid, ECM/TCM P0754 Shift solenoid (SS) A – circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM P0755 Shift solenoid (SS) B – circuit malfunction Wiring, shift solenoid, ECM/TCM P0756 Shift solenoid (SS) B – performance or stuck off Wiring, shift solenoid P0757 Shift solenoid (SS) B – stuck on Wiring, shift solenoid P0758 Shift solenoid (SS) B – electrical Wiring, shift solenoid, ECM/TCM P0759 Shift solenoid (SS) B – circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM P0760 Shift solenoid (SS) C – circuit malfunction Wiring, shift solenoid, ECM/TCM P0761 Shift solenoid (SS) C – performance or stuck off Wiring, shift solenoid P0762 Shift solenoid (SS) C – stuck on Wiring, shift solenoid P0763 Shift solenoid (SS) C – electrical Wiring, shift solenoid, ECM/TCM P0764 Shift solenoid (SS) C – circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM P0765 Shift solenoid (SS) D – circuit malfunction Wiring, shift solenoid, ECM/TCM P0766 Shift solenoid (SS) D – performance or stuck off Wiring, shift solenoid P0767 Shift solenoid (SS) D – stuck on Wiring, shift solenoid P0768 Shift solenoid (SS) D – electrical Wiring, shift solenoid, ECM/TCM P0769 Shift solenoid (SS) D – circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM P0770 Shift solenoid (SS) E – circuit malfunction Wiring, shift solenoid, ECM/TCM P0771 Shift solenoid (SS) E – performance or stuck off Wiring, shift solenoid P0772 Shift solenoid (SS) E – stuck on Wiring, shift solenoid P0773 Shift solenoid (SS) E – electrical Wiring, shift solenoid, ECM/TCM P0774 Shift solenoid (SS) E – circuit intermittent Wiring, poor connection, shift solenoid, ECM/TCM P0775 Pressure control solenoid B – malfunction Pressure control solenoid P0776 Pressure control solenoid B – performance or stuck off Wiring, pressure control solenoid P0777 Pressure control solenoid B – stuck on Wiring, pressure control solenoid P0778 Pressure control solenoid B – electrical Wiring, pressure control solenoid P0779 Pressure control solenoid B – intermittent Wiring, poor connection, pressure control solenoid P0780 Gear selection – shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault P0781 Gear selection, 1-2 – shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault P0782 Gear selection, 2-3 – shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault P0783 Gear selection, 3-4 – shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault P0784 Gear selection, 4-5 – shift malfunction Wiring, TR sensor, shift solenoids, transmission mechanical fault P0785 Shift/timing solenoid – circuit malfunction Wiring, shift/timing solenoid, ECM/TCM P0786 Shift/timing solenoid – range/performance problem Wiring, shift/timing solenoid P0787 Shift/timing solenoid – low Wiring short to ground, shift/timing solenoid, ECM/TCM P0788 Shift/timing solenoid – high Wiring short to positive, shift/timing solenoid, ECM/TCM P0789 Shift/timing solenoid – intermittent Wiring, poor connection, shift/timing solenoid, ECM/TCM P0790 Transmission mode selection switch – circuit malfunction Wiring, transmission mode selection switch, ECM/TCM P0791 Intermediate shaft speed sensor – circuit malfunction Wiring, poor connection, intermediate shaft speed sensor, ECM/TCM P0792 Intermediate shaft speed sensor – range/performance problem Wiring, poor connection, intermediate shaft speed sensor, ECM/TCM P0793 Intermediate shaft speed sensor – no signal Wiring, poor connection,short to ground, intermediate shaft speed sensor, ECM/TCM P0794 Intermediate shaft speed sensor – intermittent circuit malfunction Wiring, poor connection, intermediate shaft speed sensor, ECM/TCM P0795 Transmisssion fluid pressure (TFP) solenoid C – circuit malfunction Wiring, poor connection, TFP solenoid, ECM/TCM P0796 Transmisssion fluid pressure (TFP) solenoid C – performance or stuck off Wiring, poor connection, TFP solenoid, ECM/TCM P0797 Transmisssion fluid pressure (TFP) solenoid C – stuck on Wiring, poor connection, TFP solenoid, ECM/TCM P0798 Transmisssion fluid pressure (TFP) solenoid C – electrical malfunction Wiring, poor connection, TFP solenoid, ECM/TCM P0799 Transmisssion fluid pressure (TFP) solenoid C – intermittent circuit malfunction Wiring, poor connection, ECM/TCM P0800 Transfer case control system, MIL request – malfunction Wiring, mechanical fault P0801 Reverse inhibit circuit – malfunction Wiring, poor connection P0802 Transmission control system, MIL request – circuit open Wiring, mechanical fault P0803 1-4 Upshift (Skip shift) solenoid – circuit malfunction Wiring, poor connection, upshift solenoid P0804 1-4 Upshift (Skip shift) warning lamp – circuit malfunction Wiring, poor connection P0805 Clutch position sensor – circuit malfunction Wiring, poor connection, clutch position sensor, ECM/TCM P0806 Clutch position sensor – range/performance problem Wiring, poor connection, clutch position sensor, ECM/TCM P0807 Clutch position sensor – low input Wiring, short to ground, clutch position sensor, ECM/TCM P0808 Clutch position sensor – high input Wiring, short to positive, clutch position sensor, ECM/TCM P0809 Clutch position sensor – intermittent circuit malfunction Wiring, poor connection, clutch position sensor, ECM/TCM P0810 Clutch position control error Wiring, poor connection, ECM/TCM P0811 Excessive clutch slip Wiring, poor connection, mechanical fault, ECM/TCM P0812 Reverse gear – input circuit malfunction Wiring, poor connection, ECM/TCM P0813 Reverse gear – output circuit malfunction Wiring, poor connection, ECM/TCM P0814 Transmission range (TR) display – circuit malfunction Wiring, poor connection, TR sensor, ECM/TCM P0815 Upshift switch – circuit malfunction Wiring, poor connection, upshift switch, ECM/TCM P0816 Downshift switch – circuit malfunction Wiring, poor connection, downshift switch, ECM/TCM P0817 Starter disable circuit – malfunction Wiring, poor connection, ECM/TCM P0818 Driveline disconnect switch – circuit malfunction Wiring, poor connection, upshift switch, ECM/TCM P0819 Up and down shift switch to transmission range – correlation Wiring, poor connection,TR sensor, ECM/TCM P0820 Gear lever X-Y position sensor – circuit malfunction Wiring, poor connection, gear lever position sensor, ECM/TCM P0821 Gear lever X position sensor – circuit malfunction Wiring, poor connection, gear lever position sensor, ECM/TCM P0822 Gear lever Y position sensor – circuit malfunction Wiring, poor connection, gear lever position sensor, ECM/TCM P0823 Gear lever X position sensor – circuit intermittent Wiring, poor connection, gear lever position sensor, ECM/TCM P0824 Gear lever Y position sensor – circuit intermittent Wiring, poor connection, gear lever position sensor, ECM/TCM P0825 Gear lever push-pull switch – circuit malfunction Wiring, poor connection, gear lever push-pull switch, ECM/TCM P0826 Up and down switch – input circuit Wiring, Up/down switch P0827 Up and down switch – input circuit low Wiring short to ground, Up/down switch P0828 Up and down switch – input circuit high Wiring short to positive, Up/down switch P0829 5-6 Shift Mechanical fault P0830 Clutch pedal position (CPP) switch A – circuit malfunction Wiring, poor connection, CPP switch, ECM/TCM P0831 Clutch pedal position (CPP) switch A – low input Wiring, short to ground, CPP switch, ECM/TCM P0832 Clutch pedal position (CPP) switch A – high input Wiring, short to positive, CPP switch, ECM/TCM P0833 Clutch pedal position (CPP) switch B – circuit malfunction Wiring, poor connection, CPP switch, ECM/TCM P0834 Clutch pedal position (CPP) switch B – low input Wiring, short to ground, CPP switch, ECM/TCM P0835 Clutch pedal position (CPP) switch B – high input Wiring, short to positive, CPP switch, ECM/TCM P0836 Four wheel drive switch – circuit malfunction Wiring, poor connection, four wheel drive switch, ECM/TCM P0837 Four wheel drive switch – range/performance problem Wiring, poor connection, four wheel drive switch, ECM/TCM P0838 Four wheel drive switch – low input Wiring, short to ground, four wheel drive switch, ECM/TCM P0839 Four wheel drive switch – high input Wiring, short to positive, four wheel drive switch, ECM/TCM P0840 Transmission fluid pressure (TFP) sensor A – circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A – circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0841 Transmission fluid pressure (TFP) sensor A – range/performance problem Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A – range/performance problem Wiring, poor connection, TFP switch, ECM/TCM P0842 Transmission fluid pressure (TFP) sensor A – low input Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A – low input Wiring, short to ground, TFP switch, ECM/TCM P0843 Transmission fluid pressure (TFP) sensor A – high input Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A – high input Wiring, short to positive, TFP switch, ECM/TCM P0844 Transmission fluid pressure (TFP) sensor A – intermittent circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch A – intermittent circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0845 Transmission fluid pressure (TFP) sensor B – circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B – circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0846 Transmission fluid pressure (TFP) sensor B – range/performance problem Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B – range/performance problem Wiring, poor connection, TFP switch, ECM/TCM P0847 Transmission fluid pressure (TFP) sensor B – low input Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B – low input Wiring, short to ground, TFP switch, ECM/TCM P0848 Transmission fluid pressure (TFP) sensor B – high input Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B – high input Wiring, short to positive, TFP switch, ECM/TCM P0849 Transmission fluid pressure (TFP) sensor B – intermittent circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch B – intermittent circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0850 Park/neutral position (PNP) switch – input circuit malfunction Wiring, PNP switch, ECM/TCM P0851 Park/neutral position (PNP) switch – input circuit low Wiring, short to ground, PNP switch, ECM/TCM P0852 Park/neutral position (PNP) switch – input circuit high Wiring, short to positive, PNP switch, ECM/TCM P0853 Drive switch – input circuit malfunction Wiring, drive switch, ECM/TCM P0854 Drive switch – input circuit low Wiring, short to ground, drive switch, ECM/TCM P0855 Drive switch – input circuit high Wiring, short to positive, drive switch, ECM/TCM P0856 Traction control input signal – malfunction Wiring, poor connection, ECM/TCM P0857 Traction control input signal – range/performance problem Wiring, poor connection, ECM/TCM P0858 Traction control input signal – low Wiring, short to ground, ECM/TCM P0859 Traction control input signal – high Wiring, short to positive, ECM/TCM P0860 Gear shift module communication circuit – malfunction Wiring, poor connection, gear shift module, ECM/TCM P0861 Gear shift module communication circuit – low input Wiring, short to ground, gear shift module, ECM/TCM P0862 Gear shift module communication circuit – low input Wiring, short to positive, gear shift module, ECM/TCM P0863 Transmission control module (TCM) communication circuit – malfunction Wiring, poor connection, TCM P0864 Transmission control module (TCM) communication circuit – range/performance problem Wiring, poor connection, TCM P0865 Transmission control module (TCM) communication circuit – low input Wiring, short to ground, TCM P0866 Transmission control module (TCM) communication circuit – high input Wiring, short to positive, TCM P0867 Transmission fluid pressure (TFP) sensor Wiring, poor connection, TFP switch, ECM/TCM P0868 Transmission fluid pressure (TFP) sensor – low Wiring, short to ground, TFP switch, ECM/TCM P0869 Transmission fluid pressure (TFP) sensor – high Wiring, short to positive, TFP switch, ECM/TCM P0870 Transmission fluid pressure (TFP) sensor C – circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C – circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0871 Transmission fluid pressure (TFP) sensor C – range/performance Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C – range/performance Wiring, poor connection, TFP switch, ECM/TCM P0872 Transmission fluid pressure (TFP) sensor C – low input Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C – low input Wiring, short to ground, TFP switch, ECM/TCM P0873 Transmission fluid pressure (TFP) sensor C – high input Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C – high input Wiring, short to positive, TFP switch, ECM/TCM P0874 Transmission fluid pressure (TFP) sensor C – intermittent circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch C – intermittent circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0875 Transmission fluid pressure (TFP) sensor D – circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D – circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0876 Transmission fluid pressure (TFP) sensor D – range/performance Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D – range/performance Wiring, poor connection, TFP switch, ECM/TCM P0877 Transmission fluid pressure (TFP) sensor D – low input Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D – low input Wiring, short to ground, TFP switch, ECM/TCM P0878 Transmission fluid pressure (TFP) sensor D – high input Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D – high input Wiring, short to positive, TFP switch, ECM/TCM P0879 Transmission fluid pressure (TFP) sensor D – intermittent circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch D – intermittent circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0880 Transmission control module (TCM) – power input signal malfunction Wiring, poor connection, TCM P0881 Transmission control module (TCM) – power input signal range/performance Wiring, poor connection, TCM P0882 Transmission control module (TCM) – power input signal low Wiring, short to ground, TCM P0883 Transmission control module (TCM) – power input signal high Wiring, short to positive, TCM P0884 Transmission control module (TCM) – power input signal intermittent malfunction Wiring, poor connection, TCM P0885 Transmission control module (TCM) power relay – control circuit open Wiring, poor connection, TCM power relay, TCM P0886 Transmission control module (TCM) power relay – control circuit low Wiring, short to ground, TCM power relay, TCM P0887 Transmission control module (TCM) power relay – control circuit high Wiring, short to positive, TCM power relay, TCM P0888 Transmission control module (TCM) power relay – sense circuit malfunction Wiring, poor connection, TCM power relay, TCM P0889 Transmission control module (TCM) power relay – sense circuit range/performance Wiring, poor connection, TCM power relay, TCM P0890 Transmission control module (TCM) power relay – sense circuit low Wiring, short to ground, TCM power relay, TCM P0891 Transmission control module (TCM) power relay – sense circuit high Wiring, short to positive, TCM power relay, TCM P0892 Transmission control module (TCM) power relay – sense circuit intermittent malfunction Wiring, poor connection, TCM power relay, TCM P0893 Multiple gears engaged Mechanical fault P0894 Transmission component slipping Mechanical fault P0895 Shift time too short Mechanical fault P0896 Shift time too long Mechanical fault P0897 Transmission fluid deteriorated Mechanical fault P0898 Transmission control system – MIL request – circuit low Wiring, poor connection, short to ground P0899 Transmission control system – MIL request – circuit high Wiring, poor connection, short to positive P0900 Clutch actuator – circuit open Wiring, clutch actuator, ECM/TCM P0901 Clutch actuator – circuit range/performance Wiring, poor connection, clutch actuator, ECM/TCM P0902 Clutch actuator – circuit low Wiring, short to ground, clutch actuator, ECM/TCM P0903 Clutch actuator – circuit high Wiring, short to positive, clutch actuator, ECM/TCM P0904 Transmission gate select position circuit – malfunction Wiring, poor connection, ECM/TCM P0905 Transmission gate select position circuit – range/performance Wiring, poor connection, ECM/TCM P0906 Transmission gate select position circuit – low Wiring, short to ground, ECM/TCM P0907 Transmission gate select position circuit – high Wiring, short to positive, ECM/TCM P0908 Transmission gate select position circuit – intermittent circuit malfunction Wiring, poor connection, ECM/TCM P0909 Transmission gate select control error Mechanical fault P0910 Transmission gate select actuator – circuit open Wiring, transmission gate select actuator, ECM/TCM P0911 Transmission gate select actuator – circuit range/performance Wiring, poor connection, transmission gate select actuator, ECM/TCM P0912 Transmission gate select actuator – circuit low Wiring, short to ground, transmission gate select actuator, ECM/TCM P0913 Transmission gate select actuator – circuit high Wiring, short to positive, transmission gate select actuator, ECM/TCM P0914 Gear shift position circuit – malfunction Wiring, poor connection, ECM/TCM P0915 Gear shift position circuit – range/performance Wiring, poor connection, ECM/TCM P0916 Gear shift position circuit – low Wiring, short to ground, ECM/TCM P0917 Gear shift position circuit – high Wiring, short to positive, ECM/TCM P0918 Gear shift position circuit – intermittent malfunction Wiring, poor connection, ECM/TCM P0919 Gear shift position control – error Wiring, poor connection, ECM/TCM P0820 Gear shift forward actuator – circuit open Wiring, gear shift forward actuator, ECM/TCM P0821 Gear shift forward actuator – circuit range/performance Wiring, poor connection, gear shift forward actuator, ECM/TCM P0822 Gear shift forward actuator – circuit low Wiring, short to ground, gear shift forward actuator, ECM/TCM P0823 Gear shift forward actuator – circuit high Wiring, short to positive, gear shift forward actuator, ECM/TCM P0824 Gear shift reverse actuator – circuit open Wiring, gear shift reverse actuator, ECM/TCM P0825 Gear shift reverse actuator – circuit range/performance Wiring, poor connection, gear shift reverse actuator, ECM/TCM P0826 Gear shift reverse actuator – circuit low Wiring, short to ground, gear shift reverse actuator, ECM/TCM P0927 Gear shift reverse actuator – circuit high Wiring, short to positive, gear shift reverse actuator, ECM/TCM P0928 Gear shift lock solenoid – circuit open Wiring, gear shift lock solenoid, ECM/TCM P0929 Gear shift lock solenoid – circuit range/performance Wiring, gear shift lock solenoid, ECM/TCM P0930 Gear shift lock solenoid – circuit low Wiring, short to ground, gear shift lock solenoid, ECM/TCM P0931 Gear shift lock solenoid – circuit high Wiring, short to positive, gear shift lock solenoid, ECM/TCM P0932 Hydraulic pressure sensor – circuit malfunction Wiring, poor connection, hydraulic pressure sensor, ECM/TCM P0933 Hydraulic pressure sensor – range/performance Wiring, hydraulic pressure sensor, ECM/TCM P0934 Hydraulic pressure sensor – circuit low input Wiring, short to ground, hydraulic pressure sensor, ECM/TCM P0935 Hydraulic pressure sensor – circuit high input Wiring, short to positive, hydraulic pressure sensor, ECM/TCM P0936 Hydraulic pressure sensor – circuit intermittent Wiring, poor connection, hydraulic pressure sensor, ECM/TCM P0937 Hydraulic oil temperature sensor – circuit malfunction Wiring, poor connection, hydraulic oil temperature sensor, ECM/TCM P0938 Hydraulic oil temperature sensor – range/performance Wiring, hydraulic oil temperature sensor, ECM/TCM P0939 Hydraulic oil temperature sensor – circuit low input Wiring, short to ground, hydraulic oil temperature sensor, ECM/TCM P0940 Hydraulic oil temperature sensor – circuit high input Wiring, short to positive, hydraulic oil temperature sensor, ECM/TCM P0941 Hydraulic oil temperature sensor – circuit intermittent Wiring, poor connection, hydraulic oil temperature sensor, ECM/TCM P0942 Hydraulic pressure unit Mechanical fault P0943 Hydraulic pressure unit – cycling period too short Mechanical fault P0944 Hydraulic pressure unit – loss of pressure Mechanical fault P0945 Hydraulic pump relay – circuit open Wiring, hydraulic pump relay, ECM/TCM P0946 Hydraulic pump relay – circuit range/performance Wiring, hydraulic pump relay, ECM/TCM P0947 Hydraulic pump relay – circuit low Wiring, short to ground, hydraulic pump relay, ECM/TCM P0948 Hydraulic pump relay – circuit high Wiring, short to positive, hydraulic pump relay, ECM/TCM P0949 ASM – adaptive learning not done ECM/TCM P0850 ASM control circuit Wiring, poor connection, ECM/TCM P0851 ASM control circuit – range/performance Wiring, poor connection, ECM/TCM P0852 ASM control circuit – low Wiring, poor connection, short to ground, ECM/TCM P0853 ASM control circuit – high Wiring, poor connection, short to positive, ECM/TCM P0854 ASM – intermittent circuit malfunction Wiring, poor connection, ECM/TCM P0855 ASM mode circuit – malfunction Wiring, poor connection, ECM/TCM P0856 ASM mode circuit – range/performance Wiring, poor connection, ECM/TCM P0957 ASM mode circuit – low Wiring, poor connection, short to ground, ECM/TCM P0958 ASM mode circuit – high Wiring, poor connection, short to positive, ECM/TCM P0959 ASM mode circuit – intermittent circuit malfunction Wiring, poor connection, ECM/TCM P0960 Pressure control (PC) solenoid A – control circuit open Wiring, poor connection, pressure control solenoid, ECM/TCM P0961 Pressure control (PC) solenoid A – control circuit range/performance Wiring, poor connection, pressure control solenoid, ECM/TCM P0962 Pressure control (PC) solenoid A – control circuit low Wiring, short to ground, pressure control solenoid, ECM/TCM P0963 Pressure control (PC) solenoid A – control circuit high Wiring, short to positive, pressure control solenoid, ECM/TCM P0964 Pressure control (PC) solenoid B – control circuit open Wiring, poor connection, pressure control solenoid, ECM/TCM P0965 Pressure control (PC) solenoid B – control circuit range/performance Wiring, poor connection, pressure control solenoid, ECM/TCM P0966 Pressure control (PC) solenoid B – control circuit low Wiring, short to ground, pressure control solenoid, ECM/TCM P0967 Pressure control (PC) solenoid B – control circuit high Wiring, short to positive, pressure control solenoid, ECM/TCM P0968 Pressure control (PC) solenoid C – control circuit open Wiring, poor connection, pressure control solenoid, ECM/TCM P0969 Pressure control (PC) solenoid C – control circuit range/performance Wiring, poor connection, pressure control solenoid, ECM/TCM P0970 Pressure control (PC) solenoid C – control circuit low Wiring, short to ground, pressure control solenoid, ECM/TCM P0971 Pressure control (PC) solenoid C – control circuit high Wiring, short to positive, pressure control solenoid, ECM/TCM P0972 Shift solenoid (SS) A – control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM P0973 Shift solenoid (SS) A – control circuit low Wiring, short to ground, shift solenoid, ECM/TCM P0974 Shift solenoid (SS) A – control circuit high Wiring, short to positive, shift solenoid, ECM/TCM P0975 Shift solenoid (SS) B – control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM P0976 Shift solenoid (SS) B – control circuit low Wiring, short to ground, shift solenoid, ECM/TCM P0977 Shift solenoid (SS) B – control circuit high Wiring, short to positive, shift solenoid, ECM/TCM P0978 Shift solenoid (SS) C – control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM P0979 Shift solenoid (SS) C – control circuit low Wiring, short to ground, shift solenoid, ECM/TCM P0980 Shift solenoid (SS) C – control circuit high Wiring, short to positive, shift solenoid, ECM/TCM P0981 Shift solenoid (SS) D – control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM P0982 Shift solenoid (SS) D – control circuit low Wiring, short to ground, shift solenoid, ECM/TCM P0983 Shift solenoid (SS) D – control circuit high Wiring, short to positive, shift solenoid, ECM/TCM P0984 Shift solenoid (SS) E – control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM P0985 Shift solenoid (SS) E – control circuit low Wiring, short to ground, shift solenoid, ECM/TCM P0986 Shift solenoid (SS) E – control circuit high Wiring, short to positive, shift solenoid, ECM/TCM P0987 Transmission fluid pressure (TFP) sensor E – circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E – circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0988 Transmission fluid pressure (TFP) sensor E – circuit range/performance Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E – circuit range/performance Wiring, poor connection, TFP switch, ECM/TCM P0989 Transmission fluid pressure (TFP) sensor E – circuit low Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E – circuit low Wiring, short to ground, TFP switch, ECM/TCM P0990 Transmission fluid pressure (TFP) sensor E – circuit high Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E – circuit high Wiring, short to positive, TFP switch, ECM/TCM P0991 Transmission fluid pressure (TFP) sensor E – circuit intermittent Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch E – circuit intermittent Wiring, poor connection, TFP switch, ECM/TCM P0992 Transmission fluid pressure (TFP) sensor F – circuit malfunction Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F – circuit malfunction Wiring, poor connection, TFP switch, ECM/TCM P0993 Transmission fluid pressure (TFP) sensor F – circuit range/performance Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F – circuit range/performance Wiring, poor connection, TFP switch, ECM/TCM P0994 Transmission fluid pressure (TFP) sensor F – circuit low Wiring, short to ground, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F – circuit low Wiring, short to ground, TFP switch, ECM/TCM P0995 Transmission fluid pressure (TFP) sensor F – circuit high Wiring, short to positive, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F – circuit high Wiring, short to positive, TFP switch, ECM/TCM P0996 Transmission fluid pressure (TFP) sensor F – circuit intermittent Wiring, poor connection, TFP sensor, ECM/TCM Transmission fluid pressure (TFP) switch F – circuit intermittent Wiring, poor connection, TFP switch, ECM/TCM P0997 Shift solenoid (SS) F – control circuit range/performance Wiring, poor connection, shift solenoid, ECM/TCM P0998 Shift solenoid (SS) F – control circuit low Wiring, short to ground, shift solenoid, ECM/TCM P0999 Shift solenoid (SS) F – control circuit high Wiring, short to positive, shift solenoid, ECM/TCM P1100 Map Sensor - Malfunction P1101 Map Sensor - Abnormal P1102 Map Sensor - Low Input P1103 Map Sensor - High Input P1104 Air Flow P1105 Air Flow - Abnormal P1106 Air Flow - Low Input P1107 Air Flow - High Input P1108 Fuel Pump P1109 Fuel Pump - Abnormal P1110 Fuel Pump - Stuck On P1110 ETS System - Malfunction P1111 Fuel Pump - Electrical P1112 Manifold Differential Pressure Sensor P1112 VGT Actuator - Malfunction P1113 Manifold Differential Pressure Sensor - Abnormal P1114 Manifold Differential Pressure Sensor - Low P1115 Coolant Temperature Input - Abnormal P1116 Boost Pressure Sensor - Malfunction P1118 ETS Motor - Malfunction P1119 Inlet Metering Valve Control P1120 Electric Governor - Malfunction P1120 Inlet Metering Valve Malfunction P1121 APS PWM Output Circuit Malfunction P1121 Throttle Position Input - Abnormal P1122 Boost Pressure Control Valve P1123 Fuel System Rich - Idle P1123 Timer Position Sensor - Malfunction P1124 Fuel System Lean - Idle P1125 Fuel Press Sensor1 P1126 Fuel Press Sensor2 P1127 Fuel System Rich - Part Load P1127 Control Sleeve Position Sensor P1128 Fuel System Lean - Part Load P1130 Start Solenoid- Malfunction P1131 Injection Quantity Adjust P1134 O2s Transition Time(B1/S1) P1135 Injection Timing Servo P1140 Inlet Air Temperature Sensor Malfunction P1141 Slow Duty Solenoid- Malfunction P1145 Main Duty Solenoid- Malfunction P1146 Idle Co Potentiometer P1147 Accelerator Position Sensor (ETS) Circuit P1150 Barometric Pressure Sensor Malfunction P1151 Accelerator Position Sensor (EMS) Circuit P1152 Accelerator Position Circuit-Low Input P1153 Accelerator Position Circuit-High Input P1154 O2s Transition Time(B2/S1) P1155 Limp Home Valve- Malfunction P1159 Variable Induction System P1162 High Pressure Pump & Fuel Line P1166 O2s (B1) Control Adaptation P1166 Limit O2s Lambda Control (B1) P1167 O2s (B2) Control Adaptation P1167 Limit O2s Lambda Control (B2) P1168 O2s (B1/S2) Heater Power P1169 O2s (B2/S2) Heater Power P1170 ECM (Barometric Pressure Sensor) P1171 ETS Valve Stuck - Open P1172 ETS Improper Motor Current P1173 ETS Target Following Malfunction P1174 ETS Valve Stuck - Close #1 P1175 ETS Valve Stuck - Close #2 P1176 ETS Motor Open/Short #1 P1177 ETS Motor Open/Short #2 P1178 ETS Motor Power - Open P1179 ETS Position F/B-Mismatch P1180 O2 S1 Heater Circuit- Malfunction P1180 Fuel Pressure Regulator - Malfunction P1181 Fuel Pressure Monitoring P1182 O2 S2 Heater Circuit - Malfunction P1182 Fuel Pressure Regulator - Short P1183 Fuel Pressure Regulator - Open P1184 O2s No Activity (B1/S2) P1184 Fuel Pressure Regulator - Power P1185 Fuel Position - Excessive P1186 Fuel Pressure - Too Low P1187 Regulator Valve - Stuck P1188 Fuel Pressure - Leakage P1189 Governor Deviation P1190 Intake Throttle Actuator P1191 ETS Limp Home Valve On P1192 Limp home - Target Follow Malfunction P1193 ETS Limp Home - Low Rpm P1194 Limp Home - TPS2 Position Malfunction P1195 Limp Home - Target Follow Delay P1196 ETS Limp Home - Close Stuck P1300 Spark Timing Adjust Signal P1300 Injector Specific Data Fault P1300 Synchronization Error-CKP/CMP P1301 TDC Sensor - Abnormal P1302 TDC Sensor - Low Input P1303 TDC Sensor - High Input P1304 Phase Sensor P1305 Phase Sensor - Abnormal P1306 Phase Sensor - Low Input P1307 Phase Sensor - High Input P1307 Accelerator Sensor - Range/Performance P1308 Ignition Coil.1 P1308 Accelerator Sensor - Low P1308 Accelerator Sensor Circuit - Low P1309 Ignition Coil.1 - Abnormal P1309 Accelerator Sensor - High P1309 Accelerator Sensor Circuit - High P1310 Ignition Coil.1 - Low Output P1310 Injection Control Circuit Fault P1311 Ignition Coil.1 - High Output P1312 Ignition Coil.2 P1313 Ignition Coil.2 - Abnormal P1314 Ignition Coil.2 - Low Output P1315 Ignition Coil.2 - High Output P1316 Ignition Coil.3 P1317 Ignition Coil.3 - Abnormal P1318 Ignition Coil.3 - Low Output P1319 Ignition Coil.3 - High Output P1320 Ignition Coil.4 P1321 Ignition Coil.4 - Abnormal P1321 Glow Indicator Lamp - Short P1322 Ignition Coil.4 - Low Output P1322 Glow Indicator Lamp - Open P1323 Ignition Coil.4 - High Output P1324 Glow Relay - Malfunction P1325 Glow Relay - Abnormal P1325 Glow Relay P1326 Glow Relay - Stuck On P1326 Glow Relay - Short P1327 Glow Relay - Electrical P1327 Glow Relay - Open P1330 Spark Timing Adjust Signal P1331 #1 MF Signal Line Short P1332 #2 MF Signal Line Short P1333 #3 MF Signal Line Short P1334 #4 MF Signal Line Short P1335 #5 MF Signal Line Short P1336 #6 MF Signal Line Short P1337 #7 MF Signal Line Short P1338 #8 MF Signal Line Short P1340 IFS 2 Open P1341 #1 Ion Line Open P1342 #2 Ion Line Open P1343 #3 Ion Line Open P1344 #4 Ion Line Open P1345 #5 Ion Line Open P1346 #6 Ion Line Open P1347 #7 Ion Line Open P1348 #8 Ion Line Open P1351 #1 MF Signal Line Open P1352 #2 MF Signal Line Open P1353 #3 MF Signal Line Open P1354 #4 MF Signal Line Open P1355 #5 MF Signal Line Open P1356 #6 MF Signal Line Open P1357 #7 MF Signal Line Open P1358 #8 MF Signal Line Open P1372 Segment Time Incorrect P1400 Manifold Differential Pressure Sensor P1401 DMTL Performance P1402 DMTL Motor Circuit P1403 DMTL Valve Circuit P1404 DMTL Heater Circuit P1405 EGR Temperature Incorrect P1415 2nd Air Injection Insufficient (B1) P1416 Secondary Air Injection P1418 2nd Air Injection Insufficient (B2) P1419 2nd Air Injection Valve P1440 EVAP System-Vent Circuit P1440 Canister Valve Open/Short P1443 EVAP System - Tank Cap Missing P1458 A/C Switch Malfunction P1500 A/Con Switch P1500 Vehicle Speed Signal Malfunction P1500 Vehicle Speed Input - Abnormal P1501 Brake Switch P1502 Wheel Speed Sensor Circuit Malfunction P1503 Accelerator Switch P1503 Auto Cruise Control Switch P1504 Inhibitor Switch P1504 Auto Cruise Cancel P1505 Kick-Down Servo Switch P1505 Idle Speed Actuator (Open) - Open P1506 MPS P1506 Idle Speed Actuator (Open) - Short P1507 MPS - Abnormal P1507 Idle Speed Actuator (Close) - Open P1508 MPS - Low P1508 Idle Speed Actuator (Close) - Short P1509 MPS - High P1510 Idle Speed Actuator (Open) - Short P1510 ISC Circuit Open/Short P1511 ISC Open/Short Coil2 P1511 ISC Circuit Open/Short P1512 WTS - Low P1513 Idle Speed Actuator (Open) - Open P1514 Oil Temperature Sensor P1515 Oil Temperature Sensor - Abnormal P1515 ISA Coil1 Command Sig. Malfunction P1516 Oil Temperature Sensor - Low P1516 ISA Coil2 Command Sig. Malfunction P1517 Oil Temperature Sensor - High P1520 Generator Front Terminal Malfunction P1521 Power Steering Switch Circuit P1522 Battery P1522 Sensor Supply 1 Volt - Low P1523 Sensor Supply 1 Volt - High P1524 Sensor Supply 2 Volt - Low P1525 5v Source Voltage P1525 Sensor Supply 2 Volt - High P1526 Sensor Supply Voltage1 - Malfunction P1527 Sensor Supply Voltage2 - Malfunction P1529 TCM Mil On Request Signal P1529 Check TCM P1530 Maximum Vehicle Speed Limiting P1543 Brake Switch Signal Fault P1545 A/C Comp. Switch Open/Short P1552 Idle Speed Act.(Close) - Short P1553 Idle Speed Act.(Close) - Open P1555 Idle Co-Potentiometer Open/Short P1567 Fuel Pressure Valve Current - Low P1568 Fuel Pressure Valve Current - Hi P1569 Current-Pressure Control Valve P1569 Press Control Valve - Current P1586 MT/AT Encoding Sig. Error P1600 Serial Communication - Malfunction (With4A/T) P1601 ECM ‘L’ Line P1602 ECU-TCU Communication Line #1 Malfunction P1603 ECU-TCU Communication Line #2 Malfunction P1603 ECM-TCSCM Communication Line P1603 TCU Error P1603 CAN Communication Bus Off P1604 TPS Communication Malfunction P1604 No ID From ECU P1605 Rough Road Sensor Malfunction P1605 Acceleration Sensor - Malfunction P1606 Rough Road Sensor Not Ration P1606 Acceleration Sensor - Abnormal P1607 Vacuum Sol. Valve Stuck On P1607 ECM-ETS Communication Line - Malfunction P1607 ECM-ETS Communication Line - Malfunction P1608 Vacuum Solenoid Valve Electrical P1608 ECU Fault P1608 ETS-ECM Communication Line - Malfunction P1609 Immobilizer Communication - Malfunction P1610 Immobilizer - Smartra Error P1610 Sensor Reference Voltage Fault P1611 Mil Request Signal Low P1611 Immobilizer - Transponder Malfunction P1612 Ventilation Solenoid Valve Elec. P1612 Immobilizer - Smartra Malfunction P1613 ECM-Failure P1613 Immobilizer Communication Error P1613 Mil Request Line - High P1613 ECM-Malfunction P1613 ECM (Voltage Regulator) - Malfunction P1614 Mil Request Signal High P1614 ECU Software Fault P1614 ETS ECU - Malfunction P1614 ETS ECU - Malfunction P1615 ETS - ECM Malfunction P1616 Main Relay Malfunction P1619 Main Relay P1620 A/C Relay Malfunction P1620 A/C Comp. Relay - Short P1621 Fuel Cut Valve - Malfunction P1621 A/C Comp. Relay - Open P1622 A/C Control Circuit Failure P1622 A/C Relay - Malfunction P1622 A/C Comp. Relay - Malfunction P1623 Mil Open/Short P1623 Engine Check Lamp - Malfunction P1623 Radiator Cooling Fan - Malfunction P1624 Mil-On Request From TCM P1624 Cooling Fan Relay (Low) Cir P1624 Radiator Cooling Fan - Malfunction P1624 Cooling Fan Relay - Low P1625 A/C Condenser Fan - Malfunction P1625 Cooling Fan Relay (High) Circuit P1625 Cooling Fan Relay - High P1626 Immobilizer Indicator Malfunction P1627 A/C Condenser Fan P1628 Condenser Fan Circuit - Low P1629 Glow Indicator Lamp - Malfunction P1629 Condenser Fan Circuit - High P1630 CAN-Bus-Off P1630 Intercooler Fan - Malfunction P1631 Serial Communication Error - Password P1631 CAN-Time Out ECU P1632 TCS System Malfunction P1632 CAN Bus Off P1633 Immobilizer Status Lamp P1634 Cruise Control Lamp - Malfunction P1634 Auxiliary Heat Relay - Short/Open P1635 Water Heater Relay - Malfunction P1636 Voltage Regulator For Inject. P1638 ECM (Microcontroller) - Malfunction P1639 ECM (Monitoring ADC) - Malfunction P1640 VI Motor Open/Short Coil1 P1640 Main Relay Malfunction P1641 VI Motor Open/Short Coil2 P1642 Non Immobilizer ECU Equipped P1645 Booster Voltage - Operate Injector P1646 Booster Voltage - Too High P1647 Threshold 1 Voltage - Malfunction P1647 Booster Voltage -Too Low P1652 Ignition Switch - Malfunction P1653 After-Run Check Error P1660 Cruise Control Switch - Malfunction P1665 Power Stage Group A Malfunction. P1670 Power Stage Group B Malfunction P1670 Injector Classification P1672 Fan Relay Malfunction - Low Speed P1673 Fan Relay Malfunction - High Speed P1674 A/C Fan Relay Malfunction P1690 Immobilizer Smartra Error P1690 W/Heater Relay Fault P1691 Immobilizer Antenna Error P1692 Immobilizer - Indicator Lamp Error P1693 Mil Request Line - Malfunction P1693 Immobilizer Transponder P1694 Immobilizer ECU Signal Error P1695 Immobilizer EEPROM Error P1696 Immobilizer - Key Mismatched P1697 Invalid Tester Request P1698 Key ID. Not Valid P1700 A/T Gear Shift Malfunction P1701 TPS P1702 TPS - Abnormal P1702 TPS - Malfunction Adjustment P1702 TPS - Malfunction Adjustment P1703 TPS - Low Input P1703 TPS - Open/Short (Ground) P1703 TPS - Open/Short (Ground) P1704 TPS - High Input P1704 TPS - Short P1704 TPS - Short P1706 Inhibitor Switch P1707 Brake Switch P1707 Auto Cruise Brake Switch P1708 Accelerator Switch P1709 Kick-Down Servo Switch P1709 K/D Servo Switch - Open/Short P1710 Oil Temperature Sensor P1711 Oil Temperature Sensor Abnormal P1712 Oil Temperature Sensor Low Input P1713 Oil Temperature Sensor High Input P1714 Idle Switch P1715 A/C on Switch P1716 Steering Sensor P1717 Steering Sensor Abnormal P1717 Steer 1 Input Signal P1718 Steering Sensor Low Input P1718 Steer 2 Input Signal P1719 Steering Sensor High Input P1719 Steer N Input Signal P1721 Control Relay P1722 Control Relay - Abnormal P1723 Control Relay - Stuck On P1723 A/T Relay - Open/Short (Ground) P1723 A/T Relay - Open/Short (Ground) P1724 Control Relay - Electrical P1725 TOD Control Module Error P1726 TPS Input - Loss Of Signal P1727 TPS Input - Out Of Range P1728 EMC-Open/Short To Battery P1729 EMC-Short To Ground P1730 Front Speed Sensor - Low Input P1731 Front Speed Sensor - High P1732 Rear Speed Sensor - Low Input P1733 Rear Speed Sensor - High Input P1734 Speed Sensor Reference - Low P1735 Speed Sensor Reference - High P1736 Shift Motor - Open P1737 ECV Stick P1737 Shift Motor - Short To Ground P1738 Shift System Time Out P1739 General Position Encoder Fault P1740 Position1 - Short To Ground P1741 Position2 - Short To Ground P1742 Position3 - Short To Ground P1743 Position4 - Short To Ground P1744 Lock Up Clutch System P1744 Anomalous Vibration Occurrence P1745 TCM ‘K’ Line P1746 TCM ‘L’ Line P1747 TCU-ECU Communication Line #1 Malfunction P1748 TCU-ECU Communication Line2 Malfunction P1749 Serial Communication Link P1749 Serial Communication Link-Open/Short P1749 Serial Communication Link-Open/Short P1750 TPS Communication Malfunction P1750 Front Left Speed Sensor P1751 Not Defined DTC P1751 Front Right Speed Sensor P1752 Lamp ‘P’ P1752 Rear Left Speed Sensor P1753 Lamp ‘R’ P1753 Rear Right Speed Sensor P1754 Lamp ‘N’ P1755 Lamp ‘D’ P1756 Lamp ‘3’ P1757 Lamp ‘2’ P1758 Lamp ‘L’ P1759 Control Module - Check Sum P1760 Control Module - Programming P1761 Control Module - KAM P1762 Control Module - RAM P1763 Control Module - ROM P1764 Can Controller - Malfunction P1764 ECU-ITM CAN Communication Line P1765 Torque Reduction Request P1765 Torque Reduction Request P1765 TCS-ITM CAN Communication Line P1766 Torque Reduction Execution P1766 Torque Reduction Execution P1771 Shifting Position P1772 Selection Position P1773 Gearbox Input Speed Sensor P1774 CRC Sensor P1775 TCM-Malfunction P1776 Power Control Module- Malfunction P1777 PCM Output - Malfunction P1778 Electro Valve Output - Malfunction P1779 Stator Inhibit Relay - Malfunction P1780 Push-Pull Sensor P1780 Torque Reduction Required Signal P1781 Actuator P1782 Actuator Position Sensor P1786 Engine Rpm Output Circuit Malfunction P1791 TPS Input Circuit - Malfunction P1795 Ground Return Circuit - Malfunction P1795 Transfer High/Low Switch - Malfunction P1800 Immobilizer Antenna Error P1801 Immobilizer Transponder Error P1802 Immobilizer Antenna Error P1803 Immobilizer ECU Signal Error P1805 Immobilizer EEPROM Error P1805 EEPROM Error/VIN Mismatch P2096 Post Fuel Trim Too Lean-B1 P2097 Post Fuel Trim Too Rich-B1 P2120 Accelerator Position Circuit - Malfunction P2122 Accelerator Position Circuit - Low Input P2123 Accelerator Position Circuit - High Input P2125 Accelerator Position Circuit - Malfunction P2127 Accelerator Position Circuit - Low Input P2128 Accelerator Position Circuit - High Input P2187 Fuel System Too Lean At Idle P2188 Fuel Sys Too Rich At Idle P2191 Fuel Sys Too Lean At P-load P2192 Fuel Sys Too Rich At P-load P2195 L.O2s Signal Stuck - Lean (B1/S1) P2196 L.O2s Signal Stuck - Rich (B1/S1) P2231 O2s Signal & Heater - Short (B1/S1) P2237 L.O2s Pump. Circuit - Open (B1/S1) P2238 L.O2s Pump. Circuit - Low (B1/S1) P2239 L.O2s Pump. Circuit - High (B1/S1) P2243 L.O2s Reference Circuit (+) Open - (B1/S1) P2251 L.O2s Reference Circuit (-) Open - (B1/S1) P2297 L.O2s Out Of Range (B1/S1) P2414 L.O2s Exhaust Sample (B1/S1) P2626 L.O2s Pump Trim - Open (B1/S1)
Коды неисправностей стандарта OBDII
P0 1XX FUEL AND AIR METERING Измерители топлива и воздуха PO 100 MAF or VAF CIRCUIT MALFUNCTION Неисправность цепи датчика расхода воздуха PO 101 MAF or VAF CIRCUIT RANGE/PERF PROBLEM Выход сигнала из допустимого диапазона PO 102 MAF or VAF CIRCUIT LOW INPUT Низкий уровень выходного сигнала PO 103 MAF or VAF CIRCUIT HIGH INPUT Высокий уровень выходного сигнала PO 105 MAP/BARO CIRCUIT MALFUNCTION Неисправность датчика давления воздуха PO 106 MAP/BARO CIRCUIT RANGE/PERF PROBLEM Выход сигнала из допустимого диапазона PO 107 MAP/BARO CIRCUIT LOW INPUT Низкий уровень выходного сигнала PO 108 MAP/BARO CIRCUIT HIGH INPUT Высокий уровень выходного сигнала PO 110 IAT CIRCUIT MALFUNCTION Неисправность датчика температуры всасываемого воздуха PO 111 IAT RANGE/PERF PROBLEM Выход сигнала из допустимого диапазона PO 112 IAT CIRCUIT LOW INPUT Низкий уровень выходного сигнала PO 113 IAT CIRCUIT HIGH INPUT Высокий уровень выходного сигнала PO 115 ECT CIRCUIT MALFUNCTION Неисправность датчика температуры охлаждающей жидкости PO 116 ECT RANGE/PERF PROBLEM Выход сигнала из допустимого диапазона PO 117 ECT CIRCUIT LOW INPUT Низкий уровень выходного сигнала PO 118 ECT CIRCUIT HIGH INPUT Высокий уровень выходного сигнала PO 120 TPS SENSOR A CIRCUIT MALFUNCTION Неисправность датчика положения дроссельной заслонки PO 121 TPS SENSOR A RANGE/PERF PROBLEM Выход сигнала из допустимого диапазона PO 122 TPS SENS A CIRCUIT LOW INPUT Низкий уровень выходного сигнала PO 123 TPS SENS A CIRCUIT HIGH INPUT Высокий уровень выходного сигнала PO 125 LOW ECT FOR CLOSED LOOP FUEL CONTROL Низкая температуры охлаждающей жид. для упр.по замкн.контуру PO 130 02 SENSOR B1 S1 MALFUNCTION Датчик О2 В1 S1 несправен(Банк1) PO 131 02 SENSOR B1 S1 LOW VOLTAGE Датчик О2 В1 S1 имеет низкий уровень сигнала PO 132 02 SENSOR B1 S1 HIGH VOLTAGE Датчик О2 В1 S1 имеет высокий уровень сигнала PO 133 02 SENSOR B1 S1 SLOW RESPONSE Датчик О2 В1 S1 имеет медленный отклик на обогащение/обеднение PO 134 02 SENSOR B1 S1 CIRCUIT INACTIVE Цепь датчика О2 В1 S1 пассивна PO 135 02 SENSOR B1 S1 HEATER MALFUNCTION Нагреватель датчика О2 В1 S1 несправен PO 136 02 SENSOR B1 S2 MALFUNCTION Датчик О2 В1 S2 несправен PO 137 02 SENSOR B1 S2 LOW VOLTAGE Датчик О2 В1 S2 имеет низкий уровень сигнала PO 138 02 SENSOR B1 S2 HIGH VOLTAGE Датчик О2 В1 S2 имеет высокий уровень сигнала PO 139 02 SENSOR B1 S2 SLOW RESPONSE Датчик О2 В1 S2 имеет медленный отклик на обогащение/обеднение PO 140 02 SENSOR B1 S2 CIRCUIT INACTIVE Цепь датчика О2 В1 S2 пассивна PO 141 02 SENSOR B1 S2 HEATER MALFUNCTION Нагреватель датчика О2 В1 S2 несправен PO 142 02 SENSOR B1 S3 MALFUNCTION Датчик О2 В1 S3 несправен PO 143 02 SENSOR B1 S3 LOW VOLTAGE Датчик О2 В1 S3 имеет низкий уровень сигнала PO 144 02 SENSOR B1 S3 HIGH VOLTAGE Датчик О2 В1 S3 имеет высокий уровень сигнала PO 145 02 SENSOR B1 S3 SLOW RESPONSE Датчик О2 В1 S3 имеет медленный отклик на обогащение/обеднение PO 146 02 SENSOR B1 S3 CIRCUIT INACTIVE Цепь датчика О2 В1 S3 пассивна PO 147 02 SENSOR B1 S3 HEATER MALFUNCTION Нагреватель датчика О2 В1 S3 несправен PO 150 02 SENSOR B2 S1 CIRCUIT MALFUNCTION Датчик О2 В2 S1 несправен (Банк2) PO 151 02 SENSOR B2 S1 CKT LOW VOLTAGE Датчик О2 В2 S1 имеет низкий уровень сигнала PO 152 02 SENSOR B2 S1 CKT HIGH VOLTAGE Датчик О2 В2 S1 имеет высокий уровень сигнала PO 153 02 SENSOR B2 S1 CKT SLOW RESPONSE Датчик О2 В2 S1 имеет медленный отклик на обогащение/обеднение PO 154 02 SENSOR B2 S1 CIRCUIT INACTIVE Цепь датчика О2 В2 S1 пассивна PO 155 02 SENSOR B2 S1 HTR CKT MALFUNCTION Нагреватель датчика О2 В2 S1 несправен PO 156 02 SENSOR B2 S2 CIRCUIT MALFUNCTION Датчик О2 В2 S2 несправен PO 157 02 SENSOR B2 S2 CKT LOW VOLTAGE Датчик О2 В2 S2 имеет низкий уровень сигнала PO 158 02 SENSOR B2 S2 CKT HIGH VOLTAGE Датчик О2 В2 S2 имеет высокий уровень сигнала PO 159 02 SENSOR B2 S2 CKT SLOW RESPONSE Датчик О2 В2 S2 имеет медленный отклик на обогащение/обеднение PO 160 02 SENSOR B2 S2 CIRCUIT INACTIVE Цепь датчика О2 В2 S2 пассивна PO 161 02 SENSOR B2 S2 HTR CKT MALFUNCTION Нагреватель датчика О2 В2 S2 несправен PO 162 02 SENSOR B2 S3 CIRCUIT MALFUNCTION Датчик О2 В2 S3 несправен PO 163 02 SENSOR B2 S3 CKT LOW VOLTAGE Датчик О2 В2 S3 имеет низкий уровень сигнала PO 164 02 SENSOR B2 S3 CKT HIGH VOLTAGE Датчик О2 В2 S3 имеет высокий уровень сигнала PO 165 02 SENSOR B2 S3 CKT SLOW RESPONSE Датчик О2 В2 S3 имеет медленный отклик на обогащение/обеднение PO 166 02 SENSOR B2 S3 CIRCUIT INACTIVE Цепь датчика О2 В2 S3 пассивна PO 167 02 SENSOR B2 S3 HTR CKT MALFUNCTION Нагреватель датчика О2 В2 S3 несправен PO 170 BANK 1 FUEL TRIM MALFUNCTION Утечка топлива из топливной системы блока №1 PO 171 BANK 1 SYSTEM TOO LEAN Блок цилиндров №1 беднит (возможно подсос воздуха) PO 172 BANK 1 SYSTEM TOO RICH Блок цилиндров №1 богатит (возможно неполное закрытие форсунки) PO 173 BANK 2 FUEL TRIM MALFUNCTION Утечка топлива из топливной системы блока №2 PO 174 BANK 2 SYSTEM TOO LEAN Блок цилиндров №2 беднит (возможно подсос воздуха) PO 175 BANK 2 SYSTEM TOO RICH Блок цилиндров №2 богатит (возможно неполное закрытие форсунки) PO 176 FUEL COMPOSITION SENSOR MALFUNCTION Датчик выброса СНх неисправен PO 177 FUEL COMPOSITION SENS CKT RANGE/PERF Сигнал датчика выходит из допустимого диапазона PO 178 FUEL COMPOSITION LOW INPUT Низкий уровень сигнала датчика СНх PO 179 FUEL COMPOSITION HIGH INPUT Высокий уровень сигнала датчика СНх PO 180 FUEL TEMP SENSOR A CIRCUIT MALFUNCTION Цепь датчика температуры топлива «А» неисправна PO 181 FUEL TEMP SENSOR A CIRCUIT RANGE/PERF Сигнал датчика «А» выходит из допустимого диапазона PO 182 FUEL TEMP SENSOR A LOW INPUT Низкий сигнал датчика температуры топлива «А» PO 183 FUEL TEMP SENSOR A HIGH INPUT Высокий сигнал датчика температуры топлива «А» PO 185 FUEL TEMP SENSOR B CIRCUIT MALFUNCTION Цепь датчика температуры топлива «В» неисправна PO 186 FUEL TEMP SENSOR RANGE/PERF Сигнал датчика «В» выходит из допустимого диапазона PO 187 FUEL TEMP SENSOR B LOW INPUT Низкий сигнал датчика температуры топлива «В» PO 188 FUEL TEMP SENSOR B HIGH INPUT Высокий сигнал датчика температуры топлива «В» PO 190 FUEL RAIL PRESSURE CIRCUIT MALFUNCTION Цепь датчика давления топлива в топливной рампе неисправна PO 191 FUEL RAIL CIRCUIT RANGE/PERF Сигнал датчика выходит из допустимого диапазона PO 192 FUEL RAIL PRESSURE LOW INPUT Низкий сигнал датчика давления топлива PO 193 FUEL RAIL PRESSURE HIGH INPUT Высокий сигнал датчика давления топлива PO 194 FUEL RAIL PRESSURE CKT INTERMITTENT Сигнал датчика давления топлива перемежающийся PO 195 ENGINE OIL TEMP SENSOR MALFUNCTION Цепь датчика температуры масла в двигателе неисправна PO 196 ENGINE OIL TEMP SENSOR RANGE/PERF Сигнал датчика выходит из допустимого диапазона PO 197 ENGINE OIL TEMP SENSOR LOW Низкий сигнал датчика температуры масла PO 198 ENGINE OIL TEMP SENSOR HIGH Высокий сигнал датчика температуры масла PO 199 ENGINE OIL TEMP SENSOR INTERMITTENT Сигнал датчика температуры масла перемежающийся PO 2XX FUEL AND AIR METERING PO 200 INJECTOR CIRCUIT MALFUNCTION Цепь управления форсункой неисправна PO 201 INJECTOR CIRCUIT MALFUNCTION CYL 1 Цепь управления форсункой цилиндра №1 неисправна PO 202 INJECTOR CIRCUIT MALFUNCTION CYL 2 Цепь управления форсункой цилиндра №2 неисправна PO 203 INJECTOR CIRCUIT MALFUNCTION CYL 3 Цепь управления форсункой цилиндра №3 неисправна PO 204 INJECTOR CIRCUIT MALFUNCTION CYL 4 Цепь управления форсункой цилиндра №4 неисправна PO 205 INJECTOR CIRCUIT MALFUNCTION CYL 5 Цепь управления форсункой цилиндра №5 неисправна PO 206 INJECTOR CIRCUIT MALFUNCTION CYL 6 Цепь управления форсункой цилиндра №6 неисправна PO 207 INJECTOR CIRCUIT MALFUNCTION CYL 7 Цепь управления форсункой цилиндра №7 неисправна PO 208 INJECTOR CIRCUIT MALFUNCTION CYL 8 Цепь управления форсункой цилиндра №8 неисправна PO 209 INJECTOR CIRCUIT MALFUNCTION CYL 9 Цепь управления форсункой цилиндра №9 неисправна PO 210 INJECTOR CIRCUIT MALFUNCTION CYL 10 Цепь управления форсункой цилиндра №10 неисправна PO 211 INJECTOR CIRCUIT MALFUNCTION CYL 11 Цепь управления форсункой цилиндра №11 неисправна PO 212 INJECTOR CIRCUIT MALFUNCTION CYL 12 Цепь управления форсункой цилиндра №12 неисправна PO 213 COLD START INJ N0.1 MALFUNCTION Цепь управления форсункой холодного старта №1 неисправна PO 214 COLD START INJ N0.2 MALFUNCTION Цепь управления форсункой холодного старта №2 неисправна PO 215 ENGINE SHUTOFF SOL MALFUNCTION Соленоид выключения двигателя неисправен PO 216 INJ TIMING CONTROL CIRCUIT MALFUNCTION Цепь контроля времени впрыска неисправна PO 217 ENGINE OVERTEMP CONDITION Двигатель находится в перегретом состоянии PO 218 TRANSMISSION OVERTEMP CONDITION Трансмиссия находится в перегретом состоянии PO 219 ENGINE OVERSPEED CONDITION Двигатель перекручен PO 220 TPS SENSOR B CIRCUIT MALFUNCTION Неисправность датчика положения дроссельной заслонки «В» PO 221 TPS SENSOR B CIRCUIT RANGE/PERF Выход сигнала из допустимого диапазона PO 222 TPS SENSOR B LOW INPUT Низкий уровень выходного сигнала датчика «В» PO 223 TPS SENSOR B HIGH INPUT Высокий уровень выходного сигнала датчика «В» PO 224 TPS SENSOR B CKT INTERMITTENT Сигнал датчика «В» перемежающийся PO 225 TPS SENSOR C CIRCUIT MALFUNCTION Неисправность датчика положения дроссельной заслонки «С» PO 226 TPS SENSOR C CIRCUIT RANGE/PERF Выход сигнала из допустимого диапазона PO 227 TPS SENSOR C LOW INPUT Низкий уровень выходного сигнала датчика «С» PO 228 TPS SENSOR C HIGH INPUT Высокий уровень выходного сигнала датчика «С» PO 229 TPS SENSOR C CKT INTERMITTENT Сигнал датчика «С» перемежающийся PO 230 FUEL PUMP PRIMARY CIRCUIT MALFUNCTION Первичная цепь бензонасоса (управление реле бензонас.) неисправна PO 231 FUEL PUMP SECONDARY CIRCUIT LOW Вторичная цепь бензонасоса имеет постоянно низкий уровень PO 232 FUEL PUMP SECONDARY CIRCUIT HIGH Вторичная цепь бензонасоса имеет постоянно высокий уровень PO 233 FUEL PUMP SECONDARY CKT INTERMITTENT Вторичная цепь бензонасоса имеет перемежающийся уровень PO 235 TURBO BOOST SENSOR A CIRCUIT MALFUNCTION Цепь датчика давления турбо-наддува «А» неисправен PO 236 TURBO BOOST SENSOR A CIRCUIT RANGE/PERF Сигнал с датчика турбины «А» выходит из допустимого диапазона PO 237 TURBO BOOST SENSOR A CIRCUIT LOW Сигнал с датчика турбины «А» имеет постоянно низкий уровень PO 238 TURBO BOOST SENSOR A CIRCUIT HIGH Сигнал с датчика турбины «А» имеет постоянно высокий уровень PO 239 TURBO BOOST SENSOR B CIRCUIT MALFUNCTION Цепь датчика давления турбо-наддува «Б» неисправен PO 240 TURBO BOOST SENSOR B CIRCUIT RANGE/PERF Сигнал с датчика турбины «Б» выходит из допустимого диапазона PO 241 TURBO BOOST SENSOR B CIRCUIT LOW Сигнал с датчика турбины «Б» имеет постоянно низкий уровень PO 242 TURBO BOOST SENSOR B CIRCUIT HIGH Сигнал с датчика турбины «Б» имеет постоянно высокий уровень PO 243 TURBO WASTEGATE A SOLENOID MALFUNC Соленоид затвора выхлопных газов турбины «А» неисправен PO 244 TURBO WASTEGATE A SOLENOID RANGE/PERF Сигнал соленоида турбины «А» выходит из допустимого диапазона PO 245 TURBO WASTEGATE A SOLENOID LOW Соленоид выхлопных газов турбины «А» всегда закрыт PO 246 TURBO WASTEGATE A SOLENOID HIGH Соленоид выхлопных газов турбины «А» всегда открыт PO 247 TURBO WASTEGATE B SOLENOID MALFUNC Соленоид выхлопных газов турбины «В» неисправен PO 248 TURBO WASTEGATE B SOLENOID RANGE/PERF Сигнал соленоида турбины «В» выходит из допустимого диапазона PO 249 TURBO WASTEGATE B SOLENOID LOW Соленоид выхлопных газов турбины «В» всегда закрыт PO 250 TURBO WASTEGATE B SOLENOID HIGH Соленоид выхлопных газов турбины «В» всегда открыт PO 251 INJECTION PUMP A ROTOR/CAM MALFUNCTION Насос впрыска турбины «А» неисправен PO 252 INJECTION PUMP A ROTOR/CAM RANGE/PERF Сигнал насоса впрыска турбины «А» выходит из доп. диапазона PO 253 INJECTION PUMP A ROTOR/CAM LOW Сигнал насоса впрыска турбины «А» имеет низкий уровень PO 254 INJECTION PUMP A ROTOR/CAM HIGH Сигнал насоса впрыска турбины «А» имеет высокий уровень PO 255 INJECTION PUMP A ROTOR/CAM INTERMIT Сигнал насоса впрыска турбины «А» перемежающийся PO 256 INJECTION PUMP B ROTOR/CAM MALFUNCTION Насос впрыска турбины «В» неисправен PO 257 INJECTION PUMP B ROTOR/CAM RANGE/PERF Сигнал насоса впрыска турбины «В» выходит из доп. диапазона PO 258 INJECTION PUMP B ROTOR/CAM LOW Сигнал насоса впрыска турбины «В» имеет низкий уровень PO 259 INJECTION PUMP B ROTOR/CAM HIGH Сигнал насоса впрыска турбины «В» имеет высокий уровень PO 260 INJECTION PUMP B ROTOR/CAM INTERMIT Сигнал насоса впрыска турбины «В» перемежающийся PO 261 INJ CYLINDER 1 CIRCUIT LOW Форсунка 1-ого цилиндра замкнута на землю PO 262 INJ CYLINDER 1 CIRCUIT HIGH Форсунка 1-ого цилиндра оборвана или замкнута на +12В PO 263 CYLINDER 1 CONTRIB/BAL FAULT Драйвер форсунки 1-ого цилиндра неисправен PO 264 INJ CYLINDER 2 CIRCUIT LOW Форсунка 2-ого цилиндра замкнута на землю PO 265 INJ CYLINDER 2 CIRCUIT HIGH Форсунка 2-ого цилиндра оборвана или замкнута на +12В PO 266 CYLINDER 2 CONTRIB/BAL FAULT Драйвер форсунки 2-ого цилиндра неисправен PO 267 INJ CYLINDER 3 CIRCUIT LOW Форсунка 3-го цилиндра замкнута на землю PO 268 INJ CYLINDER 3 CIRCUIT HIGH Форсунка 3-го цилиндра оборвана или замкнута на +12В PO 269 CYLINDER 3 CONTRIB/BAL FAULT Драйвер форсунки 3-го цилиндра неисправен PO 270 INJ CYLINDER 4 CIRCUIT LOW Форсунка 4-ого цилиндра замкнута на землю PO 271 INJ CYLINDER 4 CIRCUIT HIGH Форсунка 4-ого цилиндра оборвана или замкнута на +12В PO 272 CYLINDER 4 CONTRIB/BAL FAULT Драйвер форсунки 4-ого цилиндра неисправен PO 273 INJ CYLINDER 5 CIRCUIT LOW Форсунка 5-ого цилиндра замкнута на землю PO 274 INJ CYLINDER 5 CIRCUIT HIGH Форсунка 5-ого цилиндра оборвана или замкнута на +12В PO 275 CYLINDER 5 CONTRIB/BAL FAULT Драйвер форсунки 5-ого цилиндра неисправен PO 276 INJ CYLINDER 6 CIRCUIT LOW Форсунка 6-ого цилиндра замкнута на землю PO 277 INJ CYLINDER 6 CIRCUIT HIGH Форсунка 6-ого цилиндра оборвана или замкнута на +12В PO 278 CYLINDER 6 CONTRIB/BAL FAULT Драйвер форсунки 6-ого цилиндра неисправен PO 279 INJ CYLINDER 7 CIRCUIT LOW Форсунка 7-ого цилиндра замкнута на землю PO 280 INJ CYLINDER 7 CIRCUIT HIGH Форсунка 7-ого цилиндра оборвана или замкнута на +12В PO 281 CYLINDER 7 CONTRIB/BAL FAULT Драйвер форсунки 7-ого цилиндра неисправен PO 282 INJ CYLINDER 8 CIRCUIT LOW Форсунка 8-ого цилиндра замкнута на землю PO 283 INJ CYLINDER 8 CIRCUIT HIGH Форсунка 8-ого цилиндра оборвана или замкнута на +12В PO 284 CYLINDER 8 CONTRIB/BAL FAULT Драйвер форсунки 8-ого цилиндра неисправен PO 285 INJ CYLINDER 9 CIRCUIT LOW Форсунка 9-ого цилиндра замкнута на землю PO 286 INJ CYLINDER 9 CIRCUIT HIGH Форсунка 9-ого цилиндра оборвана или замкнута на +12В PO 287 CYLINDER 9 CONTRIB/BAL FAULT Драйвер форсунки 9-ого цилиндра неисправен PO 288 INJ CYLINDER 10 CIRCUIT LOW Форсунка 10-ого цилиндра замкнута на землю PO 289 INJ CYLINDER 10 CIRCUIT HIGH Форсунка 10-ого цилиндра оборвана или замкнута на +12В PO 290 CYLINDER 10 CONTRIB/BAL FAULT Драйвер форсунки 10-ого цилиндра неисправен PO 291 INJ CYLINDER 11 CIRCUIT LOW Форсунка 11-ого цилиндра замкнута на землю PO 292 INJ CYLINDER 11 CIRCUIT HIGH Форсунка 11-ого цилиндра оборвана или замкнута на +12В PO 293 CYLINDER 11 CONTRIB/BAL FAULT Драйвер форсунки 11-ого цилиндра неисправен PO 294 INJ CYLINDER 12 CIRCUIT LOW Форсунка 12-ого цилиндра замкнута на землю PO 295 INJ CYLINDER 12 CIRCUIT HIGH Форсунка 12-ого цилиндра оборвана или замкнута на +12В PO 296 CYLINDER 12 CONTRIB/BAL FAULT Драйвер форсунки 12-ого цилиндра неисправен PO 3XX IGNITION SYSTEM OR MISFIRE Система зажигания и пропуски PO 300 RANDOM/MULTIPLE MISFIRE DETECTED Обнаружены случайные/множественные пропуски зажигания PO 301 CYLINDER 1 MISFIRE DETECTED Обнаружены пропуски зажигания в 1-ом цилиндре PO 302 CYLINDER 2 MISFIRE DETECTED Обнаружены пропуски зажигания во 2-ом цилиндре PO 303 CYLINDER 3 MISFIRE DETECTED Обнаружены пропуски зажигания в 3-ем цилиндре PO 304 CYLINDER 4 MISFIRE DETECTED Обнаружены пропуски зажигания в 4-ом цилиндре PO 305 CYLINDER 5 MISFIRE DETECTED Обнаружены пропуски зажигания в 5-ом цилиндре PO 306 CYLINDER 6 MISFIRE DETECTED Обнаружены пропуски зажигания в 6-ом цилиндре PO 307 CYLINDER 7 MISFIRE DETECTED Обнаружены пропуски зажигания в 7-ом цилиндре PO 308 CYLINDER 8 MISFIRE DETECTED Обнаружены пропуски зажигания в 8-ом цилиндре PO 309 CYLINDER 9 MISFIRE DETECTED Обнаружены пропуски зажигания в 9-ом цилиндре PO 310 CYLINDER 10 MISFIRE DETECTED Обнаружены пропуски зажигания в 10-ом цилиндре PO 311 CYLINDER 11 MISFIRE DETECTED Обнаружены пропуски зажигания в 11-ом цилиндре PO 312 CYLINDER 12 MISFIRE DETECTED Обнаружены пропуски зажигания в 12-ом цилиндре PO 320 IGN/DIST RPM CKT INPUT MALFUNCTION Цепь распределителя зажигания неисправна PO 321 IGN/DIST RPM CKT RANGE/PERFORMANCE Сигнал цепи распределителя зажигания выходит за доп. пределы PO 322 IGN/DIST RPM CKT NO SIGNAL Сигнал цепи распределителя зажигания отсутствует PO 323 IGN/DIST RPM CKT INTERMITTENT Сигнал цепи распределителя зажигания перемежающийся PO 325 KNOCK SENSOR 1 CIRCUIT MALFUNCTION Цепь датчика детонации №1 неисправна PO 326 KNOCK SENSOR 1 RANGE/PERFORMANCE Сигнал датчика детонации №1 выходит за допустимые пределы PO 327 KNOCK SENSOR 1 LOW INPUT Сигнал датчика детонации №1 имеет низкий уровень PO 328 KNOCK SENSOR 1 HIGH INPUT Сигнал датчика детонации №1 имеет высокий уровень PO 329 KNOCK SENSOR 1 INTERMITTENT Сигнал датчика детонации №1 перемежающийся PO 330 KNOCK SENSOR 2 CIRCUIT MALFUNCTION Цепь датчика детонации №2 неисправна PO 331 KNOCK SENSOR 2 RANGE/PERFORMANCE Сигнал датчика детонации №2 выходит за допустимые пределы PO 332 KNOCK SENSOR 2 LOW INPUT Сигнал датчика детонации №2 имеет низкий уровень PO 333 KNOCK SENSOR 2 HIGH INPUT Сигнал датчика детонации №2 имеет высокий уровень PO 334 KNOCK SENSOR 2 INTERMITTENT Сигнал датчика детонации №2 перемежающийся PO 335 CRANKSHAFT POSITION SENS A MALFUNC Датчик положения коленчатого вала «А» неисправен PO 336 CRANKSHAFT POS A RANGE/PERFORMANCE Сигнал датчика «А» выходит за допустимые пределы PO 337 CRANKSHAFT POSITION SENSOR A LOW INPUT Сигнал датчика «А» имеет низкий уровень или замкнут на массу PO 338 CRANKSHAFT POSITION SENSOR A HIGH INPUT Сигнал датчика «А» имеет высокий уровень или замкнут на 12В PO 339 CRANKSHAFT POS A SENSOR INTERMITTENT Сигнал датчика «А» перемежающийся PO 340 CAMSHAFT POSITION SENSOR MALFUNCTION Датчик положения распределительного вала неисправен PO 341 CAMSHAFT POSITION RANGE/PERFORMANCE Сигнал датчика выходит за допустимые пределы PO 342 CAMSHAFT POSITION SENSOR LOW INPUT Сигнал датчика имеет низкий уровень или замкнут на массу PO 343 CAMSHAFT POSITION SENSOR HIGH INPUT Сигнал датчика имеет высокий уровень PO 344 CAMSHAFT POSITION SENSOR INTERMITTENT Сигнал датчика перемежающийся PO 350 IGN COIL PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания неисправны PO 351 IGN COIL A PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «А» неисправны PO 352 IGN COIL B PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «B» неисправны PO 353 IGN COIL C PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «C» неисправны PO 354 IGN COIL D PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «D» неисправны PO 355 IGN COIL E PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «E» неисправны PO 356 IGN COIL F PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «F» неисправны PO 357 IGN COIL G PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «G» неисправны PO 358 IGN COIL H PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «H» неисправны PO 359 IGN COIL I PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «I» неисправны PO 360 IGN COIL J PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «J» неисправны PO 361 IGN COIL K PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «K» неисправны PO 362 IGN COIL L PRI/SEC CIRCUIT MALFUNCTION Первичная/вторичная цепи катушки зажигания «L» неисправны PO 370 TIMING REF (HRS) A MALFUNCTION PO 371 TIMING REF (HRS) A TOO MANY PULSES PO 372 TIMING REF (HRS) A TOO MANY PULSES PO 373 TIMING REF (HRS) A INTERMITTENT PULSES PO 374 TIMING REF (HRS) A NO PULSES PO 375 TIMING REF (HRS) B MALFUNCTION PO 376 TIMING REF (HRS) B TOO MANY PULSES PO 377 TIMING REF (HRS) B TOO MANY PULSES PO 378 TIMING REF (HRS) B INTERMITTENT PULSES PO 379 TIMING REF (HRS) B NO PULSES PO 380 GLOW PLUG/HEATER CIRCUIT MALFUNCTION Свеча накаливания или цепь нагрева неисправны PO 381 GLOW PLUG/HEATER INDICATOR MALFUNC Свеча накаливания или индикатор нагрева неисправны PO 385 CRANKSHFT POS SEN B CIRCUIT MALFUNCTION Цепь датчика положения коленчатого вала «В» неисправны PO 386 CRANKSHFT POS SEN B RANGE/PERFORMANCE Сигнал датчика «В» выходит за допустимые пределы PO 387 CRANKSHFT POS SEN B CIRCUIT LOW INPUT Цепь датчика оборвана или замкнута на массу PO 388 CRANKSHFT POS SEN B CIRCUIT HIGH INPUT Цепь датчика замкнута на один из силовых выводов PO 389 CRANKSHFT POS SEN B CIRCUIT INTERMIT Сигнал датчика «В» перемежающийся PO 4XX AUXILIARY EMISSION CONTROLS PO 400 EGR FLOW MALFUNCTION Система рециркуляции отработанных газов неисправна PO 401 EGR FLOW INSUFFICIENT Система рециркуляции отработанных газов неэффективна PO 402 EGR FLOW EXCESSIVE Система рециркуляции отработанных газов избыточна PO 403 EGR CIRCUIT MALFUNCTION Цепь датчика рециркуляции отработанных газов неисправна PO 404 EGR RANGE/PERFORMANCE Сигнал датчика выходит за допустимые пределы PO 405 EGR SENSOR A CIRCUIT LOW Сигнал датчика «А» имеет низкий уровень PO 406 EGR SENSOR A CIRCUIT HIGH Сигнал датчика «А» имеет высокий уровень PO 407 EGR SENSOR B CIRCUIT LOW Сигнал датчика «В» имеет низкий уровень PO 408 EGR SENSOR B CIRCUIT HIGH Сигнал датчика «В» имеет высокий уровень PO 410 SECONDARY AIR INJ SYSTEM MALFUNCTION Система вторичной подачи (впрыска) воздуха неисправна PO 411 SECONDARY AIR INJ INCORRECT FLOW Ошибочный поток проходит через систему вторичной подачи воздуха PO 412 SECONDARY AIR INJ VALVE A MALFUNCTION Клапан системы вторичной подачи воздуха «А» неисправен PO 413 SECONDARY AIR INJ VALVE A OPEN Клапан системы вторичной подачи воздуха «А» всегда открыт PO 414 SECONDARY AIR INJ VALVE A SHORTED Клапан системы вторичной подачи воздуха «А» всегда закрыт PO 415 SECONDARY AIR INJ VALVE B MALFUNCTION Клапан системы вторичной подачи воздуха «В» неисправен PO 416 SECONDARY AIR INJ VALVE B OPEN Клапан системы вторичной подачи воздуха «В» всегда открыт PO 417 SECONDARY AIR INJ VALVE B SHORTED Клапан системы вторичной подачи воздуха «В» всегда закрыт PO 420 CAT SYS EFFIC B1 BELOW THRESHOLD Эффективность системы катализаторов «В1» ниже порога PO 421 WARM UP CAT EFFIC B1 BELOW THRESHOLD Эффективность прогрева катализатора «В1» ниже порога PO 422 MAIN CAT EFFIC B1 BELOW THRESHOLD Эффективность главного катализатора «В1» ниже порога PO 423 HEATED CAT EFFIC B1 BELOW THRESHOLD Эффективность нагревателя катализатора «В1» ниже порога PO 424 HEATED CAT TEMP B1 BELOW THRESHOLD Температура нагревателя катализатора «В2» ниже порога PO 430 CAT SYS EFFIC B2 BELOW THRESHOLD Эффективность системы катализаторов «В2» ниже порога PO 431 WARM UP CAT EFFIC B2 BELOW THRESHOLD Эффективность прогрева катализатора «В2» ниже порога PO 432 MAIN CAT EFFIC B2 BELOW THRESHOLD Эффективность главного катализатора «В2» ниже порога PO 433 HEATED CAT EFFIC B2 BELOW THRESHOLD Эффективность нагревателя катализатора «В2» ниже порога PO 434 HEATED CAT TEMP B2 BELOW THRESHOLD Температура нагревателя катализатора «В2» ниже порога PO 440 EVAP CONTROL SYSTEM MALFUNCTION Контроль системы улавливания паров бензина неисправен PO 441 EVAP CONTROL BAD PURGE FLOW Система улавливания паров бензина плохо продувается PO 442 EVAP CONTROL SMALL LEAK DETECTED Обнаружена небольшая утечка в системе улавливания паров PO 443 EVAP CONTROL PURGE CONT VALVE MALFUNC Управление клапаном продувки системы «EVAP» неисправен PO 444 EVAP PURGE VALVE CIRCUIT OPEN Клапан продувки системы «EVAP» всегда открыт PO 445 EVAP PURGE VALVE CIRCUIT SHORT Клапан продувки системы «EVAP» всегда закрыт PO 446 EVAP VENT CONTROL MALFUNCTION Управление воздушным клапаном системы «EVAP» неисправно PO 447 EVAP VENT CONTROL OPEN Воздушный клапан системы «EVAP» всегда открыт PO 448 EVAP VENT CONTROL SHORTED Воздушный клапан системы «EVAP» всегда закрыт PO 450 EVAP PRESS SENSOR MALFUNCTION Датчик давления паров бензина неисправен PO 451 EVAP CONTROL PRESS RANGE/PERFORMANCE Сигнал датчика давления паров бензина выходит за доп. диапазон PO 452 EVAP CONTROL PRESS SENSOR LOW INPUT Сигнал датчика давления паров бензина имеет низкий уровень PO 453 EVAP CONTROL PRESS SENSOR HIGH INPUT Сигнал датчика давления паров бензина имеет высокий уровень PO 454 EVAP CONTROL PRESS SENSOR INTERMITTENT Сигнал датчика давления паров бензина перемежающийся PO 455 EVAP CONTROL SYS GROSS LEAK DETECTED Обнаружена грубая утечка в системе улавливания паров PO 460 FUEL LEVEL SENSOR CIRCUIT MALFUNCTION Цепь датчика уровня топлива неисправна PO 461 FUEL LEVEL SENSOR RANGE/PERFORMANCE Сигнал датчика уровня топлива выходит за допустимые пределы PO 462 FUEL LEVEL SENSOR CIRCUIT LOW INPUT Сигнал датчика уровня топлива имеет низкий уровень PO 463 FUEL LEVEL SENSOR CIRCUIT HIGH INPUT Сигнал датчика уровня топлива имеет высокий уровень PO 464 FUEL LEVEL SENSOR CKT INTERMITTENT Сигнал датчика уровня топлива перемежающийся PO 465 PURGE FLOW SENSOR CIRCUIT MALFUNCTION Цепь датчика потока воздуха продувки неисправен PO 466 PURGE FLOW SENSOR RANGE/PERFORMANCE Сигнал датчика потока воздуха продувки выходит за доп. пределы PO 467 PURGE FLOW SENSOR CIRCUIT LOW INPUT Сигнал датчика потока воздуха продувки имеет низкий уровень PO 468 PURGE FLOW SENSOR CIRCUIT HIGH INPUT Сигнал датчика потока воздуха продувки имеет высокий уровень PO 469 PURGE FLOW SENSOR CKT INTERMITTENT Сигнал датчика потока воздуха продувки перемежающийся PO 470 EXHAUST PRESSURE SENSOR MALFUNCTION Датчик давления выхлопных газов неисправен PO 471 EXHAUST PRESSURE SENSOR RANGE/PERF Сигнал датчика давления выходит за доп. диапазон PO 472 EXHAUST PRESSURE SENSOR LOW Сигнал датчика давления имеет низкий уровень PO 473 EXHAUST PRESSURE SENSOR HIGH Сигнал датчика давления имеет высокий уровень PO 474 EXHAUST PRESSURE SENSOR INTERMIT Сигнал датчика давления перемежающийся PO 475 EXHAUST PRESS VALVE CONTROL MALFUNCTION Клапан датчика давления выхлопных газов неисправен PO 476 EXHAUST PRESS VALVE CONTROL RANGE/PERF Сигнал клапана датчика давления выходит за доп. диапазон PO 477 EXHAUST PRESS VALVE CONTROL LOW Сигнал клапана датчика давления имеет низкий уровень PO 478 EXHAUST PRESS VALVE CONTROL HIGH Сигнал клапана датчика давления имеет высокий уровень PO 479 EXHAUST PRESS VALVE CONTROL INTERMIT Сигнал клапана датчика давления перемежающийся PO 5XX VEHICLE SPEED, IDLE CONTROL AND AUXILIARY INPUTS PO 500 VSS SENSOR MALFUNCTION Датчик скорости автомобиля неисправен PO 501 VSS SENSOR RANGE/PERFORMANCE Сигнал датчика скорости автомобиля выходит за доп. пределы PO 502 VSS SENSOR CIRCUIT LOW INPUT Сигнал датчика скорости автомобиля имеет низкий уровень PO 503 VSS SENSOR INTERMIT/ERRATIC/HI Сигнал датчика перемежающийся или имеет высокий уровень PO 505 IDLE CONTROL SYSTEM MALFUNCTION Система поддержания холостого хода неисправна PO 506 IDLE CONTROL SYSTEM RPM TOO LOW Обороты двигателя под управлением системы слишком низкие PO 507 IDLE CONTROL SYSTEM RPM TOO HIGH Обороты двигателя под управлением системы слишком высокие PO 510 CLOSED TPS SWITCH MALFUNCTION Концевик индикации закрытого положения дросселя неисправен PO 530 A/C REFRIG PRESSURE SENSOR MALFUNCTION Датчик давления хладагента кондиционера неисправен PO 531 A/C REFRIG PRESSURE RANGE/PERFORMANCE Сигнал датчика давления хладагента выходит за доп. диапазон PO 532 A/C REFRIG PRESSURE SENSOR LOW INPUT Сигнал датчика давления хладагента имеет низкий уровень PO 533 A/C REFRIG PRESSURE SENSOR HIGH INPUT Сигнал датчика давления хладагента имеет высокий уровень PO 534 A/C REFRIGERANT CHARGE LOSS Большая потеря хладагента в кондиционере PO 550 PSP SENSOR CIRCUIT MALFUNCTION Датчик давления гидроусилителя руля неисправен PO 551 PSP SENSOR RANGE/PERFORMANCE Сигнал датчика давления выходит за допустимый диапазон PO 552 PSP SENSOR CIRCUIT LOW INPUT Сигнал датчика давления имеет низкий уровень PO 553 PSP SENSOR CIRCUIT HIGH INPUT Сигнал датчика давления имеет высокий уровень PO 554 PSP SENSOR CIRCUIT INTERMITTENT Сигнал датчика давления перемежающийся PO 560 SYSTEM VOLTAGE MALFUNCTION Датчик бортового напряжения неисправен PO 561 SYSTEM VOLTAGE UNSTABLE Бортовое напряжение нестабильно PO 562 SYSTEM VOLTAGE LOW Бортовое напряжение имеет низкий уровень PO 563 SYSTEM VOLTAGE HIGH Бортовое напряжение имеет высокий уровень PO 565 CRUISE CONTROL ON SIGNAL MALFUNCTION Цепь включения «круиз контроля» неисправна PO 566 CRUISE CONTROL OFF SIGNAL MALFUNCTION Цепь выключения «круиз контроля» неисправна PO 567 CRUISE CTRL RESUME SIGNAL MALFUNCTION Цепь продолжения работы «круиз контроля» неисправна PO 568 CRUISE CONTROL SET SIGNAL MALFUNCTION Цепь установки скорости «круиз контроля» неисправна PO 569 CRUISE CTRL COAST SIGNAL MALFUNCTION Цепь поддержки «наката» «круиз контроля» неисправна PO 570 CRUISE CTRL ACCEL SIGNAL MALFUNCTION Цепь поддержки «разгона» «круиз контроля» неисправна PO 571 CRUISE CTRL/BRK SW CKT A MALFUNCTION Переключатель включения тормозов «круиз контроля» неисправен PO 572 CRUISE CTRL/BRK SW CKT A LOW Переключатель всегда замкнут PO 573 CRUISE CTRL/BRK SW CKT A HIGH Переключатель всегда разомкнут PO 6XX COMPUTER AND AUXILIARY OUTPUTS PO 600 SERIAL COMM LINK MALFUNCTION Линия передачи последовательных данных неисправна PO 601 INTERNAL MEMORY CHECK SUM ERROR Ошибка контрольной суммы внутренней памяти PO 602 CONTROL MODULE PROGRAMMING ERROR Программная ошибка контрольного модуля PO 603 INTERN CONTROL MOD KAM ERROR Ошибка репрограммируемой памяти PO 604 INTERN CONTROL MOD RAM ERROR Ошибка оперативного запоминающего устройства PO 605 INTERN CONTROL MOD ROM ERROR Ошибка постоянного запоминающего устройства PO 606 PCM PROCESSOR FAULT Ошибка модуля управления энергосбережением PO 7XX TRANSMISSION PO 700 TRANS CONTROL SYS MALFUNCTION Система управления трансмиссией неисправна PO 701 TRANS CONTROL SYS RANGE/PERFORMANCE Система управления трансмиссией работает неверно PO 702 TRANS CONTROL SYSTEM ELECTRICAL PO 703 TORQ CONV/BRK SW B CKT MALFUNCTION Переключатель карданный вал/тормоза неисправен PO 704 CLUTCH SWITCH INPUT CIRCUIT MALFUNCTION Цепь датчика включения сцепления неисправен PO 705 TRANS RANGE SENSOR MALFUNCTION (PRNDL) Датчик диапазона работы трансмиссии неисправен PO 706 TRANS RANGE SENSOR RANGE/PERFORMANCE Сигнал датчика выходит за допустимые пределы PO 707 TRANS RANGE SENSOR CIRCUIT LOW INPUT Сигнал датчика имеет низкий уровень PO 708 TRANS RANGE SENSOR CIRCUIT HIGH INPUT имеет высокий уровень PO 709 TRANS RANGE SENSOR INTERMITTENT Сигнал датчика перемежающийся PO 710 TRANS FLUID TEMP SENSOR MALFUNCTION Датчик температуры трансмиссионной жидкости неисправен PO 711 TRANS FLUID TEMP RANGE/PERFRMANCE Сигнал датчика выходит за допустимые пределы PO 712 TRANS FLUID TEMP SENSOR LOW INPUT Сигнал датчика имеет низкий уровень PO 713 TRANS FLUID TEMP SENSOR HIGH INPUT имеет высокий уровень PO 714 TRANS FLUID TEMP CKT INTERMITTENT Сигнал датчика перемежающийся PO 715 INPUT/TURBINE SPEED SENSOR MALFUNCTION Датчик скорости турбины неисправен PO 716 INPUT/TURBINE SPEED RANGE/PERFORMANCE Сигнал датчика выходит за допустимые пределы PO 717 INPUT/TURBINE SPEED SENSOR NO SIGNAL Сигнал датчика отсутствует PO 718 INPUT/TURBINE SPEED SENSOR INTERMITTENT Сигнал датчика перемежающийся PO 719 TORQ CONV/BRK SW B CIRCUIT LOW Переключатель карданный вал/тормоза замкнут на массу PO 720 OUTPUT SPEED SENSOR CIRCUIT MALFUNCTION Цепь датчика «Внешней скорости» неисправна PO 721 OUTPUT SPEED SENSOR RANGE/PERFORMANCE Сигнал датчика «Внешней скорости» выходит за доп. пределы PO 722 OUTPUT SPEED SENSOR CIRCUIT NO SIGNAL Сигнал датчика «Внешней скорости» отсутствует PO 723 OUTPUT SPEED SENSOR CKT INTERMITTENT Сигнал датчика «Внешней скорости» перемежающийся PO 724 TORQ CONV/BRK SW B CIRCUIT HIGH Переключатель карданный вал/тормоза замкнут на питание PO 725 ENGINE SPEED SENSOR CIRCUIT MALFUNCTION Цепь датчика скорости вращения двигателя неисправен PO 726 ENGINE SPEED SENSOR RANGE/PERFORMANCE Сигнал датчика выходит за допустимые пределы PO 727 ENGINE SPEED SENSOR CIRCUIT NO SIGNAL Сигнал датчика отсутствует PO 728 ENGINE SPEED SENSOR CKT INTERMITTENT Сигнал датчика перемежающийся PO 730 GEAR RATIO INCORRECT Передаточное число трансмиссии неверно PO 731 GEAR 1 INCORRECT RATIO Передаточное число трансмиссии на 1 передаче неверно PO 732 GEAR 2 INCORRECT RATIO Передаточное число трансмиссии на 2 передаче неверно PO 733 GEAR 3 INCORRECT RATIO Передаточное число трансмиссии на 3 передаче неверно PO 734 GEAR 4 INCORRECT RATIO Передаточное число трансмиссии на 4 передаче неверно PO 735 GEAR 5 INCORRECT RATIO Передаточное число трансмиссии на 5 передаче неверно PO 736 REVERSE INCORRECT RATIO Передаточное число трансмиссии на передаче задн. хода неверно PO 740 TCC CIRCUIT MALFUNCTION Цепь управления блокировкой дифференциала неисправна PO 741 TCC PERF OR STUCK OFF Дифференциал всегда выключен (разблокирован) PO 742 TCC CIRCUIT STUCK ON Дифференциал всегда включен (заблокирован) PO 743 TCC CIRCUIT ELECTRICAL PO 744 TCC CIRCUIT INTERMITTENT Дифференциал состояние неустойчивое PO 745 PRESS CONTROL SOL MALFUNCTION Управление сжимающим соленоидом неисправно PO 746 PRESS CONT SOLENOID PERF OR STUCK OFF Соленоид всегда в выключенном состоянии PO 747 PRESSURE SOLENOID STUCK ON Соленоид всегда во включенном состоянии PO 748 PRESSURE CONTROL SOLENOID ELECTRICAL PO 749 PRESSURE CONTROL SOL INTERMITTENT Состояние соленоида неустойчиво PO 750 SHIFT SOLENOID A MALFUNCTION Соленоид «А» включения передачи неисправен PO 751 SHIFT SOLENOID A PERF OR STUCK OFF Соленоид «А» всегда в выключенном состоянии PO 752 SHIFT SOLENOID A STUCK ON Соленоид «А» всегда во включенном состоянии PO 753 SHIFT SOLENOID A ELECTRICAL PO 754 SHIFT SOLENOID A INTERMITTENT Состояние соленоида «А» неустойчиво PO 755 SHIFT SOLENOID B MALFUNCTION Соленоид «В» включения передачи неисправен PO 756 SHIFT SOLENOID B PERF OR STUCK OFF Соленоид «В» всегда в выключенном состоянии PO 757 SHIFT SOLENOID B STUCK ON Соленоид «В» всегда во включенном состоянии PO 758 SHIFT SOLENOID B ELECTRICAL PO 759 SHIFT SOLENOID B INTERMITTENT Состояние соленоида «В» неустойчиво PO 760 SHIFT SOLENOID C MALFUNCTION Соленоид «С» включения передачи неисправен PO 761 SHIFT SOLENOID C PERF OR STUCK OFF Соленоид «С» всегда в выключенном состоянии PO 762 SHIFT SOLENOID C STUCK ON Соленоид «С» всегда во включенном состоянии PO 763 SHIFT SOLENOID C ELECTRICAL PO 764 SHIFT SOLENOID C INTERMITTENT Состояние соленоида «С» неустойчиво PO 765 SHIFT SOLENOID D MALFUNCTION Соленоид «Д» включения передачи неисправен PO 766 SHIFT SOLENOID D PERF OR STUCK OFF Соленоид «Д» всегда в выключенном состоянии PO 767 SHIFT SOLENOID D STUCK ON Соленоид «Д» всегда во включенном состоянии PO 768 SHIFT SOLENOID D ELECTRICAL PO 769 SHIFT SOLENOID D INTERMITTENT Состояние соленоида «Д» неустойчиво PO 770 SHIFT SOLENOID E MALFUNCTION Соленоид «Е» включения передачи неисправен PO 771 SHIFT SOLENOID E PERF OR STUCK OFF Соленоид «Е» всегда в выключенном состоянии PO 772 SHIFT SOLENOID E STUCK ON Соленоид «Е» всегда во включенном состоянии PO 773 SHIFT SOLENOID E ELECTRICAL PO 774 SHIFT SOLENOID E INTERMITTENT Состояние соленоида «Е» неустойчиво PO 780 SHIFT MALFUNCTION Переключение передач не работает PO 781 1-2 SHIFT MALFUNCTION Переключение передач с 1-ой на 2-ю не работает PO 782 2-3 SHIFT MALFUNCTION Переключение передач со 2-й на 3-ю не работает PO 783 3-4 SHIFT MALFUNCTION Переключение передач с 3-й на 4-ю не работает PO 784 4-5 SHIFT MALFUNCTION Переключение передач с 4-й на 5-ю не работает PO 785 SHIFT/TIMING SOL MALFUNCTION Соленоид управления синхронизатором неисправен PO 786 SHIFT/TIMING SOL RANGE/PERFORMANCE PO 787 SHIFT/TIMING SOL LOW Соленоид управления синхронизатором всегда выключен PO 788 SHIFT/TIMING SOL HIGH Соленоид управления синхронизатором всегда включен PO 789 SHIFT/TIMING SOL INTERMITTENT Соленоид управления синхронизатором неустойчив PO 790 NORM/PERFORM SWITCH CIRCUIT MALFUNCTION Цепь переключателя режима движения неисправна
P1 291 HEATED AIR INTAKE На впуске перегретый воздух
P1 292 CN GAS HIGH PRESSURE Давление газа (бензина)где то в «CN» высокое P1 293 CN GAS LOW PRESSURE Давление газа (бензина)где то в «CN» низкое P1 294 IDLE SPEED PERFORMANCE Холостой ход нестабилен P1 295 TPS SENSOR NO 5V FEED На датчике положения дроссельной заслонки нет питания 5В P1 296 MAP SENSOR NO 5V FEED На датчике давления воздуха во впускном кол. нет питания 5В P1 297 MAP PNEUMATIC CHANGE Давление в датчике мало P1 298 WIDE OPEN THROTTLE LEAN Широко открытый дроссель беднит P1 298 NO VARIATION IN MAP SIGNAL IS DETECTED Обнаружено отсутствие изменений сигнала с P1 299 AIR FLOW TOO HIGH Поток воздуха слишком большой P1 390 CAM/CRANK TIMING Сбой по времени синхронизации коленчатого вала P1 391 CAM/CRANK SENSOR LOSS Пропадание сигнала датчика вращения коленчатого вала P1 391 NO PEAK PRI #1 WITH MAX DWELL TIME Отсутствие сигнала «начало отсчета» №1 больше пол. времени P1 392 NO PEAK PRI #2 WITH MAX DWELL TIME Отсутствие сигнала «начало отсчета» №2 больше пол. Времени P1 393 NO PEAK PRI #3 WITH MAX DWELL TIME Отсутствие сигнала «начало отсчета» №3 больше пол. Времени P1 394 NO PEAK PRI #4 WITH MAX DWELL TIME Отсутствие сигнала «начало отсчета» №4 больше пол. Времени P1 395 NO PEAK PRI #5 WITH MAX DWELL TIME Отсутствие сигнала «начало отсчета» №5 больше пол. времени P1 398 CRANK SENSOR Датчик положения коленчатого вала P1 399 WAIT TO STRT LMP CKT P1 486 EVAP HOSE PINCHED Пережат испарительный рукав P1 487 HI SPD FAN #2 CKT Цепь высокоскоростного вентилятора №2 P1 488 AUX 5 VOLT LOW OUTPUT Питание датчиков 5В отсутствует P1 489 HI SPD FAN RELAY CIRCUIT Цепь реле высокоскоростного вентилятора P1 490 LO SPD FAN RELAY CIRCUIT Цепь реле низкоскоростного вентилятора P1 491 RADIATOR FAN RELAY CIRCUIT Цепь реле радиаторного вентилятора P1 492 AMBIENT TEMP SENSOR HIGH Сигнал датчика внешней температуры всегда высокий P1 493 AMBIENT TEMP SENSOR LOW Сигнал датчика внешней температуры всегда низкий P1 494 LEAK DETECT PUMP PRESSURE SWITCH Обнаружена утечка в цепи переключателя давления насоса P1 495 LEAK DETECT PUMP SOLENOID CIRCUIT Обнаружена утечка в цепи соленоида насоса P1 496 5 VOLT LOW OUTPUT Отсутствует 5В выход P1 596 POWER STEEPING SW. BAD INPUT STATE Мощный шаговый переключатель имеет неправ. нач. положение P1 598 A/C PRESS SENSOR INPUT VOLT TOO LOW Сигнал датчика давления в кондиционере всегда низкий P1 599 A/C PRESS SENSOR INPUT VOLT TOO HIGH Сигнал датчика давления в кондиционере всегда высокий P1 698 NO COD MESGS RECVD TRANS CNTRL MOD Нет кодов сообщений принятых в «trans control mode» P1 699 NO CОD MESGS RECVD PWRTRAIN CNTRL MOD Нет кодов сообщений принятых в «powertrain control mode» P1 761 GOV CONTROL SYSTEM Управляющая контрольная система P1 762 GOV PRESS SENSOR OFFSET Сигнал датчика давления GOV смещен P1 763 GOV PRESS SENSOR HIGH Сигнал датчика давления GOV всегда высокий P1 764 GOV PRESS SENSOR LOW Сигнал датчика давления GOV всегда низкий P1 765 TRANS VOLTAGE RELAY CIRCUIT Изменение напряжения в цепи реле P1 899 PARK/NEUTRAL SWITCH WRONG INPUT STATE Переключатель парковки/нейтрали находится в ошибочном положении P1 XXX 1995—Ford P1 000 CHECK OF SYS INCOMP MORE DRIVING REQ’D P1 100 MAF SENSOR INTERMITTENT Сигнал датчика расхода воздуха перемежающийся P1 101 MAF SENSOR OUT OF RANGE Сигнал датчика расхода воздуха выходит из доп. диапазона P1 112 IAT SENSOR INTERMITTENT Сигнал датчика температуры воздуха на впуске перемежающийся P1 116 ECT SENSOR OUT OF RANGE Сигнал датчика температуры охл. жид. выходит из доп. диапазона P1 117 ECT SENSOR INTERMITTENT Сигнал датчика температуры охл. жид. Перемежающийся P1 120 TP CIRCUIT OUT OF RANGE LOW Сигнал датчика положения дросселя всегда низкий P1 121 TP SENSOR INCONSISTENT W/ MAF Сигнал датчика положения дросселя не согласуется с ДМРВ P1 124 TP SENSOR OUT OF RANGE Сигнал датчика положения дросселя выходит за доп. диапазон P1 125 TP SENSOR INTERMITTENT Сигнал датчика положения дросселя перемежающийся P1 130 H02 NO SWITCH B1 SI ADAPTIVE FUEL LIMIT P1 131 H02 NO SWITCH B1 SYNDICATES LEAN P1 132 H02 NO SWITCH B1 SYNDICATES RICH P1 150 H02 NO SWITCH B2 SI ADAPTIVE FUEL LIMIT P1 151 H02 NO SWITCH B2 SYNDICATES LEAN P1 152 H02 NO SWITCH B2 SYNDICATES RICH P1 220 SERIES THROTTLE CONTROL MALFUNCTION Последовательный канал управления дросселем неисправен P1 224 TPS B SELF TEST OUT OF RANGE Внутренний тест датчика положения дросселя выходит за доп. P1 233 FUEL PUMP DRIVER MODULE OFFLINE-MIL Драйвер модуля топливного насоса выключен и горит инд. лампа P1 234 FUEL PUMP DRIVER MODULE OFFLINE Драйвер модуля топливного насоса выключен P1 235 FUEL PUMP CONTROL OUT OF RANGE-MIL Драйвер модуля топливного насоса выходит из доп. диапазона P1 236 FUEL PUMP CONTROL OUT OF RANGE Драйвер модуля топливного насоса выходит из доп. диапазона P1 237 FUEL PUMP SECONDARY CIRCUIT MALF-MIL Вторичная цепь топливного насоса неисправна и горит инд. лампа P1 238 FUEL PUMP SECONDARY CIRCUIT MALFUNCTION Вторичная цепь топливного насоса неисправна P1 260- THEFT DETECTED ENGINE DISABLED Двигатель выключен противоугонной системой (обнаружен вор) P1 270 RPM OR VEH SPEED LIMITER REACHED Обороты двигателя или скорость авт. не достигают ограничителя P1 299 ENGINE OVERTEMP CONDITION Двигатель в состоянии перегрева P1 351 IGN DIAGNOSTIC INPUT MALFUNCTION Вход диагностики зажигания неисправен P1 352 IGN COIL A PRIMARY MALFUNCTION Первичная цепь катушки зажигания «А» неисправна P1 353 IGN COIL B PRIMARY MALFUNCTION Первичная цепь катушки зажигания «В» неисправна P1 354 IGN COIL C PRIMARY MALFUNCTION Первичная цепь катушки зажигания «С» неисправна P1 355 IGN COIL D PRIMARY MALFUNCTION Первичная цепь катушки зажигания «Д» неисправна P1 356 PIP WHILE IDM PULSE SAYS ENG NOT TURNIN Импульсы с зубчатого колеса говорят что двигатель не проворач. P1 357 IDM PULSE WIDTH NOT DEFINED Ширина «IDM» импульса не определяется P1 358 IDM SIGNAL OUT OF RANGE Ширина «IDM» импульса выходит из допустимого диапазона P1 359 SPARK OUTPUT CKT MALFUNCTION Выходная цепь зажигания неисправна P1 364 IGN COIL PRIMARY MALFUNCTION Первичная катушка зажигания неисправна P1 390 OCTANE ADJUST PIN IN USE/CIRCUIT OPEN Вывод октан потенциометра или его цепь оборваны P1 400 DPFE SENSOR LOW VOLTAGE Сигнал датчика «DPFE» всегда в низком уровне P1 401 DPFE SENSOR HIGH VOLTAGE Сигнал датчика «DPFE» всегда в высоким уровне P1 403 DPFE SENSOR HOSES REVERSED Сигнал датчика «DPFE» в шланге перевернут P1 405 DPFE SENSOR UPSTREAM HOSE OFF Сигнал датчика «DPFE» в обратном шланге не работает P1 406 DPFE SENSOR DOWNSTREAM HOSE OFF Сигнал датчика «DPFE» в прямом шланге не работает P1 407 EGR NO FLOW DETECTED Не обнаружен поток отработанных газов в системе рециркуляции P1 408 EGR FLOW OUT OF TEST RANGE Поток рециркуляции отработанных газов выходит из тестового диапазона P1 409 EGR CONTROL CIRCUIT MALFUNCTION Цепь управления рециркуляцией отработанных газов неисправна P1 413 SECONDARY AIR INJ CIRCUIT LOW VOLTAGE Цепь впрыска вторичного воздуха в низком уровне P1 414 SECONDARY AIR INJ CIRCUIT Hi VOLTAGE Цепь впрыска вторичного воздуха в высоком уровне P1 443 EVAP PURGE MALFUNCTION Продувка системы улавливания паров бензина неисправна P1 444 PURGE FLOW SENSOR CIRCUIT LOW INPUT Цепь датчика потока продувки адсорбера в низком уровне P1 445 PURGE FLOW SENSOR CIRCUIT HIGH INPUT Цепь датчика потока продувки адсорбера в высоком уровне P1 460 WIDE OPEN THROTTLE A/C CUTOUT FAILURE Кондиционер не выключается при полностью открытом дросселе P1 461 A/C PRESSURE CKT HIGH INPUT Цепь давления кондиционера всегда в высоком уровне P1 462 A/C PRESSURE CKT LOW INPUT Цепь давления кондиционера всегда в низком уровне P1 463 A/C PRESSURE INSUFFICIENT CHANGE Давление в кондиционере меняется недостаточно P1 464 A/C DEMAND OUT OF RANGE Запрос на включение кондиционера выходит из допустимого диапазона P1 469 A/C CYCLING PERIOD LOW Период повторения кондиционера мал P1 473 FAN MONITOR HIGH/W FANS OFF Управление вентилятором высокое а вентилятор выключен P1 474 FAN CONTROL LOW SPEED FAILURE Высокоскоростной контроль вентилятора неисправен P1 479 FAN CONTROL HIGH SPEED FAILURE Низкоскоростной контроль вентилятора неисправен P1 480 FAN MONITOR LOW/W LOW FAN ON Управление вентилятора низкое а вентилятор выключен P1 481 FAN MONITOR LOW/W HIGH FAN ON Управление вентилятора низкое а вентилятор выключен P1 500 VSS INTERMITTENT Сигнал датчика скорости автомобиля неисправен P1 505 IAC AT ADAPTIVE CLIP Ошибочная адаптация регулятора холостого хода P1 518 INLET MAN. RUNNER STUCK OPEN P1 519 INLET MAN. RUNNER STUCK CLOSED P1 520 INLET MAN. RUNNER MALFUNCTION P1 550 PSP OUT OF RANGE Давление в гидроусилителе руля выходит из допустимого диапазона P1 605 ROM/KAM TEST KEEP ALIVE MEM FAIL Тест заполнения ROM/KAM памяти показывает сбой P1 610 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 611 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 612 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 613 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 614 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 615 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 616 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 617 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 618 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 619 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 620 FLASH EPROM REPROG ERROR Репрограммируемая память EEPROM неисправна P1 650 PSP SENSOR OUT OF RANGE Датчик гидроусилителя руля выходит из допустимого диапазона P1 651 PSP SENSOR INPUT MALFUNCTION Датчик гидроусилителя руля неисправен P1 701 REVERSE ENGAGEMENT ERROR Ошибка зацепления реверса P1 703 BRAKE SWITCH OUT OF RANGE Переключатель тормозов выходит за диапазон P1 705 TRANS RANGE SENSOR OUT OF RANGE Датчик выбора режима трансмиссии выходит за диапазон P1 709 PNP SWITCH OUT OF RANGE Переключатель парковка/нейтраль выходит за диапазон P1 711 TFT SENSOR OUT OF RANGE «TFT» датчик выходит за диапазон P1 729 4X4L SWITCH ERROR Переключатель 4Х4 неисправен P1 730 4X4 LOW ERROR 4Х4 ошибка низкого уровня P1 731 1-2 SHIFT ERROR Ошибка переключателя с 1ой на 2ю передачу P1 732 2-3 SHIFT ERROR Ошибка переключателя с 2ой на 3ю передачу P1 733 3-4 SHIFT ERROR Ошибка переключателя с 3ей на 4ю передачу P1 741 TCC CONTROL ERROR Ошибка управления сцеплением P1 742 TCC PWM SOL FAILED ON Соленоид включения сцепления не включается P1 743 TCC PWM SOL FAILED ON Соленоид включения сцепления не включается P1 744 TCC SYSTEM PERFORMANCE Медленная работа сцепления P1 746 EPC SOLENOID OPEN CIRCUIT Цепь «EPC» соленоида оборвана P1 747 EPC SOLENOID SHORT CIRCUIT Цепь «EPC» соленоида замкнута P1 749 EPC SOLENOID FAILED LOW «EPC» соленоид не задвигается P1 751 SHIFT SOLENOID A PERFORMANCE Соленоид «А» переключения передач медленно работает P1 754 COAST CLUTCH CKT MALFUNCTION Цепь включения накатной муфты не работает P1 756 SHIFT SOLENOID B PERFORMANCE Соленоид «В» переключения передач медленно работает P1 761 SHIFT SOLENOID C PERFORMANCE Соленоид «С» переключения передач медленно работает P1 766 SHIFT SOLENOID D PERFORMANCE Соленоид «Д» переключения передач медленно работает P1 780 TCS OUT OF RANGE TCS вышел из диапазона P1 781 4X4L SWITCH OUT OF RANGE 4Х4L - переключатель вышел из диапазона P1 783 TRANSMISSION OVERTEMPERATURE Трансмиссия перегрета P1 784 TRANS 1ST & REV. MECHANICAL FAILURE Первая или задняя передачи механически неисправна P1 785 TRANS 1ST & 2ND MECHANICAL FAILURE Первая или вторая передачи механически неисправна P1 788 VFS #2 OPEN CIRCUIT Цепь VFS №2 оборвана P1 789 VFS #2 SHORT CIRCUIT Цепь VFS №2 замкнута U1 39 VSS FAILURE Датчик скорости автомобиля неисправен U1 51 BRAKE SWITCH SIG. FAILURE Выключатель стоп-сигнала неисправен U1 135 IGN SWITCH SIG. FAILURE Выключатель (замок) зажигания неисправен U1 451 PATS MODULE NO RESP/ENG DISABLE Часть модулей не отвечает или двигатель выключен P1 XXX 1995—GM P1 2 BRAKE BOOSTER VAC SHORTED Вакуумный усилитель тормозов заткнут P1 3 BRAKE BOOSTER VAC OPEN Вакуумный усилитель тормозов открыт P1 5 BRAKE BOOSTER VAC TO LOW Вакуумный усилитель тормозов имеет низкий уровень вакуума P1 7 PCM DATA LINK PROBLEM Проблема с передачей данных из блока управления P1 37 ABS/TCS LOSS OF DATA Блок управления АБС или трансмиссии теряют данные P1 106 MAP INTERM. HIGH IN Датчик давления впускного воздуха перемежающийся высокий уровень P1 107 MAP INTERM. LOW IN Датчик давления впускного воздуха перемежающийся низкий уровень P1 111 INTAKE AIR TEMP INTERM. HIGH INPUT Датчик температуры впускного воздуха перемежающийся высокий уровень P1 112 IAT SENSOR INTERM. LOW INPUT Датчик температуры впускного воздуха перемежающийся низкий уровень P1 114 ECT INTERM. LOW INPUT Датчик температуры охл. жидкости перемежающийся высокий уровень P1 115 ECT INTERM. HIGH INPUT Датчик температуры охл. жидкости перемежающийся низкий уровень P1 121 TPS INTERM. HIGH INPUT Датчик положения дросселя перемежающийся высокий уровень P1 122 TPS INTERM. LOW INPUT Датчик положения дросселя перемежающийся низкий уровень P1 133 ENGINE 02 B1 SI SWITCHING Датчик кислорода «В1» медленно переключатель P1 134 ENGINE 02 B1 SI RATIO Датчик кислорода «В1» имеет малый рейтинг переключений P1 135 ENGINE 02 B1 SI MEAN VOLTS Датчик кислорода «В1» имеет смещение середины сигнала P1 153 ENGINE 02 B2 SI SWITCHING Датчик кислорода «В2» медленно переключатель P1 154 ENGINE 02 B2 SI RATIO Датчик кислорода «В2» имеет малый рейтинг переключений P1 155 ENGINE 02 B2 SI MEAN VOLTS Датчик кислорода «В2» имеет смещение середины сигнала P1 257 SUPER CHARGER OVER BOOST Супер заряженный над форсаж P1 274 INJECTOR WIRING INCORRECT Провода впрыска под соединены не правильно P1 350 BYPASS LINE MONITOR Аварийная линия управления P1 361 EST NO TOGGLE AFT ENABLE «EST» не поворачивается после включения P1 374 CRANK LOW RES CORRELATE Относительно низкий уровень сигнала датчика коленчатого вала P1 381 ABS SYS ROUGH ROAD DETECT COMM FAIL Датчик неровной дороги системы АБС неисправен P1 406 LINEAR EGR PINTLE POSITION ERROR Линейность системы рециркуляции отработанных газов нарушена P1 441 EVAPORATIVE SYS OPEN PURGE FLOW Система улавливания паров бензина открыта продувочному потоку P1 442 PURGE SOLENOID VAC SWITCH MALFUNCTION Переключатель продувочного соленоида не работает P1 508 IDLE CONTROL SYS LOW Система поддержания холостого хода не открывается P1 509 IDLE CONTROL SYS HIGH Система поддержания холостого хода не закрывается P1 520 PN SWITCH CIRCUIT FAULT Цепь переключателя “PN” неисправна P1 554 CRUISE STEPPER MTR LINK FAULT Связь с шаговым мотором круизконтроля нарушена P1 571 TRACTION CNTRL PWM LINK FAULT Связь с антипробуксовочой системой нарушена P1 573 TRACTION CNTRL ABS LOST SERIAL DATA Связь с антиблокировочной системой нарушена P1 619 OIL CHANGE RESET CIRCUIT FAULT Цепь запроса смены масла неисправна P1 626 PASSKEY FUEL ENABLE LOST Ключ разрешения топливоподачи потерян P1 629 PASSKEY FREQUENCY INVALID Частота ключа неправильная P1 635 VSBA VOLTAGE CIRCUIT FAULT P1 639 VSBB VOLTAGE CIRCUIT FAULT P1 641 ODMA OUTPUT 1 CIRCUIT FAULT P1 642 ODMA OUTPUT 2 CIRCUIT FAULT P1 643 ODMA OUTPUT 3 CIRCUIT FAULT P1 644 ODMA OUTPUT 4 CIRCUIT FAULT P1 645 ODMA OUTPUT 5 CIRCUIT FAULT P1 646 ODMA OUTPUT 6 CIRCUIT FAULT P1 647 ODMA OUTPUT 7 CIRCUIT FAULT P1 651 ODMB OUTPUT 1 CIRCUIT FAULT P1 652 ODMB OUTPUT 2 CIRCUIT FAULT P1 653 ODMB OUTPUT 3 CIRCUIT FAULT P1 654 ODMB OUTPUT 4 CIRCUIT FAULT P1 655 ODMB OUTPUT 5 CIRCUIT FAULT P1 656 ODMB OUTPUT 6 CIRCUIT FAULT P1 657 ODMB OUTPUT 7 CIRCUIT FAULT P1 661 ODMC OUTPUT 1 CIRCUIT FAULT P1 662 ODMC OUTPUT 2 CIRCUIT FAULT P1 663 ODMC OUTPUT 3 CIRCUIT FAULT P1 664 ODMC OUTPUT 4 CIRCUIT FAULT P1 665 ODMC OUTPUT 5 CIRCUIT FAULT P1 666 ODMC OUTPUT 6 CIRCUIT FAULT P1 667 ODMC OUTPUT 7 CIRCUIT FAULT P1 671 ODMD OUTPUT 1 CIRCUIT FAULT P1 672 ODMD OUTPUT 2 CIRCUIT FAULT P1 673 ODMD OUTPUT 3 CIRCUIT FAULT P1 674 ODMD OUTPUT 4 CIRCUIT FAULT P1 675 ‘ ODMD OUTPUT 5 CIRCUIT FAULT P1 676 ODMD OUTPUT 6 CIRCUIT FAULT P1 677 ODMD OUTPUT 7 CIRCUIT FAULT P1 801 SELECT SWITCH PERFORM FAULT (HMD) Переключатель режима работы неисправен P1 810 PSS MANIFOLD MALFUNCTION “PSS” трубопровод неисправен P1 811 MAX ADAPT & LONG SHIFT (HMD) P1 812 TRANS (HMD) HOT Трансмиссия перегрета P1 814 TORQUE CONVERTER OVER STRESSED Сцепление перегружено (ударная нагрузка) P1 860 TCC PWM SOLENOID CIRCUIT (HMD) P1 864 TCC SOLENOID CIRCUIT (HMD) P1 870 TRANSM COMPONENT SUPPING (HMD) P1 871 GEAR RATIO UNDEFINED Передача не определена P1 886 3 TO 2 SOLENOID CIRCUIT MALFUNCTION Цепь соленоида переключения с 3-ей на 2-ю передачи неисправна P1 889 3RD CLUTCH SWITCH PRESS SWITCH (HMD) BO 100 DRIVER AIR BAG CIRCUIT MALFUNCTION Цепь надувной подушки безопасности водителя неисправна BO 101 DRIVER AIR BAG CIRCUIT RANGE/PERF Сигнал цепи надувной подушки выходит за доп. диапазон BO 102 DRIVER AIR BAG CIRCUIT LOW INPUT Сигнал цепи надувной подушки всегда в низком положении BO 103 DRIVER AIR BAG CIRCUIT HIGH INPUT Сигнал цепи надувной подушки всегда в высоком положении BO 105 PASSENGER AIR BAG CIRCUIT MALFUNCTION Цепь надувной подушки безопасности пассажира неисправна BO 106 PASSENGER AIR BAG CIRCUIT RANGE/PERF Сигнал цепи надувной подушки выходит за доп. диапазон BO 107 PASSENGER AIR BAG CIRCUIT LOW INPUT Сигнал цепи надувной подушки всегда в низком положении BO 108 PASSENGER AIR BAG CIRCUIT HIGH INPUT Сигнал цепи надувной подушки всегда в высоком положении BO 110 DRVR-SIDE AIR BAG CIRCUIT MALFUNCTION Цепь надувной боковой подушки без. водителя неисправна BO 111 DRVR-SIDE AIR BAG CIRCUIT RANGE/PERF Сигнал цепи надувной подушки выходит за доп. диапазон BO 112 DRVR-SIDE AIR BAG CIRCUIT LOW INPUT Сигнал цепи надувной подушки всегда в низком положении BO 113 DRVR-SIDE AIR BAG CIRCUIT HIGH INPUT Сигнал цепи надувной подушки всегда в высоком положении BO 115 PSNGR-SIDE AIR BAG CIRCUIT MALFUNCTION Цепь надувной боковой подушки без. пассажира неисправна BO 116 PSNGR-SIDE AIR BAG CIRCUIT RANGE/PERF Сигнал цепи надувной подушки выходит за доп. диапазон BO 117 PSNGR-SIDE AIR BAG CIRCUIT LOW INPUT Сигнал цепи надувной подушки всегда в низком положении BO 118 PSNGR-SIDE AIR BAG CIRCUIT HIGH INPUT Сигнал цепи надувной подушки всегда в высоком положении BO 120 SEATBELT #1 SW MON. CIRCUIT MALFUNCTION Защелка ремня безопасности №1 неисправен BO 121 SEATBELT #1 SW MON. CIRCUIT RANGE/PERF Защелка ремня безопасности №1 работает медленно BO 122 SEATBELT #1 SW MON. CIRCUIT LOW INPUT Защелка ремня безопасности №1 имеет низкий вход BO 123 SEATBELT #1 SW MON. CIRCUIT HIGH INPUT Защелка ремня безопасности №1 имеет высокий вход BO 125 SEATBELT #2 SW MON. CIRCUIT MALFUNCTION Защелка ремня безопасности №2 неисправен BO 126 SEATBELT #2 SW MON. CIRCUIT RANGE/PERF Защелка ремня безопасности №2 работает медленно BO 127 SEATBELT #2 SW MON. CIRCUIT LOW INPUT Защелка ремня безопасности №2 имеет низкий вход BO 128 SEATBELT #2 SW MON. CIRCUIT HIGH INPUT Защелка ремня безопасности №2 имеет высокий вход BO 130 SEATBELT #1 RETRACT CIRCUIT MALFUNCTION Механизм натяжения ремня безопасности №1 неисправен BO 131 SEATBELT #1 RETRACT CIRCUIT RANGE/PERF Механизм натяжения ремня безопасности №1 работает медленно BO 132 SEATBELT #1 RETRACT CIRCUIT LOW INPUT Механизм натяжения ремня безопасности №1 имеет низкий вход BO 133 SEATBELT #1 RETRACT CIRCUIT HIGH INPUT Механизм натяжения ремня безопасности №1 имеет высокий вход BO 135 SEATBELT #2 RETRACT CIRCUIT MALFUNCTION Механизм натяжения ремня безопасности №2 неисправен BO 136 SEATBELT #2 RETRACT CIRCUIT RANGE/PERF Механизм натяжения ремня безопасности №2 работает медленно BO 137 SEATBELT #2 RETRACT CIRCUIT LOW INPUT Механизм натяжения ремня безопасности №2 имеет низкий вход BO 138 SEATBELT #2 RETRACT CIRCUIT HIGH INPUT Механизм натяжения ремня безопасности №2 имеет высокий вход BO 300 COOLING FAN #1 CIRCUIT MALFUNCTION Цепь вентилятора охлаждения №1 не работает BO 301 COOLING FAN #1 CIRCUIT RANGE/PERF Цепь вентилятора охлаждения №1 работает медленно BO 302 COOLING FAN #1 CIRCUIT LOW INPUT Цепь вентилятора охлаждения №1 имеет низкий сигнал BO 303 COOLING FAN #1 CIRCUIT HIGH INPUT Цепь вентилятора охлаждения №1 имеет высокий сигнал BO 305 COOLING FAN #2 CIRCUIT MALFUNCTION Цепь вентилятора охлаждения №2 не работает BO 306 COOLING FAN #2 CIRCUIT RANGE/PERF Цепь вентилятора охлаждения №2 работает медленно BO 307 COOLING FAN #2 CIRCUIT LOW INPUT Цепь вентилятора охлаждения №2 имеет низкий сигнал BO 308 COOLING FAN #2 CIRCUIT HIGH INPUT Цепь вентилятора охлаждения №2 имеет высокий сигнал BO 310 A/C CLUTCH CIRCUIT MALFUNCTION Цепь включения кондиционера неисправна BO 311 A/C CLUTCH CIRCUIT RANGE/PERF Цепь включения кондиционера работает медленно BO 312 A/C CLUTCH CIRCUIT LOW INPUT Цепь включения кондиционера имеет низкий сигнал BO 313 A/C CLUTCH CIRCUIT HIGH INPUT Цепь включения кондиционера имеет высокий сигнал BO 315 A/C PRESSURE #1 CIRCUIT MALFUNCTION Цепь компрессора кондиционера №1 неисправна BO 316 A/C PRESSURE #1 CIRCUIT RANGE/PERF Цепь компрессора кондиционера №1 работает медленно BO 317 A/C PRESSURE #1 CIRCUIT LOW INPUT Цепь компрессора кондиционера №1 имеет низкий сигнал B0 318 A/C PRESSURE #1 CIRCUIT HIGH INPUT Цепь компрессора кондиционера №1 имеет высокий сигнал B0 320 A/C PRESSURE #2 CIRCUIT MALFUNCTION Цепь компрессора кондиционера №2 неисправна B0 321 A/C PRESSURE #2 CIRCUIT RANGE/PERF Цепь компрессора кондиционера №2 работает медленно B0 322 A/C PRESSURE #2 CIRCUIT LOW INPUT Цепь компрессора кондиционера №2 имеет низкий сигнал B0 323 A/C PRESSURE #2 CIRCUIT HIGH INPUT Цепь компрессора кондиционера №2 имеет высокий сигнал B0 325 A/C PRESS REF (SIG) CIRCUIT MALFUNCTION B0 326 A/C PRESS REF (SIG) CIRCUIT RANGE/PERF B0 327 A/C PRESS REF (SIG) CIRCUIT LOW INPUT B0 328 A/C PRESS REF (SIG) CIRCUIT HIGH INPUT B0 330 OUTSIDE AIR TEMP CIRCUIT MALFUNCTION Цепь датчика температуры внешнего воздуха неисправна B0 331 OUTSIDE AIR TEMP CIRCUIT RANGE/PERF Цепь датчика температуры работает медленно B0 332 OUTSIDE AIR TEMP CIRCUIT LOW INPUT Цепь датчика температуры имеет низкий сигнал B0 333 OUTSIDE AIR TEMP CIRCUIT HIGH INPUT Цепь датчика температуры имеет высокий сигнал B0 335 IN AIR TEMP SENS #1 CIRCUIT MALFUNCTION Цепь датчика температуры внутреннего воздуха №1 неисправ. B0 336 IN AIR TEMP SENS #1 CIRCUIT RANGE/PERF Цепь датчика температуры №1 работает медленно B0 337 IN AIR TEMP SENS #1 CIRCUIT LOW INPUT Цепь датчика температуры №1 имеет низкий сигнал B0 338 IN AIR TEMP SENS #1 CIRCUIT HIGH INPUT Цепь датчика температуры №1 имеет высокий сигнал B0 340 IN AIR TEMP SENS #2 CIRCUIT MALFUNCTION Цепь датчика температуры внутреннего воздуха №2 неисправ. B0 341 IN AIR TEMP SENS #2 CIRCUIT RANGE/PERF Цепь датчика температуры №2 работает медленно B0 342 IN AIR TEMP SENS #2 CIRCUIT LOW INPUT Цепь датчика температуры №2 имеет низкий сигнал B0 343 IN AIR TEMP SENS #2 CIRCUIT HIGH INPUT Цепь датчика температуры №2 имеет высокий сигнал B0 345 SOLAR LOAD SENSOR 1 CIRCUIT MALFUNCTION Цепь датчика освещенности (солнечных батарей) №1 неиспр. B0 346 SOLAR LOAD SENSOR 1 CIRCUIT RANGE/PERF Цепь датчика освещенности №1 работает медленно B0 347 SOLAR LOAD SENSOR 1 CIRCUIT LOW INPUT Цепь датчика освещенности №1 имеет низкий сигнал B0 348 SOLAR LOAD SENSOR 1 CIRCUIT HIGH INPUT Цепь датчика освещенности №1 имеет высокий сигнал B0 350 SOLAR LOAD SENSOR 2 CIRCUIT MALFUNCTION Цепь датчика освещенности (солнечных батарей) №2 неиспр. B0 351 SOLAR LOAD SENSOR 2 CIRCUIT RANGE/PERF Цепь датчика освещенности №2 работает медленно B0 352 SOLAR LOAD SENSOR 2 CIRCUIT LOW INPUT Цепь датчика освещенности №2 имеет низкий сигнал B0 353 SOLAR LOAD SENSOR 2 CIRCUIT HIGH INPUT Цепь датчика освещенности №2 имеет высокий сигнал B0 355 BLOWER MTR #1 SPEED CIRCUIT MALFUNCTION Цепь управления скоростью вентилятора №1 неисправна B0 356 BLOWER MTR #1 SPEED CIRCUIT RANGE/PERF Цепь управления вентилятора №1 работает медленно B0 357 BLOWER MTR #1 SPEED CIRCUIT LOW INPUT Цепь управления вентилятора №1 имеет низкий сигнал B0 358 BLOWER MTR #1 SPEED CIRCUIT HIGH INPUT Цепь управления вентилятора №1 имеет высокий сигнал B0 360 BLOWER MTR #1 POWER CIRCUIT MALFUNCTION Цепь питания вентилятора №1 неисправна B0 361 BLOWER MTR #1 POWER CIRCUIT RANGE/PERF Цепь питания вентилятора №1 выходит за доп. диапазон B0 362 BLOWER MTR #1 POWER CIRCUIT LOW INPUT Цепь питания вентилятора №1 имеет низкий сигнал B0 363 BLOWER MTR #1 POWER CIRCUIT HIGH INPUT Цепь питания вентилятора №1 имеет высокий сигнал B0 365 BLOWER MTR #1 GND CIRCUIT MALFUNCTION Цепь заземления вентилятора №1 неисправна B0 366 BLOWER MTR #1 GND CIRCUIT RANGE/PERF Цепь заземления вентилятора №1 выходит за доп. диапазон B0 367 BLOWER MTR #1 GND CIRCUIT LOW INPUT Цепь заземления вентилятора №1 имеет низкий сигнал B0 368 BLOWER MTR #1 GND CIRCUIT HIGH INPUT Цепь заземления вентилятора №1 имеет высокий сигнал B0 370 A/C HIGH SIDE TEMP SENSOR MALFUNCTION Датчик температуры высшей точки кондиционера неисправен B0 371 A/C HIGH SIDE TEMP SENSOR RANGE/PERF Сигнал датчика температуры выходит за допустимый диапазон B0 372 A/C HIGH SIDE TEMP SENSOR LOW INPUT Сигнал датчика температуры имеет низкий уровень B0 373 A/C HIGH SIDE TEMP SENSOR HIGH INPUT Сигнал датчика температуры имеет высокий уровень B0 375 A/C EVAP INLET TEMP SENSOR MALFUNCTION Датчик температуры на входе вент. кондиц. неисправен B0 376 A/C EVAP INLET TEMP SENSOR RANGE/PERF Сигнал датчика температуры выходит за допустимый диапазон BO 377 A/C EVAP INLET TEMP SENSOR LOW INPUT Сигнал датчика температуры имеет низкий уровень BO 378 A/C EVAP INLET TEMP SENSOR HIGH INPUT Сигнал датчика температуры имеет высокий уровень BO 380 A/C REFRIGERANT UNDERPRESSURE Давление хладагента кондиционера недостаточно BO 381 A/C REFRIGERANT OVERPRESSURE Давление хладагента кондиционера избыточно BO 400 AIR FLOW CONTROL #1 DEFROST MALFUNCTION Упр. воздушным потоком размораживателя №1 неисправно BO 401 AIR FLOW CONTROL #1 DEFROST RANGE/PERF Упр. размораживателя №1 работает медленно BO 402 AIR FLOW CONTROL #1 DEFROST LOW INPUT Упр. размораживателя №1 имеет низкий сигнал BO 403 AIR FLOW CONTROL #1 DEFROST HIGH INPUT Упр. размораживателя №1 имеет высокий сигнал BO 405 AIR FLOW CONTROL #2 HEATER MALFUNCTION Упр. воздушным потоком нагревателя №2 неисправно BO 406 AIR FLOW CONTROL #2 HEATER RANGE/PERF Упр. нагревателя №2 работает медленно BO 407 AIR FLOW CONTROL #2 HEATER LOW INPUT Упр. нагревателя №2 имеет низкий сигнал BO 408 AIR FLOW CONTROL #2 HEATER HIGH INPUT Упр. нагревателя №2 имеет высокий сигнал BO 410 AIR FLOW CONTROL #3 BLEND MALFUNCTION Упр. воздушным потоком смесителя №3 неисправно BO 411 AIR FLOW CONTROL #3 BLEND RANGE/PERF Упр. смесителя №3 работает медленно BO 412 AIR FLOW CONTROL #3 BLEND LOW INPUT Упр. смесителя №3 имеет низкий сигнал BO 413 AIR FLOW CONTROL #3 BLEND HIGH INPUT Упр. смесителя №3 имеет высокий сигнал BO 415 AIR FLOW CONTROL #4 VENT MALFUNCTION Упр. воздушным потоком вентиляции №4 неисправно BO 416 AIR FLOW CONTROL #4 VENT RANGE/PERF Упр. вентиляции №4 работает медленно BO 417 AIR FLOW CONTROL #4 VENT LOW INPUT Упр. вентиляции №4 имеет низкий сигнал BO 418 AIR FLOW CONTROL #4 VENT HIGH INPUT Упр. вентиляции №4 имеет высокий сигнал BO 420 AIR FLOW CONTROL #5 A/C MALFUNCTION Упр. воздушным потоком кондиционирования №5 неисправно BO 421 AIR FLOW CONTROL #5 A/C RANGE/PERF Упр. кондиционирования №5 работает медленно BO 422 AIR FLOW CONTROL #5 A/C LOW INPUT Упр. кондиционирования №5 имеет низкий сигнал BO 423 AIR FLOW CONTROL #5 A/C HIGH INPUT Упр. кондиционирования №5 имеет высокий сигнал BO 425 AIR FLOW CONTROL #6 RECIRC MALFUNCTION Упр. воздушным потоком рециркуляции №6 неисправно BO 426 AIR FLOW CONTROL #6 RECIRC RANGE/PERF Упр. рециркуляции №6 работает медленно BO 427 AIR FLOW CONTROL #6 RECIRC LOW INPUT Упр. рециркуляции №6 имеет низкий сигнал BO 428 AIR FLOW CONTROL #6 RECIRC HIGH INPUT Упр. рециркуляции №6 имеет высокий сигнал BO 430 REAR DEFROST CIRCUIT MALFUNCTION Цепь размораживателя заднего стекла неисправна BO 431 REAR DEFROST CIRCUIT RANGE/PERF Цепь размораживателя заднего стекла работает медленно BO 432 REAR DEFROST CIRCUIT LOW INPUT Цепь размораживателя заднего стекла имеет низкий сигнал BO 433 REAR DEFROST CIRCUIT HIGH INPUT Цепь размораживателя заднего стекла имеет высокий сигнал BO 435 A/C REQUEST CIRCUIT MALFUNCTION Цепь запроса включения кондиционера неисправна BO 436 A/C REQUEST CIRCUIT RANGE/PERF Цепь запроса включения кондиционера работает медленно BO 437 A/C REQUEST CIRCUIT LOW INPUT Цепь запроса включения кондиционера имеет низкий сигнал BO 438 A/C REQUEST CIRCUIT HIGH INPUT Цепь запроса включения кондиционера BO 440 CONTROL HEAD #1 FEEDBACK MALFUNCTION BO 441 CONTROL HEAD #1 FEEDBACK RANGE/PERF BO 442 CONTROL HEAD #1 FEEDBACK LOW INPUT BO 443 CONTROL HEAD #1 FEEDBACK HIGH INPUT BO 445 CONTROL HEAD #FEEDBACK MALFUNCTION BO 446 CONTROL HEAD #FEEDBACK RANGE/PERF BO 447 CONTROL HEAD #2 FEEDBACK LOW INPUT BO 448 CONTROL HEAD #2 FEEDBACK HIGH INPUT BO 500 RH TURN SIGNAL CIRCUIT MALFUNCTION Цепь правого указателя поворота неисправна BO 501 RH TURN SIGNAL CIRCUIT RANGE/PERF Цепь правого указателя поворота работает медленно BO 502 RH TURN SIGNAL CIRCUIT LOW INPUT Цепь правого указателя поворота имеет низкий сигнал BO 503 RH TURN SIGNAL CIRCUIT HIGH INPUT Цепь правого указателя поворота имеет высокий сигнал BO 505 LH TURN SIGNAL CIRCUIT MALFUNCTION Цепь левого указателя поворота неисправна BO 506 LH TURN SIGNAL CIRCUIT RANGE/PERF Цепь левого указателя поворота работает медленно BO 507 LH TURN SIGNAL CIRCUIT LOW INPUT Цепь левого указателя поворота имеет низкий сигнал BO 508 LH TURN SIGNAL CIRCUIT HIGH INPUT Цепь левого указателя поворота имеет высокий сигнал BO 510 HEADLAMP INDICATORS CIRCUIT MALFUNCTION Цепь индикатора головного освещения неисправна BO 511 HEADLAMP INDICATORS CIRCUIT RANGE/PERF Цепь индикатора головного освещения работает медленно BO 512 HEADLAMP INDICATORS CIRCUIT LOW INPUT Цепь индикатора головного освещения имеет низкий сигнал BO 513 HEADLAMP INDICATORS CIRCUIT HIGH INPUT Цепь индикатора головного освещения имеет высокий сигнал BO 515 SPEEDOMETER CIRCUIT MALFUNCTION Цепь спидометра неисправна BO 516 SPEEDOMETER CIRCUIT RANGE/PERF Цепь спидометра работает медленно BO 517 SPEEDOMETER CIRCUIT LOW INPUT Цепь спидометра имеет низкий сигнал BO 518 SPEEDOMETER CIRCUIT HIGH INPUT Цепь спидометра имеет высокий сигнал BO 520 TACHOMETER CIRCUIT MALFUNCTION Цепь тахометра неисправна BO 521 TACHOMETER CIRCUIT RANGE/PERF Цепь тахометра работает медленно BO 522 TACHOMETER CIRCUIT LOW INPUT Цепь тахометра имеет низкий сигнал BO 523 TACHOMETER CIRCUIT HIGH INPUT Цепь тахометра имеет высокий сигнал BO 525 TEMPERATURE GAUGES CIRCUIT MALFUNCTION Цепь измерителей температуры неисправна BO 526 TEMPERATURE GAUGES CIRCUIT RANGE/PERF Цепь измерителей температуры работает медленно BO 527 TEMPERATURE GAUGES CIRCUIT LOW INPUT Цепь измерителей температуры имеет низкий сигнал BO 528 TEMPERATURE GAUGES CIRCUIT HIGH INPUT Цепь измерителей температуры имеет высокий сигнал BO 530 FUEL LEVEL GAUGE CIRCUIT MALFUNCTION Цепь измерителя уровня топлива неисправна BO 531 FUEL LEVEL GAUGE CIRCUIT RANGE/PERF Цепь измерителя уровня топлива работает медленно BO 532 FUEL LEVEL GAUGE CIRCUIT LOW INPUT Цепь измерителя уровня топлива имеет низкий сигнал BO 533 FUEL LEVEL GAUGE CIRCUIT HIGH INPUT Цепь измерителя уровня топлива имеет высокий сигнал BO 535 TURBO/SUPER BOOST GAUGE MALFUNCTION Измеритель турбо/ супер наддува неисправен BO 536 TURBO/SUPER BOOST GAUGE RANGE/PERF Измеритель турбо/ супер наддува работает медленно BO 537 TURBO/SUPER BOOST GAUGE LOW INPUT Измеритель турбо/ супер наддува имеет низкий сигнал BO 538 TURBO/SUPER BOOST GAUGE HIGH INPUT Измеритель турбо/ супер наддува имеет высокий сигнал BO 540 FASTEN SEATBELT INDICATOR MALFUNCTION Индикатор защелкивания ремня безопасности неисправен BO 541 FASTEN SEATBELT INDICATOR RANGE/PERF Индикатор защелкивания ремня безопасности работает медленно BO 542 FASTEN SEATBELT INDICATOR LOW INPUT Индикатор защелкивания ремня безопасности имеет низкий сигнал BO 543 FASTEN SEATBELT INDICATOR HIGH INPUT Индикатор защелкивания ремня безопасности имеет выс. сигнал BO 545 DOOR AJAR #1 INDICATOR MALFUNCTION Индикатор приоткрытой двери №1 неисправен BO 546 DOOR AJAR #1 INDICATOR RANGE/PERF Индикатор приоткрытой двери №1 работает медленно BO 547 DOOR AJAR #1 INDICATOR LOW INPUT Индикатор приоткрытой двери №1 имеет низкий сигнал BO 548 DOOR AJAR #1 INDICATOR HIGH INPUT Индикатор приоткрытой двери №1 имеет высокий сигнал BO 550 DOOR AJAR #2 INDICATOR MALFUNCTION Индикатор приоткрытой двери №2 неисправен BO 551 DOOR AJAR #2 INDICATOR RANGE/PERF Индикатор приоткрытой двери №2 работает медленно BO 552 DOOR AJAR #2 INDICATOR LOW INPUT Индикатор приоткрытой двери №2 имеет низкий сигнал BO 553 DOOR AJAR #2 INDICATOR HIGH INPUT Индикатор приоткрытой двери №2 имеет высокий сигнал BO 555 BRAKE INDICATOR CIRCUIT MALFUNCTION Цепь индикатора торможения неисправна BO 556 BRAKE INDICATOR CIRCUIT RANGE/PERF Цепь индикатора торможения работает медленно BO 557 BRAKE INDICATOR CIRCUIT LOW INPUT Цепь индикатора торможения имеет низкий сигнал BO 558 BRAKE INDICATOR CIRCUIT HIGH INPUT Цепь индикатора торможения имеет высокий сигнал BO 560 AIR BAG LAMP #1 CIRCUIT MALFUNCTION Цепь лампы воздушной подушки №1 неисправна BO 561 AIR BAG LAMP #1 CIRCUIT RANGE/PERF Цепь лампы воздушной подушки №1 работает медленно BO 562 AIR BAG LAMP #1 CIRCUIT LOW INPUT Цепь лампы воздушной подушки №1 имеет низкий сигнал BO 563 AIR BAG LAMP #1 CIRCUIT HIGH INPUT Цепь лампы воздушной подушки №1 имеет высокий сигнал BO 565 SECURITY OP INFO CIRCUIT MALFUNCTION Цепь информации о секретных опциях неисправна BO 566 SECURITY OP INFO CIRCUIT RANGE/PERF Цепь информации о секретных опциях работает медленно BO 567 SECURITY OP INFO CIRCUIT LOW INPUT Цепь информации о секретных опциях имеет низкий сигнал BO 568 SECURITY OP INFO CIRCUIT HIGH INPUT Цепь информации о секретных опциях имеет высокий сигнал BO 600 OPTION CONFIG ERROR Конфигурация опций ошибочна BO 601 KAM RESET Сброс «КАМ» датчика BO 602 OSC WATCHDOG COP MALFUNCTION Генератор управляющий системой «WATCHDOG» неисправен BO 603 EEPROM WRITE ERROR Ошибка записи во FLASH-пзу BO 604 EEPROM CALIBRATION ERROR Ошибка ПЗУ калибровок BO 605 EEPROM CHECKSUM ERROR Ошибка контрольной суммы ПЗУ BO 606 RAM MALFUNCTION Оперативное запоминающее устройство неисправно BO 607 INTERNAL ERROR Внутренняя ошибка BO 608 INITIALIZATION ERROR Ошибка инициализации BO 800 DEVICE POWER #1 CIRCUIT MALFUNCTION Цепь блока питания №1 неисправна BO 801 DEVICE POWER #1 CIRCUIT RANGE/PERF Сигнал цепи блока питания №1 выходит за допустимые пределы BO 802 DEVICE POWER #1 CIRCUIT LOW INPUT Сигнал цепи блока питания №1 всегда низкого уровня BO 803 DEVICE POWER #1 CIRCUIT HIGH INPUT Сигнал цепи блока питания №1 всегда высокого уровня BO 805 DEVICE POWER #2 CIRCUIT MALFUNCTION Цепь блока питания №2 неисправна BO 806 DEVICE POWER #2 CIRCUIT RANGE/PERF Сигнал цепи блока питания №2 выходит за допустимые пределы BO 807 DEVICE POWER #2 CIRCUIT LOW INPUT Сигнал цепи блока питания №2 всегда низкого уровня BO 808 DEVICE POWER #2 CIRCUIT HIGH INPUT Сигнал цепи блока питания №2 всегда высокого уровня BO 810 DEVICE POWER #3 CIRCUIT MALFUNCTION Цепь блока питания №3 неисправна BO 811 DEVICE POWER #3 CIRCUIT RANGE/PERF Сигнал цепи блока питания №3 выходит за допустимые пределы BO 812 DEVICE POWER #3 CIRCUIT LOW INPUT Сигнал цепи блока питания №3 всегда низкого уровня BO 813 DEVICE POWER #3 CIRCUIT HIGH INPUT Сигнал цепи блока питания №3 всегда высокого уровня BO 815 DEVICE GROUND #1 CIRCUIT MALFUNCTION Цепь заземления устройств №1 неисправна BO 816 DEVICE GROUND #1 CIRCUIT RANGE/PERF Сигнал цепи заземления №1 выходит за допустимые пределы BO 817 DEVICE GROUND #1 CIRCUIT LOW INPUT Сигнал цепи заземления №1 всегда низкого уровня BO 818 DEVICE GROUND #1 CIRCUIT HIGH INPUT Сигнал цепи заземления №1 всегда высокого уровня BO 820 DEVICE GROUND #2 CIRCUIT MALFUNCTION Цепь заземления устройств №2 неисправна BO 821 DEVICE GROUND #2 CIRCUIT RANGE/PERF Сигнал цепи заземления №2 выходит за допустимые пределы BO 822 DEVICE GROUND #2 CIRCUIT LOW INPUT Сигнал цепи заземления №2 всегда низкого уровня BO 823 DEVICE GROUND #2 CIRCUIT HIGH INPUT Сигнал цепи заземления №2 всегда высокого уровня BO 825 DEVICE GROUND #3 CIRCUIT MALFUNCTION Цепь заземления устройств №3 неисправна BO 826 DEVICE GROUND #3 CIRCUIT RANGE/PERF Сигнал цепи заземления №3 выходит за допустимые пределы BO 827 DEVICE GROUND #3 CIRCUIT LOW INPUT Сигнал цепи заземления №3 всегда низкого уровня BO 828 DEVICE GROUND #3 CIRCUIT HIGH INPUT Сигнал цепи заземления №3 всегда высокого уровня BO 830 IGNITION 0 CIRCUIT MALFUNCTION Цепь зажигания 0 неисправна BO 831 IGNITION 0 CIRCUIT RANGE/PERF Цепь зажигания 0 работает медленно BO 832 IGNITION 0 CIRCUIT LOW INPUT Цепь зажигания 0 имеет низкий уровень BO 833 IGNITION 0 CIRCUIT HIGH INPUT Цепь зажигания 0 имеет высокий уровень BO 835 IGNITION 1 CIRCUIT MALFUNCTION Цепь зажигания 1 неисправна BO 836 IGNITION 1 CIRCUIT RANGE/PERF Цепь зажигания 1 работает медленно BO 837 IGNITION 1 CIRCUIT LOW INPUT Цепь зажигания 1 имеет низкий уровень BO 838 IGNITION 1 CIRCUIT HIGH INPUT Цепь зажигания 1 имеет высокий уровень BO 840 IGNITION 3 CIRCUIT MALFUNCTION Цепь зажигания 3 неисправна BO 841 IGNITION 3 CIRCUIT RANGE/PERF Цепь зажигания 3 работает медленно BO 842 IGNITION 3 CIRCUIT LOW INPUT Цепь зажигания 3 имеет низкий уровень BO 843 IGNITION 3 CIRCUIT HIGH Цепь зажигания 3 имеет высокий уровень BO 845 INPUT DEVICE 5 VOLT REF CIRCUIT MALFUNCTION 5-и вольтовый блок питания неисправен BO 846 DEVICE 5 VOLT REF CIRCUIT RANGE/PERF Сигнал 5- В. блока питания выходит из допустимого диапазона BO 847 DEVICE 5 VOLT REF CIRCUIT LOW INPUT Сигнал 5- В. блока питания всегда низкого уровня BO 848 DEVICE 5 VOLT REF CIRCUIT HIGH INPUT Сигнал 5- В. блока питания всегда высокого уровня BO 850 (CLEAN)BATTERY CIRCUIT MALFUNCTION (Чистая) Цепь аккумуляторной батареи неисправна BO 851 (CLEAN)BATTERY CIRCUIT RANGE/PERF (Чистая) Цепь аккумуляторной батареи работает плохо BO 852 (CLEAN)BATTERY CIRCUIT LOW INPUT (Чистая) Цепь аккумуляторной батареи имеет низкий уровень BO 853 (CLEAN)BATTERY CIRCUIT HIGH INPUT (Чистая) Цепь аккумуляторной батареи имеет высокий уровень BO 855 (DIRTY)BATTERY CIRCUIT MALFUNCTION (Грязная) Цепь аккумуляторной батареи неисправна BO 856 (DIRTY)BATTERY CIRCUIT RANGE/PERF (Грязная) Цепь аккумуляторной батареи работает плохо BO 857 (DIRTY)BATTERY CIRCUIT LOW INPUT (Грязная) Цепь аккумуляторной батареи имеет низкий уровень BO 858 (DIRTY)BATTERY CIRCUIT HIGH INPUT (Грязная) Цепь аккумуляторной батареи имеет высокий уровень BO 860 SYSTEM VOLTAGE HIGH Высокое напряжение питания системы BO 856 SYSTEM VOLTAGE LOW Низкое напряжение питания системы CO 200 RF WHEEL SPD SENS CIRCUIT MALFUNCTION Цепь датчика скорости правого переднего колеса неисправна CO 201 RF WHEEL SPD SENS CIRCUIT RANGE/PERF Цепь датчика правого переднего колеса работает плохо CO 202 RF WHEEL SPD SENS CIRCUIT LOW INPUT Цепь датчика правого переднего колеса всегда в низком уровне CO 203 RF WHEEL SPD SENS CIRCUIT HIGH INPUT Цепь датчика правого переднего колеса всегда в высок. уровне CO 205 LF WHEEL SPD SENS CIRCUIT MALFUNCTION Цепь датчика скорости левого переднего колеса неисправна CO 206 LF WHEEL SPD SENS CIRCUIT RANGE/PERF Цепь датчика левого переднего колеса работает плохо CO 207 LF WHEEL SPD SENS CIRCUIT LOW INPUT Цепь датчика левого переднего колеса всегда в низком уровне CO 208 LF WHEEL SPD SENS CIRCUIT HIGH INPUT Цепь датчика левого переднего колеса всегда в высок. уровне CO 210 RR WHEEL SPD SENS CIRCUIT MALFUNCTION Цепь датчика скорости правого заднего колеса неисправна CO 211 RR WHEEL SPD SENS CIRCUIT RANGE/PERF Цепь датчика правого заднего колеса работает плохо CO 212 RR WHEEL SPD SENS CIRCUIT LOW INPUT Цепь датчика правого заднего колеса всегда в низком уровне CO 213 RR WHEEL SPD SENS CIRCUIT HIGH INPUT Цепь датчика правого заднего колеса всегда в высок. уровне CO 215 LR WHEEL SPD SENS CIRCUIT MALFUNCTION Цепь датчика скорости левого заднего колеса неисправна CO 216 LR WHEEL SPD SENS CIRCUIT RANGE/PERF Цепь датчика левого заднего колеса работает плохо CO 217 LR WHEEL SPD SENS CIRCUIT LOW INPUT Цепь датчика левого заднего колеса всегда в низком уровне CO 218 LR WHEEL SPD SENS CIRCUIT HIGH INPUT Цепь датчика левого заднего колеса всегда в высок. уровне CO 220 REAR WHEEL SPD SENS CIRCUIT MALFUNCTION Цепь датчика скорости заднего колеса неисправна CO 221 REAR WHEEL SPD SENS CIRCUIT RANGE/PERF Цепь датчика заднего колеса работает плохо CO 222 REAR WHEEL SPD SENS CIRCUIT LOW INPUT Цепь датчика заднего колеса всегда в низком уровне CO 223 REAR WHEEL SPD SENS CIRCUIT HIGH INPUT Цепь датчика заднего колеса всегда в высок. уровне CO 225 WHEEL SPD SENS FREQUENCY ERROR Частота датчика скорости колеса ошибочна CO 226 RF ABS SOL/MTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 АБС прав. пер. колеса неисправна CO 227 RF ABS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 АБС прав. пер. колеса раб. медленно CO 228 RF ABS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 АБС прав.пер.колеса в низком уровне CO 229 RF ABS SOL/MTR #1 CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 АБС прав.пер.колеса в высок. уровне CO 231 RF ABS SOL/MTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 АБС прав. пер. колеса неисправна CO 232 RF ABS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 АБС прав. пер. колеса раб. медленно CO 233 RF ABS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 АБС прав.пер.колеса в низком уровне CO 234 RF ABS SOL/MTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 АБС прав.пер.колеса в высок. уровне CO 236 LF ABS SOL/MTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 АБС лев. пер. колеса неисправна CO 237 LF ABS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 АБС лев. пер. колеса раб. медленно CO 238 LF ABS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 АБС лев.пер.колеса в низком уровне CO 239 LF ABS SOL/MTR #1 CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 АБС лев.пер.колеса в высок. уровне CO 241 LF ABS SOL/MTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 АБС лев. пер. колеса неисправна CO 242 LF ABS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 АБС лев. пер. колеса раб. медленно CO 243 LF ABS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 АБС лев.пер.колеса в низком уровне CO 244 LF ABS SOL/MTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 АБС лев.пер.колеса в высок. уровне CO 246 RR ABS SOL/MTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 АБС прав. зад. колеса неисправна CO 247 RR ABS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 АБС прав. зад. колеса раб. медленно CO 248 RR ABS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 АБС прав.зад.колеса в низком уровне CO 249 RR ABS SOL/MTR #1 CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 АБС прав.зад.колеса в высок. уровне CO 251 RR ABS SOL/MTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 АБС прав. зад. колеса неисправна CO 252 RR ABS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 АБС прав. зад. колеса раб. медленно CO 253 RR ABS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 АБС прав.зад.колеса в низком уровне CO 254 RR ABS SOL/MTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 АБС прав.зад. колеса в высок. уровне CO 256 LR ABS SOL/MTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 АБС лев. зад. колеса неисправна CO 257 LR ABS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 АБС лев. зад. колеса раб. медленно CO 258 LR ABS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 АБС лев.зад.колеса в низком уровне CO 259 LR ABS SOL/MTR #1 CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 АБС лев.зад.колеса в высок. уровне CO 261 RR ABS SOL/MTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 АБС прав. зад. колеса неисправна CO 262 RR ABS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 АБС прав. зад. колеса раб. медленно CO 263 RR ABS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 АБС прав.зад.колеса в низком уровне CO 264 RR ABS SOL/MTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 АБС прав.зад. колеса в высок. уровне CO 266 PUMP MOTOR CIRCUIT MALFUNCTION Цепь двигателя насоса неисправна CO 267 PUMP MOTOR CIRCUIT RANGE/PERF Цепь двигателя насоса работает не правильно CO 268 PUMP MOTOR CIRCUIT LOW INPUT Цепь двигателя насоса всегда в низком уровне CO 269 PUMP MOTOR CIRCUIT HIGH INPUT Цепь двигателя насоса CO 271 PUMP MOTOR RELAY CIRCUIT MALFUNCTION Цепь реле двигателя насоса неисправна CO 272 PUMP MOTOR RELAY CIRCUIT RANGE/PERF Цепь реле двигателя насоса работает не правильно CO 273 PUMP MOTOR RELAY CIRCUIT LOW INPUT Цепь реле двигателя насоса всегда в низком уровне CO 274 PUMP MOTOR RELAY CIRCUIT HIGH INPUT Цепь реле двигателя насоса всегда высоком уровне CO 276 VALVE RELAY CIRCUIT MALFUNCTION Цепь реле клапана неисправна CO 277 VALVE RELAY CIRCUIT RANGE/PERF Цепь реле клапана работает не правильно CO 278 VALVE RELAY CIRCUIT LOW INPUT Цепь реле клапана всегда в низком уровне CO 279 VALVE RELAY CIRCUIT HIGH INPUT Цепь реле клапана всегда высоком уровне CO 300 RF TCS SOUMTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 “TCS” прав. пер. колеса неисправна CO 301 RF TCS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 «TCS» прав. пер. колеса раб. Медленно CO 302 RF TCS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 «TCS» прав.пер.колеса в низком уровне CO 303 RF TCS SOUMTR # CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 «TCS» прав.пер.колеса в высок. Уровне CO 305 RF TCS SOUMTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 «TCS» прав. пер. колеса неисправна CO 306 RF TCS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 «TCS» прав. пер. колеса раб. Медленно CO 307 RF TCS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 «TCS» прав.пер.колеса в низком уровне CO 308 RF TCS SOL/MTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 «TCS» прав.пер.колеса в высок. Уровне CO 310 LF TCS SOL/MTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 «TCS» лев. пер. колеса неисправна CO 311 LF TCS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 «TCS» лев. пер. колеса раб. медленно CO 312 LF TCS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 «TCS» лев.пер.колеса в низком уровне CO 313 LF TCS SOL/MTR #1 CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 «TCS» лев.пер.колеса в высок. уровне CO 315 LF TCS SOL/MTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 «TCS» лев. пер. колеса неисправна CO 316 LF TCS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 «TCS» лев. пер. колеса раб. медленно CO 317 LF TCS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 «TCS» лев.пер.колеса в низком уровне CO 318 LF TCS SOL/MTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 «TCS» лев.пер.колеса в высок. уровне CO 320 RR TCS SOL/MTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 «TCS» прав. зад. колеса неисправна CO 321 RR TCS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 «TCS» прав. зад. колеса раб. медленно CO 322 RR TCS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 «TCS» прав.зад.колеса в низком уровне CO 323 RR TCS SOL/MTR #1 CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 «TCS» прав.зад.колеса в высок. уровне CO 325 RR TCS SOL/MTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 «TCS» прав. зад. колеса неисправна CO 326 RR TCS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 «TCS» прав. зад. колеса раб. медленно CO 327 RR TCS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 «TCS» прав.зад.колеса в низком уровне CO 328 RR TCS SOL/MTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 «TCS» прав.зад. колеса в высок. уровне CO 330 LR TCS SOL/MTR #1 CIRCUIT MALFUNCTION Цепь соленоида/прив. №1 «TCS» лев. зад. колеса неисправна CO 331 LR TCS SOL/MTR #1 CIRCUIT RANGE/PERF Цепь соленоида/прив. №1 «TCS» лев. зад. колеса раб. медленно CO 332 LR TCS SOL/MTR #1 CIRCUIT LOW INPUT Цепь соленоида/прив. №1 «TCS» лев.зад.колеса в низком уровне CO 333 LR TCS SOL/MTR #1 CIRCUIT HIGH INPUT Цепь соленоида/прив. №1 «TCS» лев.зад.колеса в высок. уровне CO 335 RR TCS SOL/MTR #2 CIRCUIT MALFUNCTION Цепь соленоида/прив. №2 «TCS» прав. зад. колеса неисправна CO 336 RR TCS SOL/MTR #2 CIRCUIT RANGE/PERF Цепь соленоида/прив. №2 «TCS» прав. зад. колеса раб. медленно CO 337 RR TCS SOL/MTR #2 CIRCUIT LOW INPUT Цепь соленоида/прив. №2 «TCS» прав.зад.колеса в низком уровне CO 338 RR TCS SOUMTR #2 CIRCUIT HIGH INPUT Цепь соленоида/прив. №2 «TCS» прав.зад. колеса в высок. уровне CO 340 ABS/TCS BRAKE SW. CIRCUIT MALFUNCTION Цепь переключения систем «ABS»/ “TCS” неисправна CO 341 ABS/TCS BRAKE SW. CIRCUIT RANGE/PERF Цепь переключения систем «ABS»/ “TCS” работает медленно CO 342 ABS/TCS BRAKE SW. CIRCUIT LOW INPUT Цепь переключения систем «ABS»/ “TCS” в низком уровне CO 343 ABS/TCS BRAKE SW. CIRCUIT HIGH INPUT Цепь переключения систем «ABS»/ “TCS” в высоком уровне CO 345 LOW BRAKE FLUID CIRCUIT MALFUNCTION Цепь датчика низкого уровня тормозной жидкости неисправна CO 346 LOW BRAKE FLUID CIRCUIT RANGE/PERF Цепь датчика уровня тормозной жидкости работает не правильно CO 347 LOW BRAKE FLUID CIRCUIT LOW INPUT Цепь датчика уровня тормозной жидкости в низком уровне CO 348 LOW BRAKE FLUID CIRCUIT HIGH INPUT Цепь датчика уровня тормозной жидкости в высоком уровне CO 350 REAR SOL/MTR #1 CIRCUIT MALFUNCTION Цепь заднего соленоида/привода №1 неисправна CO 351 REAR SOL/MTR #1 CIRCUIT RANGE/PERF Цепь заднего соленоида/привода №1 работает не правильно CO 352 REAR SOL/MTR #1 CIRCUIT LOW INPUT Цепь заднего соленоида/привода №1 в низком уровне CO 353 REAR SOL/MTR #1 CIRCUIT HIGH INPUT Цепь заднего соленоида/привода №1 в высоком уровне CO 355 THROTTLE REDUCT MTR CIRCUIT MALFUNCTION Цепь мотора привода дросселя неисправна CO 356 THROTTLE REDUCT MTR CIRCUIT RANGE/PERF Цепь мотора привода дросселя работает не правильно CO 357 THROTTLE REDUCT MTR CIRCUIT LOW INPUT Цепь мотора привода дросселя в низком уровне CO 358 THROTTLE REDUCT MTR CIRCUIT HIGH INPUT Цепь мотора привода дросселя в высоком уровне CO 360 SYSTEM PRESSURE CIRCUIT MALFUNCTION Цепь систем измерения давления неисправна CO 361 SYSTEM PRESSURE CIRCUIT RANGE/PERF Цепь систем измерения давления работает не правильно CO 362 SYSTEM PRESSURE CIRCUIT LOW INPUT Цепь систем измерения давления в низком уровне CO 363 SYSTEM PRESSURE CIRCUIT HIGH INPUT Цепь систем измерения давления в высоком уровне CO 365 LATERAL ACCELEROMTR CIRCUIT MALFUNCTION Цепь измерителя бокового ускорения неисправна CO 366 LATERAL ACCELEROMTR CIRCUIT RANGE/PERF Цепь измерителя бокового ускорения работает не правильно CO 367 LATERAL ACCELEROMTR CIRCUIT LOW INPUT Цепь измерителя бокового ускорения в низком уровне CO 368 LATERAL ACCELEROMTR CIRCUIT HIGH INPUT Цепь измерителя бокового ускорения в высоком уровне CO 370 YAW RATE CIRCUIT MALFUNCTION Цепь датчика курсовой устойчивости неисправна CO 371 YAW RATE CIRCUIT RANGE/PERF Цепь датчика курсовой устойчивости работает не правильно CO 372 YAW RATE CIRCUIT LOW INPUT Цепь датчика курсовой устойчивости в низком уровне CO 373 YAW RATE CIRCUIT HIGH INPUT Цепь датчика курсовой устойчивости в высоком уровне CO 500 STEEPING SOLENOID CIRCUIT MALFUNCTION Цепь втягивающего соленоида (втягивающего реле) неисправна CO 501 STEEPING SOLENOID CIRCUIT RANGE/PERF Цепь втягивающего соленоида работает не правильно CO 502 STEEPING SOLENOID CIRCUIT LOW INPUT Цепь втягивающего соленоида в низком уровне CO 503 STEEPING SOLENOID CIRCUIT HIGH INPUT Цепь втягивающего соленоида в высоком уровне CO 505 STEEPING POSITION SENSOR MALFUNCTION CO 506 STEEPING POSITION SENSOR RANGE/PERF CO 507 STEEPING POSITION SENSOR LOW INPUT CO 508 STEEPING POSITION SENSOR HIGH INPUT CO 510 STEEPING CHANGE RATE SENSOR MALFUNCTION CO 511 STEEPING CHANGE RATE SENSOR RANGE/PERF CO 512 STEEPING CHANGE RATE SENSOR LOW INPUT CO 513 STEEPING CHANGE RATE SENSOR HIGH INPUT CO 700 LF SOLENOID CIRCUIT MALFUNCTION Цепь левого переднего соленоида неисправна CO 701 LF SOLENOID CIRCUIT RANGE/PERF Цепь левого переднего соленоида работает не правильно CO 702 LF SOLENOID CIRCUIT LOW INPUT Цепь левого переднего соленоида в низком уровне CO 703 LF SOLENOID CIRCUIT HIGH INPUT Цепь левого переднего соленоида в высоком уровне CO 705 RF SOLENOID CIRCUIT MALFUNCTION Цепь правого переднего соленоида неисправна CO 706 RF SOLENOID CIRCUIT RANGE/PERF Цепь правого переднего соленоида работает не правильно CO 707 RF SOLENOID CIRCUIT LOW INPUT Цепь правого переднего соленоида в низком уровне CO 708 RF SOLENOID CIRCUIT HIGH INPUT Цепь правого переднего соленоида в высоком уровне CO 710 LR SOLENOID CIRCUIT MALFUNCTION Цепь левого заднего соленоида неисправна CO 711 LR SOLENOID CIRCUIT RANGE/PERF Цепь левого заднего соленоида работает не правильно CO 712 LR SOLENOID CIRCUIT LOW INPUT Цепь левого заднего соленоида в низком уровне CO 713 LR SOLENOID CIRCUIT HIGH INPUT Цепь левого заднего соленоида в высоком уровне CO 715 RR SOLENOID CIRCUIT MALFUNCTION Цепь правого заднего соленоида неисправна CO 716 RR SOLENOID CIRCUIT RANGE/PERF Цепь правого заднего соленоида работает не правильно CO 717 RR SOLENOID CIRCUIT LOW INPUT Цепь правого заднего соленоида в низком уровне CO 718 RR SOLENOID CIRCUIT HIGH INPUT Цепь правого заднего соленоида в высоком уровне CO 720 LF ACCELEROMTR CIRCUIT MALFUNCTION Цепь левого переднего акселерометра неисправна CO 721 LF ACCELEROMTR CIRCUIT RANGE/PERF Цепь левого переднего акселерометра работает не правильно CO 722 LF ACCELEROMTR CIRCUIT LOW INPUT Цепь левого переднего акселерометра в низком уровне CO 723 LF ACCELEROMTR CIRCUIT HIGH INPUT Цепь левого переднего акселерометра в высоком уровне CO 725 RF ACCELEROMTR CIRCUIT MALFUNCTION Цепь правого переднего акселерометра неисправна CO 726 RF ACCELEROMTR CIRCUIT RANGE/PERF Цепь правого переднего акселерометра работает не правильно CO 727 RF ACCELEROMTR CIRCUIT LOW INPUT Цепь правого переднего акселерометра в низком уровне CO 728 RF ACCELEROMTR CIRCUIT HIGH INPUT Цепь правого переднего акселерометра в высоком уровне CO 730 LR ACCELEROMTR CIRCUIT MALFUNCTION Цепь левого заднего акселерометра неисправна CO 731 LR ACCELEROMTR CIRCUIT RANGE/PERF Цепь левого заднего акселерометра работает не правильно CO 732 LR ACCELEROMTR CIRCUIT LOW INPUT Цепь левого заднего акселерометра в низком уровне CO 733 LR ACCELEROMTR CIRCUIT HIGH INPUT Цепь левого заднего акселерометра в высоком уровне CO 735 RR ACCELEROMTR CIRCUIT MALFUNCTION Цепь правого заднего акселерометра неисправна CO 736 RR ACCELEROMTR CIRCUIT RANGE/PERF Цепь правого заднего акселерометра работает не правильно CO 737 RR ACCELEROMTR CIRCUIT LOW INPUT Цепь правого заднего акселерометра в низком уровне CO 738 RR ACCELEROMTR CIRCUIT HIGH INPUT Цепь правого заднего акселерометра в высоком уровне CO 740 LF POSITION SENSOR CIRCUIT MALFUNCTION Цепь левого переднего датчика положения неисправна CO 741 LF POSITION SENSOR CIRCUIT RANGE/PERF Цепь левого переднего датчика положения работает не правильно CO 742 LF POSITION SENSOR CIRCUIT LOW INPUT Цепь левого переднего датчика положения в низком уровне CO 743 LF POSITION SENSOR CIRCUIT HIGH INPUT Цепь левого переднего датчика положения в высоком уровне CO 745 RF POSITION SENSOR CIRCUIT MALFUNCTION Цепь правого переднего датчика положения неисправна CO 746 RF POSITION SENSOR CIRCUIT RANGE/PERF Цепь правого переднего датчика положения работает не правильно CO 747 RF POSITION SENSOR CIRCUIT LOW INPUT Цепь правого переднего датчика положения в низком уровне CO 748 RF POSITION SENSOR CIRCUIT HIGH INPUT Цепь правого переднего датчика положения в высоком уровне CO 750 LR POSITION SENSOR CIRCUIT MALFUNCTION Цепь левого заднего датчика положения неисправна CO 751 LR POSITION SENSOR CIRCUIT RANGE/PERF Цепь левого заднего датчика положения работает не правильно CO 752 LR POSITION SENSOR CIRCUIT LOW INPUT Цепь левого заднего датчика положения в низком уровне CO 753 LR POSITION SENSOR CIRCUIT HIGH INPUT Цепь левого заднего датчика положения в высоком уровне CO 755 RR POSITION SENSOR CIRCUIT MALFUNCTION Цепь правого заднего датчика положения неисправна CO 756 RR POSITION SENSOR CIRCUIT RANGE/PERF Цепь правого заднего датчика положения работает не правильно CO 757 RR POSITION SENSOR CIRCUIT LOW INPUT Цепь правого заднего датчика положения в низком уровне CO 758 RR POSITION SENSOR CIRCUIT HIGH INPUT Цепь правого заднего датчика положения в высоком уровне
2 комментарии
Кто сейчас на конференцииЗарегистрированные пользователи: Google [Робот], Majestic-12 [Робот], Yandex [Робот], кузька |
